Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 2.3 RC1 Calendar widget inconsistent presentment via Links(RAP 2.3 RC1 Calendar widgets via Links will not consistently be presented; especially for 'No Start Date' and No End Date' scenarios)
RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1384365] Wed, 28 May 2014 16:43 Go to next message
This issue is separate from previously mentioned 'menu' issues.
New wrinkle for RAP 2.3 RC1: Presentment of Calendar widgets via links
Calendar widgets, via links, are inconsistently presented: sometimes not presented.
1) Calendar widget via link is presented repeatedly until a child editor is presented. Then, the link will no longer present the Calendar widget.
2) A temporary remediation or user workaround of this presentation issue is done by navigating to another editor (this case, same level) and then back to the problematic editor, BUT ONLY works for links in the form of an actual valid date/time.
i.e. the link is in the form of a date ex. 2014-05-28T:00:00:00
3) No currently known remediation or user workaround of presentation issue if the link to a Calendar widget is presented as 'No Start Date' or 'No End Date'. These are used to indicate just that: there is no start or end limit
Video attached in mp4 format: Tradescape_RAP_2.3_RC1_Issues.mp4
[Updated on: Thu, 29 May 2014 11:34] by Moderator
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1384898 is a reply to message #1384365] Mon, 02 June 2014 17:16 Go to previous messageGo to next message
Debbuging revealed that the Link widget's selection handler is not fired in all cases.
I could not find a Link example in the RAP demo, so it's unclear if the behavior would show there, too.
Can you please check your code for the Link widget. It has regressed from RAP 2.1 where it was working properly.
Thanks!
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1384923 is a reply to message #1384898] Tue, 03 June 2014 03:36 Go to previous messageGo to next message
here is a demo of Link widget (RAP 2.3 RC2) -
http://rap.eclipsesource.com/demo/stable/controls/#Link
There is a selection listener attached to the first link (Lorem ipsum
dolor sit amet).
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1384929 is a reply to message #1384898] Tue, 03 June 2014 03:56 Go to previous messageGo to next message
could you extract a small self-running snippet to reproduce the issue?
Does it work in older RAP versions? Please open a bugzilla and attach
the snippet there.
Ivan
Ivan Furnadjiev
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1385018 is a reply to message #1384929] Tue, 03 June 2014 12:42 Go to previous messageGo to next message
Ivan Furnadjiev wrote on Tue, 03 June 2014 00:56
the snippet there.
Ivan
Looks like someone else has the same problem and already created a
sample.
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1385020 is a reply to message #1385018] Tue, 03 June 2014 12:55 Go to previous messageGo to next message
Yes seems to be the same issue, It worked fine in 2.2.0, it stopped working when I switched to RAP 2.3.0 RC2, In my post I have update workbench demo to show the issue. It seems to be related to something wrong between links and editor in workbench.
Re: RAP 2.3 RC1 Calendar widget inconsistent presentment via Links [message #1385086 is a reply to message #1385020] Wed, 04 June 2014 05:27 Go to previous message
issue is fixed. The fix will be included in RAP 2.3 release.
Thanks for reporting,
Ivan
Ivan Furnadjiev
Previous Topic:Tomcat: External Log Configuration
Next Topic:How to dynamically fill a parameter to a popup menu item
Current Time: Sun Jul 20 10:32:45 EDT 2025
Powered by FUDForum. Page generated in 0.04426 seconds
