Home » Eclipse Projects » Nebula » Nebula GridViewerTable Column alignment.(How to align the image to the center of the Column)
Nebula GridViewerTable Column alignment. [message #1386529] Wed, 18 June 2014 02:46 Go to next message
Hi All,
I am using the Nebula GridViewerTable in my plugin.I am unable to align the image to the center of the column using the following code.Please help with this issue.
protected void measure(Event event, Object element) {
protected void paint(Event event, Object element) {
Image img = getImage(element);
if (img != null) {
Rectangle bounds = ((TableItem) event.item).getBounds(event.index);
Rectangle imgBounds = img.getBounds();
bounds.width /= 2;
bounds.width -= imgBounds.width / 2;
bounds.height /= 2;
bounds.height -= imgBounds.height / 2;
int x = bounds.width > 0 ? bounds.x + bounds.width : bounds.x;
int y = bounds.height > 0 ? bounds.y + bounds.height : bounds.y;
event.gc.drawImage(img, x, y);
Veeresh Hipparagi
Re: Nebula GridViewerTable Column alignment. [message #1386907 is a reply to message #1386529] Sun, 22 June 2014 20:54 Go to previous messageGo to next message
According to this forum post http://www.eclipse.org/forums/index.php/t/17892/, the OwnerDrawLabelProvider concept is not supported in the Nebula Grid.
Re: Nebula GridViewerTable Column alignment. [message #1386908 is a reply to message #1386907] Sun, 22 June 2014 21:20 Go to previous message
The solution is to set a custom CellRenderer on the Column, like this
myImageColumn.setCellRenderer(new DefaultCellRenderer() {
            public void paint(GC gc, Object value) {
                GridItem item = (GridItem) value;
                Image img = getMyImage(item.getData());
                if (img != null) {
                    Rectangle bounds = getBounds();
                    bounds.width /= 2;
                    bounds.height /= 2;
Previous Topic:tool tip
Next Topic:Problems using CDateTimeCellEditor
Current Time: Sat Jul 19 12:32:48 EDT 2025
Powered by FUDForum. Page generated in 1.05938 seconds
