Home » Language IDEs » C / C++ IDE (CDT) » error: *** missing separator. Stop.
error: *** missing separator. Stop. [message #138610] Sun, 13 February 2005 00:02 Go to next message
Originally posted by: none.none.com
I tried updating to 2.1 CDT and now I really can't compile. I get the
error:
Help
Re: error: *** missing separator. Stop. [message #138620 is a reply to message #138610] Sun, 13 February 2005 00:13 Go to previous messageGo to next message
> error:
> Help
By the way the file does not have any leading spaces that I can see. It
looks like this:
# Automatically-generated file. Do not edit!
buffers.o \
dds.tab.o \
http.o \
interactive.o \
lex.dds.o \
main.o \
ocapi.o \
stack.o \
utility.o \
S_UPPER_SRCS += \
${addprefix $(ROOT)/build/, \
C_SRCS += \
S_SRCS += \
# Each subdirectory must supply rules for building sources it contributes
build/%.exe: $(ROOT)/build/%.o
@echo 'Building file: $<'
@echo gcc -L"D:\apps\dev\libcurl\curl-7.12.1\include"
-L"D:\apps\dev\libcurl\curl-7.12.1\lib\.libs"
-L"D:\apps\dev\libcurl\curl-7.12.1\lib" -o$@ $<
@gcc -L"D:\apps\dev\libcurl\curl-7.12.1\include"
@echo 'Finished building: $<'
@echo ' '
Re: error: *** missing separator. Stop. [message #138680 is a reply to message #138620] Sun, 13 February 2005 17:23 Go to previous message
Missing separator means that there is no tab at the beginning of a
command in a rule. You can't visually distinguish between tab and bunch
of spaces.
Example from your file:
You would have to edit the file, erase the spaces and type tab.
I realize that this is a generated file, so you may be able to fix the
problem by cleaning the project and rebuilding it again. I experienced
this problem on Mac OS X with CDT 2.1, but did not experience it on PC
where my CDT is still 2.0.
Possibly there is a bug open against it.
>> error:
>> Help
> looks like this:
> buffers.o \
> dds.tab.o \
> http.o \
> interactive.o \
> lex.dds.o \
> main.o \
> ocapi.o \
> stack.o \
> utility.o \
> S_UPPER_SRCS += \
> C_SRCS += \
> S_SRCS += \
> @echo ' '
Previous Topic:How to build native Mac Os X application
Next Topic:bogus subdir.mk file being generated
Current Time: Sat Jul 19 16:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.03364 seconds
