Home » Modeling » TMF (Xtext) » proper way to enrich model
proper way to enrich model [message #1385797] Wed, 11 June 2014 05:29 Go to next message
I have a grammar that accepts something that looks like this:
entity A {
 int i = 1
 int j
entity B extends A {
 int j = 2
entity C extends B {
 int k = 3
When I generate code from 'entity C' it actually have 3 fields: i, j and k, and, the values are: 1, 2, 3 correspondingly.
However, the emf model only contain k
What is the 'proper' way of handling this?
- sure, it's easy to evaluate the values - but i want to do this only once
I can think of several solutions:
1) Effect the creation of the emf model somehow (how?) and manually add the missing i and j to C (and j to B) while xtext is creating the model
2) 'piggyback' the extra fields on the resource/emf model while in doGenerate (am i allowed to do that?)
3) Use cache to cache fields references and values once calculated/deduced
4) Create my own model (bahh!)
Option 4 - is my least favorite.
Option 3 - looks nicer, but I don't think it's elegant
Option 2 - I don't know if I'm allowed to do that at all?
Option 1 - Sounds promising, I think that a good starting point is this: xtextcasts.org/episodes/18-model-optimization
So, what is the 'proper' xtext way to do this? is there a proper way? Smile
Any comment will be warmly accepted Smile
Yoel.
Re: proper way to enrich model [message #1385807 is a reply to message #1385797] Wed, 11 June 2014 06:46 Go to previous messageGo to next message
what about simple traverse the model (ask entity for its parent, the parent for its attributes???)
Re: proper way to enrich model [message #1385808 is a reply to message #1385807] Wed, 11 June 2014 06:51 Go to previous messageGo to next message
P.S: you may create simple extensions (helper functions) in xtend that do all the collection
Re: proper way to enrich model [message #1385835 is a reply to message #1385808] Wed, 11 June 2014 10:14 Go to previous messageGo to next message
Hi Yoel,
in the book "Implementing Domain-Specific Languages with Xtext and Xtend" from Lorenzo Bettini
there is a chapter "Scope for inheritance and member visibility" where he gives on page 246 an example:
@Inject extension SmallJavaTypeProvider
def scope_SJMember(SJMemberSelection sel, EReference r) {
var parentScope = IScope::NULLSCOPE
val type = sel.receiver.typeFor
if (type == null || type.isPrimitive)
return parentScope
for (c : type.classHierarchy.reverseView) {
parentScope = Scopes::scopeFor(c.members, parentScope)
Scopes::scopeFor(type.members, parentScope)
Hope it helps, Uli
Re: proper way to enrich model [message #1385902 is a reply to message #1385835] Thu, 12 June 2014 04:20 Go to previous message
Christian:
Thank you for your reply. Yes, I'm traversing the model using extension methods. this covers some of my problem.
Uli:
Thank you very much, yes! your snippet is helping me with the scoping aspect
I will order Lorenzo's book, it seems like a very good book Smile
Consider the following example (a little more complex)
entity Doll {
 int height
 Cuteness cutenessLevel
 Color eyeColor
 Color hairColor
 Gender gender
Entity BlondDoll extends Doll {
 Color hairColor = Color.BLONDE
Entity VeryCuteDoll extends {
 Cuteness cutenessLevel = Cuteness.VERY_CUTE
Entity MaleDoll extends Doll {
 Gender gender = Gender.MALE
Entity VeryCuteBlondeDoll extends VeryCuteDoll, BlondDoll {
Entity DollHouse {
 MaleDoll veryCuteBlondeMaleDoll42 = new VeryCuteBlondeDoll(height=42)
When I evaluate 'veryCuteBlondeMaleDoll42' I have to find the assignment for all of its values (height, cutenessLevel, eyeColor, hairColor and gender)
they come from different places, some stem from weird inheritance (blond) some from C'tor (height) and some from the value type (male)
This example sheds some more light on the grammar and the correct phrases in it.
Furthermore, things in real world scenario are a little more complicated than this.
Finding the assignment for each value of Doll is not hard.
But it does take some time and effort. And when I have of large number of values which are referenced from pre-compiled parts I want to use that.
My question is how to 'store' the data once I found it, once I traced its origin?
Can I store data in the EMF? should I?
Perhaps cache is answer?
Thanks again, Yoel
p.s.
Perhaps I'm going on a limb here, but I'm new to Xtext. I presume that there is a standard approach that is best practice in compilation of structures of this sort - I could be all wrong :0)
[Updated on: Thu, 12 June 2014 07:22] by Moderator
Previous Topic:ScopeProvider with imported Xcore
Next Topic:Need to change the return type of a Terminal
Current Time: Sat Jul 19 13:29:47 EDT 2025
Powered by FUDForum. Page generated in 0.34073 seconds
