Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] 3 way content match is losing an add?
[EMF Compare] 3 way content match is losing an add? [message #138694] Wed, 15 July 2009 18:42 Go to next message
Originally posted by: stephenmccants.yahoo.com
I'm not sure if I'm doing something wrong, or if I've found a bug, but I have a model that has a
left and right that are both different from their ancestor.
Here is the ancestor:
<com.ibm.xmlns.prod.hdwb.test:TestFolder xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:com.ibm.xmlns.prod.hdwb.test="http://www.ibm.com/xmlns/prod/hdwb/test/4.0"
name="Folder 3" contextId="UUID1">
<parent href="root#/"/>
</com.ibm.xmlns.prod.hdwb.test:TestFolder>
Here is the left side, which has the name changed:
name="Fredrick" contextId="UUID1">
Here is the right side, which has a child ("resource") added:
<resources href="third#/"/>
I'm expecting the match model to match the three TestFolders and show an unmatched object which is
the added resource (third). Instead I only get the three TestFolders matched:
<match:MatchModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:match="http://www.eclipse.org/emf/compare/match/1.1">
<matchedElements xsi:type="match:Match3Elements" similarity="0.43478260869565216">
<leftElement href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
<rightElement href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
<originElement href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
</matchedElements>
<leftRoots href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
<rightRoots href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
<ancestorRoots href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
</match:MatchModel>
This goes means that the diff model only reports the name change and does not report the add:
<diff:DiffModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1">
<ownedElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:UpdateAttribute">
<attribute href=" http://www.ibm.com/xmlns/prod/hdwb/test/4.0#//TestResource/n ame"/>
</subDiffElements>
<rightParent href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/first# /"/>
</subDiffElements>
<rightParent href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/root#/"/>
</subDiffElements>
</ownedElements>
</diff:DiffModel>
So when I merge the differences (should be mergable without problem), I only get the resulting
object has either the name change OR the add, but never both. Which I get depends on whether I
merge to the left or to the right.
I started digging into what is going on in the GenericMatchEngine and found what I think is the
problem. The initial contentMatch(rightObject, ancestor, optionMap) call on line 166
(GenericMatchEngine) works correctly and adds the child object (named "TestContext 4") to the
stillToFindFromModel1 List. The object is also added to remainingUnmatchedElements as well (pulled
from rightObjectAncestorMatch.getUnmatchedElements()).
The processUnmatchedElements(...) call (GenericMatchEngine line 202) does nothing because the
unmatched object from stillToFindFromModel1 is an instance of TestContext (part of my model) and not
an Match2Elements object.
The for loop in line 207 (GenericMatchEngine) that deals with remainingUnmatchedElements does
nothing, because the TestContext actually belongs to a different resource than the object
referencing it.
After that, the Lists are cleared and the unmatched object is simply lost.
It is worth noting that I've overridden the isSimilar(...) method, but I don't think that should
affect unmatched objects.
I'm thinking about overriding contentMatch(EObject, EObject, EObject, Map) to handle my specific case.
Any thoughts? Is this a bug or am I going about this the wrong way?
Thanks for your help!
Sincerely,
Stephen McCants
Re: [EMF Compare] 3 way content match is losing an add? [message #138711 is a reply to message #138694] Wed, 15 July 2009 19:40 Go to previous messageGo to next message
I forced it to put the unmatched element in the match model (as an unmatched element, of course),
but when I did the merge it did something I didn't want. It did successfully add the child, but it
placed it inside its parent's resource instead of a reference to the child's own resource.
Here was the resulting match model:
<?xml version="1.0" encoding="ISO-8859-1"?>
</matchedElements>
<unmatchedElements remote="true" side="Right">
<element href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/third# /"/>
</unmatchedElements>
</match:MatchModel>
Here is the resulting diff model:
</subDiffElements>
<subDiffElements xsi:type="diff:ModelElementChangeLeftTarget" remote="true">
<leftElement href=" https://localhost:9443/jazz/storage/com.ibm.hdwb.test/third# /"/>
</subDiffElements>
</subDiffElements>
</subDiffElements>
</ownedElements>
</diff:DiffModel>
Here is the resulting object:
name="Fredrick" contextId="_SdHucWT6Ed6p-b87WYLUSw">
<resources xsi:type="com.ibm.xmlns.prod.hdwb.test:TestContext" name="Context 4"
contextId="_SdHucWT6Ed6p-b87WYLUSw"/>
Here is the desired object:
I'm thinking about overriding the Merge code to handle the references to another resource. Is there
a better way to go about this? Thanks!
--Stephen
Stephen McCants wrote:
> Hello,
> but I have a model that has a left and right that are both different
> unmatched object which is the added resource (third). Instead I only
> <leftElement
> <rightElement
> <originElement
> </matchedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </match:MatchModel>
> <attribute
> <leftElement
> <rightElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> only get the resulting object has either the name change OR the add, but
> never both. Which I get depends on whether I merge to the left or to
> the right.
> found what I think is the problem. The initial
> "TestContext 4") to the stillToFindFromModel1 List. The object is also
> added to remainingUnmatchedElements as well (pulled from
> does nothing because the unmatched object from stillToFindFromModel1 is
> an instance of TestContext (part of my model) and not an Match2Elements
> object.
> remainingUnmatchedElements does nothing, because the TestContext
> actually belongs to a different resource than the object referencing it.
> don't think that should affect unmatched objects.
> Sincerely,
> Stephen McCants
Re: [EMF Compare] 3 way content match is losing an add? [message #138733 is a reply to message #138711] Thu, 16 July 2009 03:49 Go to previous message
--------------000505070507020808000308
Hi Stephen,
I must admit I am quite lost as to what you're doing and what your
models look like (I am not fluent in xmi :p). You seem to have multiple
resources... inter-model references will only be properly matched if you
use MatchService#doResourceSetMatch(). That said, losing differences
seems like a bug to me. Can you reproduce this with the Generic engine?
If yes, could you raise a bugzilla with a use case that can be used to
reproduce this (I couldn't with UML/ecore class diagrams)?
Laurent Goubet
Obeo
Stephen McCants a
Re: [EMF Compare] 3 way content match is losing an add? [message #621141 is a reply to message #138694] Wed, 15 July 2009 19:40 Go to previous message
</matchedElements>
</match:MatchModel>
</subDiffElements>
</subDiffElements>
</subDiffElements>
</subDiffElements>
</ownedElements>
</diff:DiffModel>
--Stephen
> Hello,
> <leftElement
> <rightElement
> <originElement
> </matchedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </match:MatchModel>
> <attribute
> <leftElement
> <rightElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> the right.
> object.
> Sincerely,
> Stephen McCants
Re: [EMF Compare] 3 way content match is losing an add? [message #621143 is a reply to message #138711] Thu, 16 July 2009 03:49 Go to previous message
Hi Stephen,
Laurent Goubet
Obeo
Stephen McCants a
Previous Topic:[EMF Compare] 3 way content match is losing an add?
Next Topic:[EMF Tiger] Graphical Editor Support
Current Time: Sat Jul 19 16:12:37 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
