Home » Eclipse Projects » Oomph » Version constraints in requirements for Targlet and P2
Version constraints in requirements for Targlet and P2 [message #1387178] Tue, 24 June 2014 12:27 Go to next message
I am trying to create a setup that uses specific versions of given features (e.g. Xtext 2.4.2). However, after setting the precise version in the requirement in the setup model (copied from a target definition, e.g. 2.4.2.v201306120542), I get an exception during the execution of the Targlet task, that Xtext 2.6.1 and another feature that depends on Xtext 2.4 cannot be installed in the same time.
Am I using the version attribute incorrectly or this use case is not supported? I could not find any setup file that used the version attribute.
!ENTRY org.eclipse.equinox.p2.director 4 10054 2014-06-24 17:00:11.834
!MESSAGE Cannot complete the install because of a conflicting dependency.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.834
!MESSAGE Software being installed: EMF-IncQuery SDK (Incubation) 0.7.2.201402181114 (org.eclipse.incquery.sdk.feature.source.feature.group 0.7.2.201402181114)
!MESSAGE Software being installed: Xtext SDK 2.6.1.v201406120726 (org.eclipse.xtext.sdk.feature.group 2.6.1.v201406120726)
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2014-06-24 17:00:11.834
!MESSAGE Only one of the following can be installed at once:
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.834
!MESSAGE Xbase Model 2.6.1.v201406120726 (org.eclipse.xtext.xbase 2.6.1.v201406120726)
!MESSAGE Xbase Model 2.5.2.v201402120812 (org.eclipse.xtext.xbase 2.5.2.v201402120812)
!MESSAGE Xbase Model 2.5.4.v201404100756 (org.eclipse.xtext.xbase 2.5.4.v201404100756)
!MESSAGE Xbase Model 2.4.3.v201309030823 (org.eclipse.xtext.xbase 2.4.3.v201309030823)
!MESSAGE Xbase Model 2.5.3.v201402240820 (org.eclipse.xtext.xbase 2.5.3.v201402240820)
!MESSAGE Xbase Model 2.6.0.v201405210727 (org.eclipse.xtext.xbase 2.6.0.v201405210727)
!MESSAGE Xbase Model 2.5.0.v201312110906 (org.eclipse.xtext.xbase 2.5.0.v201312110906)
!MESSAGE Xbase Model 2.4.2.v201306120542 (org.eclipse.xtext.xbase 2.4.2.v201306120542)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.835
!MESSAGE Xbase Model 2.5.1.v201402030714 (org.eclipse.xtext.xbase 2.5.1.v201402030714)
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2014-06-24 17:00:11.835
!MESSAGE Cannot satisfy dependency:
!MESSAGE From: EMF-IncQuery SDK (Incubation) without Sources 0.7.2.201402181114 (org.eclipse.incquery.sdk.feature.feature.group 0.7.2.201402181114)
!MESSAGE To: org.eclipse.incquery.tooling.ui [0.7.2.201402181114]
!MESSAGE From: EMF-IncQuery SDK (Incubation) 0.7.2.201402181114 (org.eclipse.incquery.sdk.feature.source.feature.group 0.7.2.201402181114)
!MESSAGE To: org.eclipse.incquery.sdk.feature.feature.group [0.7.2.201402181114]
!MESSAGE From: IncQuery Tooling - User Interface (Incubation) 0.7.2.201402181114 (org.eclipse.incquery.tooling.ui 0.7.2.201402181114)
!MESSAGE To: bundle org.eclipse.xtext.xbase [2.4.2,2.5.0)
!MESSAGE From: Xtext SDK 2.6.1.v201406120726 (org.eclipse.xtext.sdk.feature.group 2.6.1.v201406120726)
!MESSAGE To: org.eclipse.xtext.xbase.feature.group [2.6.1.v201406120726]
!MESSAGE From: Xbase 2.6.1.v201406120726 (org.eclipse.xtext.xbase.feature.group 2.6.1.v201406120726)
!MESSAGE To: org.eclipse.xtext.xbase [2.6.1.v201406120726]
!ENTRY org.eclipse.pde.core 4 0 2014-06-24 17:00:11.854
!MESSAGE Problems occurred while resolving the target contents
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 10054 2014-06-24 17:00:11.854
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.854
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2014-06-24 17:00:11.854
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.854
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2014-06-24 17:00:11.855
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2014-06-24 17:00:11.855
Re: Version constraints in requirements for Targlet and P2 [message #1387183 is a reply to message #1387178] Tue, 24 June 2014 13:16 Go to previous messageGo to next message
Abel,
It's not clear which repos and which units you've listed in the task.
