EMF Compare fails [message #138531] |
Tue, 14 July 2009 06:26  |
I'm trying to use EMF Compare programmaticly:
MatchModel match = MatchService.doMatch(referenceModel,
createdModel, Collections.<String, Object> emptyMap());
// Computing differences
DiffModel diff = DiffService.doDiff(match, false);
Both models are UML-models and they do exist (are not null).
Unfortunatly, the first line already throws a NullPointerException:
at
org.eclipse.emf.compare.match.engine.GenericMatchEngine.mode lMatch(GenericMatchEngine.java:356)
at
org.eclipse.emf.compare.match.service.MatchService.doMatch(M atchService.java:160)
at
alltests.ParentT2MAndM2TTestCase.testT2M(ParentT2MAndM2TTest Case.java:246)
at
org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at
org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at
org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at
org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at
org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:28)
at
org.junit.internal.runners.statements.RunAfters.evaluate(Run Afters.java:31)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:73)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java: 173)
at
at
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.junit.runners.Suite.runChild(Suite.java:115)
at org.junit.runners.Suite.runChild(Suite.java:23)
at
at
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:62)
at
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:23)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
What am I doint wrong?
Thank you
Re: EMF Compare fails [message #621133 is a reply to message #138531] |
Wed, 15 July 2009 04:10  |
--------------060502000508020604010806
Hi Usul,
Judging by the fact you're calling the comparison from unit tests and
the failure appears right off the bat, my best guess is that you're
calling MatchService.doMatch() on models that are not contained within
Resources. You can either
1) call MatchService.doContentMatch() instead (that would see all
inter-model differences as "Add" or "Remove" operations)
or
2) create Resources to contain your models and possibly create a
ResourceSet to contain these Resources and then call
MatchService.doMatch() on it.
Laurent Goubet
Obeo
Usul a
FUDForum. Page generated in 1.08394 seconds
