Home » Eclipse Projects » Remote Application Platform (RAP) » More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps
More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps [message #138849] Wed, 01 July 2009 08:51 Go to next message
Originally posted by: benjamin.wolff.web.de
i modified the ConfigIniCreator.java file that comes with the RAP demo deploy feature to add some more convenient features:
- uses relative paths to the build feature so it can be used on any machine with the same workspace content
- automatically converts windows to unix path separator chars so it can be used without change on unix and windows machines
- sorts the list of plugins to have a lexicographical sorted plugin list in the resulting config.ini
- automatically determines whether a plug-in (bundle) jar file is a fragment and thus not adding a @start tag to this bundle
- after creation on the config it automatically outputs the content in the config.ini file so there is no need to copy&paste it
there is no big magic behind it, but someone who uses a copied and adjusted version of the rap demo feature to deploy the RAP app
on a i.e. tomcat (like i do) might find this ideas a bit inspiring :)
the file is commented at the points where you need to adjust the paths etc. my deploy feature is placed in the workspace right next
to the other plug-ins, this is important to determine the relative paths. moreover my deploy feature has the same structure as
the rap demo feature. the xml script are located in the scripts folder etc.
the next litte ant script simply builds a .war file of the folder that has been filled by the webappBuilder.xml ant script. so
the procedure of deploying a RAP app on a tomcat can be as simply as this:
- adjust the feature to include the needed plug-ins and fragments
- run the webappBuilder.xml script (adjust the paths)
- run the ConfigIniCreator.java file (adjust the paths/settings)
- run the warBuilder.xml script (adjust the paths)
the resulting .war file can then be uploaded / placed in the tomcat webapp folder, done and done :P. that's how i do it however.
here are the contents of the two files, feedback, improvements, other ideas are always welcomed!!
ConfigIniCreater.java:
import java.io.File;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.OutputStreamWriter;
import java.util.Arrays;
import java.util.Comparator;
import java.util.jar.Attributes;
import java.util.jar.JarFile;
import java.util.jar.Manifest;
* This tool creates the content of a simple config.ini file. Run this after the
* ANT build scripts (webappBuilder.xml and the pde.exportFeatures) have
* finished. After that, replace the content of the config.ini file in the build.
* <p>
* Note: this is not meant to be a high end deployment tool or the only
* possibility of how the content of your config.ini should look like if you are
* creating a RAP WAR. This should simplify the task to get a minimalistic
* runtime configuration that works...
public class ConfigIniCreator {
* Name of the project directory
private static final String PROJECT_DIR_NAME = "modulhandbuch";
* Relative or absolute path to the BUILD_DIR of the project
private static final String BUILD_DIR = ".\\build\\" + PROJECT_DIR_NAME;
* Relative or absolute path to the plug-in directory of the deploy build
private static String PLUGIN_PATH = BUILD_DIR + "\\WEB-INF\\eclipse\\plugins";
* Relative or absolute path to the config.ini of the deploy build
private static String CONFIG_PATH = BUILD_DIR + "\\WEB-INF\\eclipse\\configuration\\config.ini";
* Name of the framework bundle, this bundle needs to be excluded from the config.ini
private static final String FRAMEWORK_BUNDLE = "org.eclipse.osgi_";
* Name of the Equinox Servletbridge Extension bundle
private static final String EXTENSION_BUNDLE = "org.eclipse.equinox.servletbridge.extensionbundle";
* Name of the fragment host attribute in the MANIFEST.MF of a jar file,
* is used to determine whether a jar file is a fragment bundle.
private static final String FRAGMENT_MANIFEST_ATTRIBUTE = "Fragment-Host";
* Default start level of the OSGi bundles
private static final String DEFAULT_OSGI_STARTLEVEL = "4";
* Creates the config.ini file respecting the files in the PLUGIN_PATH.
* @param args
* @throws IOException
public static void main(String[] args) throws IOException {
// On no-windows systems, the file separator will be replaced with the
// proper one
if (!File.separator.equals("\\")) {
PLUGIN_PATH = PLUGIN_PATH.replace('\\', File.separatorChar);
CONFIG_PATH = CONFIG_PATH.replace('\\', File.separatorChar);
File file = new File(PLUGIN_PATH);
// The launch-configuration is being created based on the plug-ins in the deploy build
String filename = null;
String bundlename = null;
int underscorePos = 0;
File[] fileList = file.listFiles();
// Sort the file array to have a lexicographically ordered config.ini
Arrays.sort(fileList, new Comparator<File>() {
public int compare(File o1, File o2) {
return String.CASE_INSENSITIVE_ORDER.compare(o1.getName(), o2.getName());
StringBuffer buffer = new StringBuffer();
buffer.append("# Eclipse Runtime Configuration File\n");
buffer.append("osgi.bundles=");
for (int i = 0; i < fileList.length; i++) {
filename = fileList[i].getName();
if (filename.endsWith(".jar") && !filename.startsWith(FRAMEWORK_BUNDLE)) {
// Remove version number
underscorePos = filename.lastIndexOf("_");
bundlename = filename.substring(0, underscorePos);
// Append bundle name
buffer.append(bundlename);
// Add the start command. Fragments must not be started!
if (!isFragment(fileList[i])) {
if (filename.startsWith("org.eclipse.equinox.common_")) {
buffer.append("@2:start");
} else {
buffer.append("@start");
buffer.append(",\\\n ");
if ((i + 1) >= fileList.length) {
buffer.append(EXTENSION_BUNDLE);
buffer.append("\n");
buffer.append("osgi.bundles.defaultStartLevel=" + DEFAULT_OSGI_STARTLEVEL + "\n");
// The config string will be automatically written in the config.ini, it
// is not necessary to manually copy and paste the string in the file
FileOutputStream fileStream = new FileOutputStream(CONFIG_PATH);
OutputStreamWriter outStream = new OutputStreamWriter(fileStream);
outStream.write(buffer.toString());
// Clean up
outStream.flush();
fileStream.flush();
outStream.close();
fileStream.close();
// Print the status
System.out.print(buffer);
System.out.println();
System.out.println("File: " + CONFIG_PATH + " successfully written");
* This method checks the META-INF/MANIFEST.MF of the provided JAR file to
* determine whether the bundle JAR file is a fragment bundle.