When you say an exact version number I hope/assume you mean a range
including 2.4.0 but excluding 2.5.0. Better would be to attach the *.setup.
> attribute.
> 0.7.2.201402181114
> 0.7.2.201402181114)
> !MESSAGE Only one of the following can be installed at once: !SUBENTRY
> 0.7.2.201402181114)
> 0.7.2.201402181114)
> 17:00:11.854
> 0.7.2.201402181114
> 0.7.2.201402181114)
> 0.7.2.201402181114)
> 0.7.2.201402181114)
Re: Version constraints in requirements for Targlet and P2 [message #1387184 is a reply to message #1387178] Tue, 24 June 2014 13:31 Go to previous messageGo to next message
Hi Abdel,
Comments below...
Cheers
/Eike
http://www.esc-net.de
Am 24.06.2014 18:27, schrieb Abel Hegedus:
Please note that the PDE target definition file format allows you to specifiy *installable units* with optional (exact)
*versions*, i.e., "x.y.z.q". No version or "0.0.0" means any version (so more of a version range).
In Oomph we generally use *requirement* with *version ranges*, which is generally more flexible. The format is typically
"[min-version,max-version)" and there are two special forms:
1) "0.0.0" is the omni version range
2) "[version-x,version-x]" is exactly version-x
So you should use the format 2, but keep in mind that you run into unsatisfiable queries more likely the smaller these
ranges are. Trying it out is often your best option ;-)
Note also that in Oomph models you cannot enter syntactically wrong version ranges without seeing the parse error in the
status line.
That's just because most targlets mostly point to the *own* source components and leave it to them to pull in the
required binary components. Source components have a specific version in the workspace so there's no need to specify
verion ranges for them in the targlets.
After reformatting this lovely error message the problem becomes more apparent:
0.7.2.201402181114)
0.7.2.201402181114)
To: bundle _org.eclipse.xtext.xbase [2.4.2,2.5.0)_
To: _org.eclipse.xtext.xbase [2.6.1.v201406120726]_
Put simpler: The version of IncQuery you're using requires org.eclipse.xtext.xbase [2.4.2,2.5.0), which can not be
resolved together with your own requirement of org.eclipse.xtext.xbase [2.6.1.v201406120726]. You need to either find an
IncQuery version that uses a newer Xbase or use an older Xbase yourself.
> !MESSAGE Only one of the following can be installed at once: !SUBENTRY 2 org.eclipse.equinox.p2.director 4 0
> 0.7.2.201402181114)
> 0.7.2.201402181114)
> !MESSAGE Only one of the following can be installed at once: !SUBENTRY 3 org.eclipse.equinox.p2.director 4 0
> 0.7.2.201402181114)
> 0.7.2.201402181114)
Re: Version constraints in requirements for Targlet and P2 [message #1387185 is a reply to message #1387183] Tue, 24 June 2014 13:38 Go to previous messageGo to next message
Since the validation did not show errors, I used exact versions that are available from the repositories listed in the dependencies (as mentioned, I adopted a working .target file), See the attached setup.
Thanks for your help Ed and Eike, I'll try with the modifications you suggest.
Again, I saw that the validation doesn't allow incorrect ranges, but it doesn't complain on using a simple number. Should I file a bugzilla issue about that?
