Home » Eclipse Projects » Sirius » New representation types
New representation types [message #1385950] Thu, 12 June 2014 08:22 Go to next message
Is there a way to create new representation types (i.e. not diagram,
table or tree). I assume this at least needs a (meta-)model and a
rendererer/editor for an instance of the (meta-)model. Is there an
extension point for registering new ones, and perhaps also some abstract
base classes for implementing the actual renderers/editors? Or is the
current set somehow hard-coded into the framework.
Hallvard
Re: New representation types [message #1385957 is a reply to message #1385950] Thu, 12 June 2014 09:11 Go to previous messageGo to next message
Le 12/06/2014 14:22, Hallvard Trætteberg a écrit :
No, it is not hard-coded. This notion is named a dialect [1] & [2].
The extension point uses to define a new Dialect is
org.eclipse.sirius.dialect.
As starting point, you can have a look at:
* AbstractRepresentationDialectServices [3]
* or TreeDialect [4] as example, that probably is the simplest Dialect
> Hallvard
Laurent
[1] org.eclipse.sirius.business.api.dialect.Dialect
[2] Help/Sirius/Glossary/Dialect
[3]
org.eclipse.sirius.business.api.dialect.AbstractRepresentationDialectServices
[4] org.eclipse.sirius.tree.business.internal.dialect.TreeDialect
Re: New representation types [message #1386037 is a reply to message #1385957] Fri, 13 June 2014 03:01 Go to previous message
Laurent,
Great, thanks for the pointers!
Hallvard
>> Hi,
>> Hallvard
> Regards,
> Laurent
> [3]
Previous Topic:Fixed layout
Next Topic:Unable to create first entity in emtpy table
Current Time: Sun Jul 20 12:03:17 EDT 2025
Powered by FUDForum. Page generated in 0.03381 seconds
