Home » Eclipse Projects » EGit / JGit » Team -> Import Project Set fails with "Invalid project description..."
Team -> Import Project Set fails with "Invalid project description..." [message #1386977] Mon, 23 June 2014 07:25 Go to next message
Hi!
When i use import->team->team project set to import a psf file, it reports
"Invalid project description overlaps the location of annother project ". The clone operation works fine. It seems that the import of the project fails. If i manually import the project via import -> projects from git -> local repo -> the cloned repo it works fine.
Also cloning a repo in the Git Perspective with an import of the projects works fine.
My Configuration: Eclipse Kepler SR1, eGit 3.2.0.201312181205
Is it maybe a problem, that the repo is cloned into the workspace directory?
Thank You
[Updated on: Mon, 23 June 2014 07:52] by Moderator
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1393069 is a reply to message #1386977] Thu, 03 July 2014 03:32 Go to previous messageGo to next message
Can you share the psf file ?
Can you retry with latest 3.5 version from http://download.eclipse.org/egit/updates-nightly ?
Cloning the repository into the workspace directory may affect performance but should work.
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1393940 is a reply to message #1386977] Fri, 04 July 2014 10:17 Go to previous messageGo to next message
i tried v3.4.1 and the nightly of 3.5. The same error occurs.
I've configured the workspace_loc as directory for git repo in preferences -> team -> git
The psf file is attached. It has 2 git projects and a few CVS projects. The import of the CVS projects works fine.
After importing the project set, there is a directory for the first git project inside the workspace dir but, not for the second one. The second git project isn't even cloned.
When importing the project these step are executeing in the following order:
1. Clone first git repo
2. Checkout and import CVS Projects
3. Try to import the first git Repo. This fails.
Following Error:
The following errors occurred while importing projects. Some projects may not be loaded.
OK
C:\Entwicklung\projekte\git\Provinzial-Service-Verzeichnis overlaps the location of another project: 'Provinzial-Service-Verzeichnis'
C:\Entwicklung\projekte\git is the workspace dir.
You say that cloning in the workspace may affect the performance. Whats your recommendation for the repository location, if we need the repository per workspace (Not a shared repo between different workspaces). If it should be outside the workspace, there is missing a configuration for the import project set, where to clone the repo (i thinkt it automatically clones in the workspace and atm there is no chance to change this).
Thanks for your help so far!
[Updated on: Fri, 04 July 2014 10:22] by Moderator
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1397303 is a reply to message #1393940] Wed, 09 July 2014 10:24 Go to previous messageGo to next message
Are v02_00_00_03 etc. tags or branches ?
If you want them in the workspace put them into a folder below the workspace.
If you import a team project set EGit does this automatically.
You'll see performance degradation if you have projects located directly under the workspace,
multi-select a couple of them and create a git repository for them using the Team > Share with Git
wizard and check the option "Create repository in parent folder of project" the new .git folder
is at the root of the workspace. The performance problems are caused by the fact that the
.metadata folder containing the workspace's metadata is then located in the working tree of this
repository. Hence git will also scan the folder to detect changes. Since this folder is a huge tree
this can degrade performance.
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1397320 is a reply to message #1386977] Wed, 09 July 2014 10:48 Go to previous messageGo to next message
v02_00_00_03 are Tags (old cvs style...)
So this layout:
workspace
-> .git
-> Project1
-> Project2
is not good, but this:
workspace
-> Project1
----> .git
-> Project2
----> .git
is ok? If so, we are fine, because we are using the second way. And as you said the project set import works this way too.
Back to the problem with the Import:
I've discovered that the import fails if the <projectDescription><name> in the .project file doesn't match the actual name of the project. if they are both equal, everything works fine.
Nevertheless it's quite interesting, that the import project set fails but the "import projects" on the same git repo in the git perspective is working fine.
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1397510 is a reply to message #1397320] Wed, 09 July 2014 16:55 Go to previous messageGo to next message
Matthias Niehoff wrote on Wed, 09 July 2014 10:48
So this layout:
workspace
-> .git
-> Project1
-> Project2
workspace
-> Project1
----> .git
-> Project2
----> .git
With this layout you cannot add additional eclipse projects if this need comes up. To avoid this
you can use the layout which EGit uses when you import a psf file of a repository containing multiple projects:
workspace
-> foo
---> .git
-----> Project1
-----> Project2
Please file a bug for this problem
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1397511 is a reply to message #1397510] Wed, 09 July 2014 16:56 Go to previous messageGo to next message
I meant this layout:
workspace
-> foo
---> .git
---> Project1
---> Project2
Re: Team -> Import Project Set fails with "Invalid project description..." [message #1397825 is a reply to message #1386977] Thu, 10 July 2014 03:57 Go to previous message
Thanks for your help. I created bug 439317 and also voted for Bug 395143.
Previous Topic:Doubt about git repositories inside Eclipse project folders
Next Topic:Rebase interactive reordering commits: Wrong repository state: SAFE
Current Time: Sat Jul 19 17:27:11 EDT 2025
Powered by FUDForum. Page generated in 0.06888 seconds
