Home » Eclipse Projects » Eclipse Scout » Scout Tests with Timeout(Testing)
Scout Tests with Timeout [message #1386918] Mon, 23 June 2014 02:03 Go to next message
I am wondering whether it is possible to run Scout tests and to terminate them automatically if the are still running after a certain timeout.
I am using server tests with the ScoutServerTestRunner.
The JUnit Annotation @Test can be used with the parameter "timeout":
@Test(timeout = 100)
public void test() {}
However, the timeout declaration causes JUnit to run the test in a new process and consequently the code in the testcase is not running in a Scout transaction.
Starting a ServerJob with ServerJob.getCurrentSession() does not work either because getCurrentSession() returns null.
Is there a way to run such tests in a transaction?
Thank you.
Rainer
Re: Scout Tests with Timeout [message #1395719 is a reply to message #1386918] Mon, 07 July 2014 05:44 Go to previous message
I found a solution to run such tests:
The testing logic must be wrapped within a ServerJob.
As ServerJob.getCurrentSession() returns null, an own server session must be instantiated.
  @Test(timeout = 5000)
  public void testTimeout() throws Throwable {
    TestJob job = new TestJob() {
      protected void executeTest() {
        //Testing logic with assertions
    job.runAndCheckAssertions();
  abstract class TestJob extends ServerJob {
    private Throwable m_throwable;
    public TestJob() {
      super("Test", new CoreProductServerTestSession());
      m_throwable = null;
    protected IStatus runTransaction(IProgressMonitor monitor) throws Exception {
      try {
        executeTest();
      catch (Throwable t) {
        m_throwable = t;
      return Status.OK_STATUS;
    public void runAndCheckAssertions() throws Throwable {
      runNow(null);
      if (m_throwable != null) {
        throw m_throwable;
    protected abstract void executeTest();
CoreProductServerTestSession is a class implementing IServerSession.
[Updated on: Mon, 07 July 2014 08:13] by Moderator
Previous Topic:HTTP 500 error
Next Topic:Luna technologie RAP Filechooser problem
Current Time: Sun Jul 20 14:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.29314 seconds