* @param file the JAR file to be checked
* @return true if the JAR file is a fragment bundle, false otherwise
public static boolean isFragment(File file) throws IOException {
JarFile jarfile = new JarFile(file);
Manifest manifest = jarfile.getManifest();
if (manifest != null) {
Attributes attributes = manifest.getMainAttributes();
return attributes.containsKey(new Attributes.Name(FRAGMENT_MANIFEST_ATTRIBUTE));
} else {
return false;
warBuilder.xml:
This Ant-Script packs the project build directory to a .war file which
can be deployed on e.g. a Apache Tomcat Servlet-Container.
Step one is to execute the webappBuilder.xml Ant-Script. Step two is to
execute the ConfigIniCreator.java file to create the proper config.ini file.
Step three is to make all necessary changes to any files in the resulting
project build dir. Step four is to run this Ant-Script to create a .war file.
The project can then be deployed by copying the project build directory
directly into the webapp folder of the Tomcat Server or by using the .war
file and the Tomcat Manager for example.
The properties in the init target need to be adjusted to the correct names
and paths!
<project name="project" default="default" basedir=".">
<description>
This Ant-Script creates a .war file from the project build directory
after the webappBuilder.xml assembled the directory and all configurations
to the files in the build directory have been made
</description>
target: init
<target name="init">
<property name="project.name" value="modulhandbuch"/>
<property name="project.dir" value="${basedir}/.."/>
<property name="build.dir" value="${project.dir}/build"/>
<property name="source.dir" value="${build.dir}/${project.name}"/>
<property name="dest.file" value="${build.dir}/${project.name}.war"/>
</target>
target: default
<target name="default" depends="buildWar"/>
target: prepare
<target name="prepare" depends="init">
<delete file="${dest.file}" quiet="true"/>
</target>
target: warBuild
<target name="buildWar" depends="prepare">
<zip destfile="${dest.file}" basedir="${source.dir}" defaultexcludes="true" update="false"/>
</target>
</project>
HTH,
ben
Re: More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps [message #138866 is a reply to message #138849] Wed, 01 July 2009 09:00 Go to previous messageGo to next message
one more remark: the problem is, is seems that the pde.exportFeature of the webappBuilder.xml can only be run asynchronously. if it could be run synchronously, all of the
steps could be packed in a single ant script, because the config.ini creation and the war build need to be done in the correct order and after the pde.exportFeature
has finished. i could not figure out a way until now to do this, maybe someone else already found a solution or has an even better solution?!
greetings,
ben
Ben W. schrieb:
> after the
> the build.
> * <p>
> you are
> build
> from the config.ini
> "Fragment-Host";
> * @param args
> with the
> // proper one
> config.ini
> @Override
> return
> if
> } else {
> config.ini, it
> file
> // Clean up
> outStream.flush();
> fileStream.flush();
> outStream.close();
> fileStream.close();
> // Print the status
> written");
> file to
> } else {
> return false;
> warBuilder.xml:
> config.ini file.
> resulting
> .war file.
> .war
> names
> and paths!
> <description>
> configurations
> </description>
> target: init
> </target>
> target: default
> target: prepare
> </target>
> target: warBuild
> </target>
> </project>
> HTH,
> ben
Re: More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps [message #138889 is a reply to message #138849] Wed, 01 July 2009 10:28 Go to previous messageGo to next message
Where do I get this RAP demo deploy feature?
I have checked out RAP from the rap update site and imported the
org.eclipse.rap.demo into my workspace. Nowhere do I find
ConfigIniCreator.java.
regards,
Hans
Re: More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps [message #138901 is a reply to message #138889] Wed, 01 July 2009 10:35 Go to previous messageGo to next message
Hi Hans,
you should make yourself familiar with CVS and checking out projects from a CVS repository, how this is done is described here:
http://www.eclipse.org/rap/cvs.php
there you find projects that are not distributed with the target-platform or tooling. using the CVS HEAD projects it is ensured that
you always work with the latest development status of the plug-ins. you can, for example, check out all rap projects from CVS in
your workspace and thus working with the latest additions/bug fixes etc. of RAP. but beware that there could also be new bugs that
are not present in the main release.
as mentioned in the RAP development guide about WAR deployment you should check out the prerequisitas provided in this file:
http://help.eclipse.org/galileo/topic/org.eclipse.rap.help/h elp/html/advanced/servletbridge-anon.psf
this is a team project set file. right-click in your workspace, choose 'import' select team project set and select the .psf file (download it somewhere).
the projects are then downloaded (checked-out) in your workspace. and voila, there are the mysterious projects =))
HTH,
ben
> regards,
> Hans
Re: More convenient ConfigIniCreator.java and a warBuilder.xml for deploying RAP apps [message #138924 is a reply to message #138901] Wed, 01 July 2009 10:55 Go to previous message
Thanks. This makes things clearer.
I had tried getting org.eclipse.rap.demo.feature from /cvsroot/technology
instead of /cvsroot/rt.
I hope I have more success when I continue on this tomorrow.
regards
Hans
Previous Topic:Does RAP support auto-completion of text fields?
Next Topic:Display.syncExec() does not work
Current Time: Sat Jul 19 06:00:49 EDT 2025
Powered by FUDForum. Page generated in 0.04265 seconds
