Home » Modeling » TMF (Xtext) » project java --> +/- java
project java --> +/- java [message #1385793] Wed, 11 June 2014 05:04 Go to next message
hello
I have a problem with a project...
I have a project that transforms a code in java code + / - java.
the project is executed through the application of eclipse (new configuration).
Now I have to submit this project to a web service. I can recall this application without having to use the newconfiguration eclipse?
and how is it spread?
Thank you.
mick
Re: project java --> +/- java [message #1385794 is a reply to message #1385793] Wed, 11 June 2014 05:10 Go to previous messageGo to next message
can you please give more information on how this releates to Xtext and what you are exactly doing
Re: project java --> +/- java [message #1385800 is a reply to message #1385794] Wed, 11 June 2014 05:47 Go to previous messageGo to next message
the project is built starting with the plugin xtext.
Once you have created the grammar and the artifact, you execute the project using Run As -> new configuration, then you open a new application eclipse. In the Java code editor is inserted and once saved file will be created programm.html (in the runtime-New_configuration) that will have its own output that we wish to format + / - java.
Now my part is to take this project (without changing any part) and insert it into a web service.
my problem is:
- When I'm on the web and insert the java code in recognizing text, how do I invoke the transform xtext application without writing code in Eclipse?
- Should refer to the entire project or can I export the application format .jar file and import it into the new project?
sorry if maybe I was not clear but they are just starting out with Xtext.
thanks
Re: project java --> +/- java [message #1385803 is a reply to message #1385800] Wed, 11 June 2014 06:17 Go to previous messageGo to next message
Do you use igenerator?
Re: project java --> +/- java [message #1385804 is a reply to message #1385803] Wed, 11 June 2014 06:31 Go to previous messageGo to next message
yes .. but I do not know if I'm wrong, what should I pass as input parameters to the method doGenerate? java code to input?
Re: project java --> +/- java [message #1385806 is a reply to message #1385804] Wed, 11 June 2014 06:45 Go to previous messageGo to next message
you can change the language workflow.
there is a GeneratorFragment. you can tell it to generate a java main.
once you have run this java main once
you can use the export -> java -> junnable jar file wizard to create a all in one jar.
Re: project java --> +/- java [message #1385809 is a reply to message #1385806] Wed, 11 June 2014 06:54 Go to previous messageGo to next message
but then once the file is exported in runnable jar,
I simply recall. jar file in my web service?
If you have a link to where this is an example of this kind?
thanks and sorry again
Re: project java --> +/- java [message #1385812 is a reply to message #1385809] Wed, 11 June 2014 07:29 Go to previous messageGo to next message
No example simply give it a try
Re: project java --> +/- java [message #1385819 is a reply to message #1385812] Wed, 11 June 2014 08:00 Go to previous messageGo to next message
P.S:
the main is of course only a starting point.
http://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
Re: project java --> +/- java [message #1385825 is a reply to message #1385819] Wed, 11 June 2014 08:31 Go to previous message
thanks
Previous Topic:xtext grammar import ATL metamodel
Next Topic:Antlr update breaks workflow
Current Time: Sat Jul 19 19:49:28 EDT 2025
Powered by FUDForum. Page generated in 0.47015 seconds
