Completion proposal with multiple selected regions [message #1384706] |
Fri, 30 May 2014 11:05  |
for content assist I would like to implement context-sensitive (this prevents using templates.xml) templates with multiple selected regions. So far, I used a ConfigurableCompletionProposal in the following way:
var proposal = (createCompletionProposal("Template content", "Title", null, context)
as ConfigurableCompletionProposal)
proposal.setSelectionStart(proposal.replacementOffset + 1);
proposal.setSelectionLength(5);
proposal.setSimpleLinkedMode(context.viewer, '\t')
acceptor.accept(proposal)
However, this approach allows only for one selected region. How can I insert multiple selected regions?
All the best
Arne
Re: Completion proposal with multiple selected regions [message #1384742 is a reply to message #1384706] |
Sat, 31 May 2014 01:56  |
I found useful JFace classes to complete the task. This is my helper function to create a template proposal object that can be passed to an Xtext CompletionProposalAcceptor:
def TemplateProposal createTemplateProposal(
String template,
String name,
String description,
String contextTypeId,
String icon,
ContentAssistContext context
new TemplateProposal(
new Template(name, description, contextTypeId, template, true),
new DocumentTemplateContext(
new TemplateContextType(contextTypeId, name),
context.document,
context.offset,
context.replaceContextLength
context.replaceRegion,
loadImage(icon)
However, a problem remains: if I use the ${cursor} variable to specify the location for the caret after editing, the word "cursor" is actually printed in the content proposal (but otherwise ${cursor} works as intended). Any suggestions why this is the case?
Besides this last question, I would really like to see Xtext-specific abstractions for this task (so that you don't have to fiddle around with JFace classes that -- at least to me -- don't seem to integrate well with the Xtext abstractions (why should I know something about TemplateContextTypes?)).
Cheers
Arne
FUDForum. Page generated in 0.04117 seconds
