Home » Modeling » EMF » [CDO] more detailed logs when CDOSession is null...
[CDO] more detailed logs when CDOSession is null... [message #1385547] Mon, 09 June 2014 05:09 Go to next message
Sometimes i have an error similar like this:
...my code...
when I debugging it, it is a problem with CDOSession, cdoSession is null...
Exist any possibility to launch more detailed logs for cdo, I want to know why cdosession is null...
regards
Arek
Re: [CDO] more detailed logs when CDOSession is null... [message #1385551 is a reply to message #1385547] Mon, 09 June 2014 05:57 Go to previous messageGo to next message
Am 09.06.2014 11:10, schrieb Arek Kowal:
> ..my code...
I quickly checked that nowhere in CDO's code we have a variable/field called "cdoSession". Our naming convention implies
"session". So it must be your own code, which you didn't include in the stack trace. So I can't possibly comment on it.
CDO uses Eclipse's tracing framework even in standalone runs. You can influence it either through the Tracing page in
your launch configs or via a .options file in your separate deployment.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] more detailed logs when CDOSession is null... [message #1385557 is a reply to message #1385551] Mon, 09 June 2014 07:06 Go to previous messageGo to next message
thank you, but I haven't information from cdo code in logs... it is surprising for me, you catch all exceptions in your code (without any stack trace or something like that Wink ) ?
my code:
cdoSession = STH.openSession();
public CDOSession openSession()
CDOSession session = configuration.openNet4jSession();
for (EPackage ePackage : getEPackages()) {
session.getPackageRegistry().putEPackage(ePackage);
return session;
private void init()
OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
IManagedContainer container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
CDONet4jUtil.prepareContainer(container);
container.activate();
IConnector connector = TCPUtil.getConnector(container, servedrAddress));
configuration = CDONet4jUtil.createNet4jSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName(repoName);
etc.
[Updated on: Mon, 09 June 2014 07:39] by Moderator
Re: [CDO] more detailed logs when CDOSession is null... [message #1385573 is a reply to message #1385557] Mon, 09 June 2014 11:33 Go to previous message
Am 09.06.2014 13:06, schrieb Arek Kowal:
Please read https://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F and add the following:
OMPlatform.INSTANCE.setDebugging(true);
Severe exceptions don't require that, though, as they're always logged and not just traced conditionally.
> it is surprising for me, you catch all exception in your code (without any stack trace or something like that ;) ) ?
That's totally new to me. Can you please point me to the code that swallows an exception?
> my code:
> return session;
> private void init()
> etc.
Where is the code that refers to this variable/field "cdoSession"?
Cheers
/Eike
Previous Topic:[CDO] Critical issues with CDO Workspaces
Next Topic:missing emf icons for product export
Current Time: Sat Jul 19 09:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.03292 seconds
