java.lang.Override is not on the classpath [message #1386780] |
Fri, 20 June 2014 08:05  |
currently I try to migrate my stuff to IncQuery 0.8. As already
mentioned in other discussions I use the generic IncQuery API to load
patterns and to execute queries. When my tool is to be used then some
pattern resources are intended to be loaded. The loading is done in the
normal EMF way:
URI uri = URI.createPlatformPluginURI(bundle.getSymbolicName() + "/" +
patternResourcePathInBundle, true);
ResourceSet rs = new ResourceSetImpl();
resource = rs.getResource(uri, true);
EObject model = resource.getContents().get(0);
if(model instanceof PatternModel){
// something with the loaded pattern
The problem is that I get the following exceptions when the contents is
tried to be loaded (getContents().get(0)). The resource itself is not
null and inspecting the contents while debugging suggests that it was
correctly loaded and contains patterns.
!MESSAGE Error initializing JvmElement
!STACK 0
java.lang.IllegalArgumentException: The type java.lang.Override is not
on the classpath.
at
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toAnnotation(JvmTypesBuilder.java:979)
at
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toAnnotation(JvmTypesBuilder.java:958)
at
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toAnnotation(JvmTypesBuilder.java:928)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternMatchProcessorClassInferrer$3.apply(PatternMatchProcessorClassInferrer.java:108)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternMatchProcessorClassInferrer$3.apply(PatternMatchProcessorClassInferrer.java:1)
at
org.eclipse.incquery.patternlanguage.emf.util.EMFJvmTypesBuilder.initializeSafely(EMFJvmTypesBuilder.java:103)
at
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toMethod(JvmTypesBuilder.java:622)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternMatchProcessorClassInferrer.inferProcessorClassMethods(PatternMatchProcessorClassInferrer.java:141)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternMatchProcessorClassInferrer.inferProcessorClass(PatternMatchProcessorClassInferrer.java:71)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer.inferPublic(EMFPatternLanguageJvmModelInferrer.java:200)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer.infer(EMFPatternLanguageJvmModelInferrer.java:150)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer._infer(EMFPatternLanguageJvmModelInferrer.java:315)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer.infer(EMFPatternLanguageJvmModelInferrer.java:337)
at
org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:302)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternJvmModelAssociator.installDerivedState(EMFPatternJvmModelAssociator.java:46)
at
org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:145)
at
org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:130)
and
java.lang.NullPointerException: type
at
org.eclipse.xtext.common.types.util.TypeReferences.createTypeRef(TypeReferences.java:98)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternGroupClassInferrer.inferSpecificationGetter(PatternGroupClassInferrer.java:238)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.PatternGroupClassInferrer.initializePatternGroup(PatternGroupClassInferrer.java:112)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer$8.apply(EMFPatternLanguageJvmModelInferrer.java:309)
at
org.eclipse.incquery.patternlanguage.emf.jvmmodel.EMFPatternLanguageJvmModelInferrer$8.apply(EMFPatternLanguageJvmModelInferrer.java:1)
at
org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:305)
at
at
at
I found out that the exceptions won't appear if I execute the following
before loading the resource (source code above):
new
EMFPatternLanguageStandaloneSetup().createInjectorAndDoEMFRegistration();
But, normally this should not be done when IncQuery tooling is loaded,
as can be seen here:
https://wiki.eclipse.org/EMFIncQuery/UserDocumentation/API/Advanced#Sample_code
And if I invoke the createInjectorAndDoEMFRegistration() method then I
get the following exceptions if I want to load a pattern model via the
Query Explorer with the play button:
!ENTRY org.eclipse.ui 4 0 2014-06-20 13:59:41.945
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException: type)
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.NullPointerException: type
at
at
at
at
at
at
at
at
at
at
org.eclipse.incquery.tooling.ui.queryexplorer.util.DisplayUtil.extractPatternModelFromResource(DisplayUtil.java:323)
at
org.eclipse.incquery.tooling.ui.queryexplorer.util.DisplayUtil.parseEPM(DisplayUtil.java:387)
at
org.eclipse.incquery.tooling.ui.queryexplorer.handlers.RuntimeMatcherRegistrator.registerPatternsFromPatternModel(RuntimeMatcherRegistrator.java:122)
at
org.eclipse.incquery.tooling.ui.queryexplorer.handlers.RuntimeMatcherRegistrator.run(RuntimeMatcherRegistrator.java:76)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
So the notice is right that createInjectorAndDoEMFRegistration() should
not be invoked when IncQuery tooling is loaded. But my problem remains.
How can I avoid the exceptions and how to get both working?
cheers,
Jan
FUDForum. Page generated in 0.24744 seconds
