Home » Eclipse Projects » EGit / JGit » checkout with symlinks(I can't run git checkout when there are symlinks)
checkout with symlinks [message #1386634] Wed, 18 June 2014 18:38 Go to next message
Hi all. When I run the following command with sym links in my directory,
git.checkout().setName(branchName).call();
the call fails, and I get the error
Exception in thread "main" org.eclipse.jgit.api.errors.CheckoutConflictException: Checkout conflict with files:
However when I run the same thing from the command line everything succeeds. Is there a work around for this?
Re: checkout with symlinks [message #1386734 is a reply to message #1386634] Thu, 19 June 2014 20:14 Go to previous messageGo to next message
Did you install the org.eclipse.jgit.java7 bundle ?
Re: checkout with symlinks [message #1386735 is a reply to message #1386734] Thu, 19 June 2014 20:16 Go to previous messageGo to next message
Did you check which pathes the checkout conflict is raised for ?
Call CheckoutConflictException.getConflictingPaths() for that.
Is any of the symlinks in this list ?
Re: checkout with symlinks [message #1386767 is a reply to message #1386634] Fri, 20 June 2014 06:26 Go to previous messageGo to next message
Evan Thomas skrev 2014-06-19 00.38:
Is that an empty list?
Which version are you using. 3.4.0 contains some fixes for conflict handling.
-- robin
Re: checkout with symlinks [message #1386812 is a reply to message #1386767] Fri, 20 June 2014 13:48 Go to previous messageGo to next message
I have a directory 'dir' with files 'dir/file1' and 'dir/file2'. I have a symlink 'link -> dir'. I called CheckoutConflictException.getConflictingPaths(), the exception is raised for 'link/file1' and 'link/file2' but not for 'link' (if I remove file1 and file 2 the exception disappears).
I'm on version 3.3.2, i'll upgrade and see if that fixes the problem
Re: checkout with symlinks [message #1386815 is a reply to message #1386812] Fri, 20 June 2014 13:54 Go to previous messageGo to next message
Upgrading to 3.4.0 did not fix the issue
Re: checkout with symlinks [message #1386823 is a reply to message #1386815] Fri, 20 June 2014 18:11 Go to previous messageGo to next message
Evan Thomas skrev 2014-06-20 19.54:
Can you create a small not-working repo, zip it and it's working directory (when checkout fails) and post it bugs.eclipse.org?
A single commit should be enough, I think.
-- robin
Re: checkout with symlinks [message #1386863 is a reply to message #1386734] Sat, 21 June 2014 16:50 Go to previous message
Matthias Sohn skrev 2014-06-20 02.14:
Apparently not
-- robin
Previous Topic:EGit Commit Performance depends on Files in Workspace
Next Topic:Check Git connection
Current Time: Sun Jul 20 18:59:19 EDT 2025
Powered by FUDForum. Page generated in 0.06184 seconds
