Home » Modeling » TMF (Xtext) » [Solved] How2 access top AST from Validator,Quickfix,Proposal(How to access top AST from the Validator and Quickfix.xtend)
[Solved] How2 access top AST from Validator,Quickfix,Proposal [message #1385914] Thu, 12 June 2014 05:05 Go to next message
I'm a newbie in XTEXT as well as in JAVA,
so I need some detailed example for a kickstart:
I customise Validator and Quickfix for an issue deep down in the AST levels.
There I need to access to an attribute of the topmost (Model) level.
Something like:
if (model.isSimple) ....
In the generator, I use
makeTheCif(resource.contents.head as Model)
What is the easiest way to do so in Validator, Proposal and QuickFix?
[Updated on: Tue, 17 June 2014 10:30] by Moderator
Re: How2 access top AST from Validator,Quickfix,Proposal [message #1386000 is a reply to message #1385914] Thu, 12 June 2014 16:21 Go to previous messageGo to next message
you can use EcoreUtil2.getContainerOfType(ctx, Model.class) to access the root type (i asume it is Model) from any eObject ctx
Re: How2 access top AST from Validator,Quickfix,Proposal [message #1386142 is a reply to message #1386000] Fri, 13 June 2014 11:23 Go to previous messageGo to next message
Hi Christian, thanks for the hint. Greetings from Frankfurt to Kiel, Uli
Re: How2 access top AST from Validator,Quickfix,Proposal [message #1386146 is a reply to message #1386142] Fri, 13 June 2014 11:31 Go to previous messageGo to next message
it is actually Stuttgart respectively Nuremberg
Re: How2 access top AST from Validator,Quickfix,Proposal [message #1386251 is a reply to message #1386146] Mon, 16 June 2014 03:49 Go to previous message
ok, here is the code that works for me:
Both are based on the EcoreUtil2.getRootContainer method
in the validator:
	def checkMergefileVariablesShouldNotBeEmpty(Mergefile mergefile) {
			val EObject myObject = mergefile
			var rootContainer = EcoreUtil2.getRootContainer(myObject) as Model
			System.out.println(rootContainer.name)
in the quickfix, I had to extend the arguments to include "element" to make it work:
	def addMergefileValues(Issue issue, IssueResolutionAcceptor acceptor) {
		acceptor.accept(issue, 'variables set empty', 'Generate variable set.', '')
		[ element, context |
			var rootContainer = EcoreUtil2.getRootContainer(element) as Model
			System.out.println("quickfix-calls: " + rootContainer.name)
[Updated on: Mon, 16 June 2014 03:50] by Moderator
Previous Topic:NPE in GlobalURIEditorOpener
Next Topic:NullPointer when generating parser
Current Time: Sun Jul 20 12:15:24 EDT 2025
Powered by FUDForum. Page generated in 0.45637 seconds