Edit: as you can see, I have no requirement towards Xbase 2.6.1, so that's not the cause, I imagine it uses "2.4.2..." as "[2.4.2,anything)".
[Updated on: Tue, 24 June 2014 13:46] by Moderator
Re: Version constraints in requirements for Targlet and P2 [message #1387186 is a reply to message #1387185] Tue, 24 June 2014 14:08 Go to previous messageGo to next message
Am 24.06.2014 19:38, schrieb Abel Hegedus:
No, "x.y.z" is correctly interpreted by p2 (not by PDE!!) as "[x.y.z,max.max.max]", i.e. a version range with x.y.z as
lower bound and no upper bound. Tricky, eh? ;-)
Cheers
/Eike
Re: Version constraints in requirements for Targlet and P2 [message #1387537 is a reply to message #1387186] Wed, 25 June 2014 04:16 Go to previous messageGo to next message
I have updated my targlet and now it goes through the requirement and dependency calculation. However, I get an exception in the installation phase, do you have any idea what could go wrong? Thanks!
[09:50:17] Installing ch.qos.logback.classic
[09:50:17] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[09:50:17] ERROR: org.eclipse.pde.core code=0 Problems occurred while resolving the target contents
  at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:573)
  at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:436)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2310)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.access$0(SetupTaskPerformer.java:2283)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:2916)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:2910)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:2908)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2274)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2258)
  at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2200)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$7.run(ProgressPage.java:353)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9$1.run(ProgressPage.java:429)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
  ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while installing the items
    ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=D__PhD_EclipseSpace_Oomph_transima-maintenance_ws-d434b8923c949ae5f286b714b28e5994b6e4abcd, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]ch.qos.logback.classic 1.0.7.v20121108-1250, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
      at org.eclipse.equinox.internal.frameworkadmin.equinox.EclipseLauncherParser.read(EclipseLauncherParser.java:67)
      at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.loadWithoutFwPersistentData(EquinoxManipulatorImpl.java:346)
      at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.load(EquinoxManipulatorImpl.java:319)
      at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.loadDelegate(LazyManipulator.java:55)
      at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.getConfigData(LazyManipulator.java:108)
      at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction.installBundle(InstallBundleAction.java:75)
      at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction.execute(InstallBundleAction.java:32)
      at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:38)
      at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:183)
      at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:95)
      at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
      at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
      at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
      at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:41)
      at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:685)
      at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:325)
      at org.eclipse.oomph.targlets.internal.core.TargletContainer.updateProfile(TargletContainer.java:656)
      at org.eclipse.oomph.targlets.internal.core.TargletContainer.resolveUnits(TargletContainer.java:465)
      at org.eclipse.oomph.targlets.internal.core.TargletContainer.resolveBundles(TargletContainer.java:422)
      at org.eclipse.pde.internal.core.target.AbstractBundleContainer.resolve(AbstractBundleContainer.java:77)
      at org.eclipse.pde.internal.core.target.TargetDefinition.resolve(TargetDefinition.java:262)
      at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:570)
Re: Version constraints in requirements for Targlet and P2 [message #1387579 is a reply to message #1387537] Wed, 25 June 2014 05:27 Go to previous messageGo to next message
Hi Abdel,
I would like to reproduce the problem. Can you please submit a bugzilla and attach your model file or at least paste in
the markup of your targlet task?
Cheers
/Eike
Am 25.06.2014 10:16, schrieb Abel Hegedus:
> log for details.
> at
> ERROR: org.eclipse.equinox.p2.engine code=0 java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Version constraints in requirements for Targlet and P2 [message #1387606 is a reply to message #1387579] Wed, 25 June 2014 06:15 Go to previous message
Issue created in https://bugs.eclipse.org/bugs/show_bug.cgi?id=438141
Thanks for loooking into it!
Previous Topic:Error opening user.setup after removing installation
Next Topic:Target container doesn't include SWT native fragment
Current Time: Sun Jul 20 07:53:45 EDT 2025
Powered by FUDForum. Page generated in 0.04158 seconds
