Nebula GridViewerTable Column alignment. [message #1386529] |
Wed, 18 June 2014 02:46  |
Hi All,
I am using the Nebula GridViewerTable in my plugin.I am unable to align the image to the center of the column using the following code.Please help with this issue.
protected void measure(Event event, Object element) {
protected void paint(Event event, Object element) {
Image img = getImage(element);
if (img != null) {
Rectangle bounds = ((TableItem) event.item).getBounds(event.index);
Rectangle imgBounds = img.getBounds();
bounds.width /= 2;
bounds.width -= imgBounds.width / 2;
bounds.height /= 2;
bounds.height -= imgBounds.height / 2;
int x = bounds.width > 0 ? bounds.x + bounds.width : bounds.x;
int y = bounds.height > 0 ? bounds.y + bounds.height : bounds.y;
event.gc.drawImage(img, x, y);
Veeresh Hipparagi
Re: Nebula GridViewerTable Column alignment. [message #1386908 is a reply to message #1386907] |
Sun, 22 June 2014 21:20  |
The solution is to set a custom CellRenderer on the Column, like this
myImageColumn.setCellRenderer(new DefaultCellRenderer() {
public void paint(GC gc, Object value) {
GridItem item = (GridItem) value;
Image img = getMyImage(item.getData());
if (img != null) {
Rectangle bounds = getBounds();
bounds.width /= 2;
bounds.height /= 2;
FUDForum. Page generated in 0.03518 seconds
