Home » Newcomers » Newcomers » Action Set Problem(Plugin uninstall incomplete - unable to find Action Set)
Action Set Problem [message #1388077] Wed, 25 June 2014 21:22 Go to next message
I have uninstalled org.eclipse VJet plugin and now have the following message in the error log each time I start up Eclipse:
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.8.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -vm C:\Program Files (x86)\java\jre7\bin\javaw.exe
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -vm C:\Program Files (x86)\java\jre7\bin\javaw.exe
Error
Wed Jun 25 15:32:57 EDT 2014
Unable to find Action Set: org.eclipse.dltk.mod.ui.actionSet.vjoSearchMenu
So what is an Action Set and how do I fix this?
Re: Action Set Problem [message #1388115 is a reply to message #1388077] Wed, 25 June 2014 22:39 Go to previous messageGo to next message
I'm going to try the easier of those two and suggest you Reset the Perspective from the Window menu.
Re: Action Set Problem [message #1388572 is a reply to message #1388115] Thu, 26 June 2014 12:36 Go to previous message
Thanks from a former IBMer. That seems to have done the trick.
Previous Topic:How to setup which resources to include in searches
Next Topic:Where do I find how to change indentation using tab key
Current Time: Sun Jul 20 03:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.08451 seconds
