Eclipse will not open [message #1383898] |
Mon, 26 May 2014 21:23  |
Hello.
I've had a sudden problem with eclipse this morning. After finishing on my computer I closed down eclipse safely. When I went to open it this morning I got this error. Failed to load JNI shared library C:\Program Files (x86)\eclipse\jre\bin\client\jvm.dll
I fixed that by re downloading jre7.
Now I am not even getting the eclipse to popup with an error. I have set my environment variables and updated to the newest version of jdk and jre but still no luck.
I think this is the correct error log.
!SESSION 2013-12-14 00:50:03.154 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 00:51:50.770
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 00:51:50.773
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\Blake'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
!ENTRY org.eclipse.m2e.logback.appender 4 0 2013-12-14 01:03:44.130
!MESSAGE Failed to open search index.
!ENTRY org.eclipse.recommenders.rcp.utils 4 0 2013-12-14 02:36:41.687
!MESSAGE Failed to resolve selection in '=Calculator/src<{FahrenheitToCelsius.java' at offset 487
!STACK 1
Java Model Exception: Java Model Status [Index out of bounds]
at org.eclipse.jdt.internal.core.Openable.codeSelect(Openable.java:157)
at org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(CompilationUnit.java:377)
at org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(CompilationUnit.java:371)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionUtils.resolveJavaElementFromTypeRootInEditor(JavaSelectionUtils.java:147)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionUtils.resolveJavaElementFromEditor(JavaSelectionUtils.java:129)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionUtils.resolveJavaElementFromEditor(JavaSelectionUtils.java:112)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionProvider.handleSelectionInEditor(JavaSelectionProvider.java:108)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionProvider.access$1(JavaSelectionProvider.java:105)
at org.eclipse.recommenders.internal.rcp.providers.JavaSelectionProvider$1.run(JavaSelectionProvider.java:82)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
!SUBENTRY 1 org.eclipse.jdt.core 4 980 2013-12-14 02:36:41.690
!MESSAGE Index out of bounds
!SESSION 2013-12-14 11:09:09.329 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 11:10:18.778
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 11:10:18.807
!ENTRY org.eclipse.recommenders.rcp.utils 4 0 2013-12-14 11:39:12.996
!MESSAGE Failed to resolve selection in '=Calculator/src<{Differences.java' at offset 10
!STACK 1
!SUBENTRY 1 org.eclipse.jdt.core 4 980 2013-12-14 11:39:12.999
!SESSION 2013-12-14 12:55:13.194 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 12:55:30.355
!ENTRY org.eclipse.egit.ui 2 0 2013-12-14 12:55:30.371
!SESSION 2013-12-15 09:53:38.358 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 09:54:11.174
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 09:54:11.213
!SESSION 2013-12-15 10:39:04.993 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 10:39:12.889
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 10:39:12.890
!SESSION 2013-12-15 13:34:00.899 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 13:34:18.840
!ENTRY org.eclipse.egit.ui 2 0 2013-12-15 13:34:18.857
Any help would be appreciated.
Blake
Re: Eclipse will not open [message #1384027 is a reply to message #1383898] |
Tue, 27 May 2014 19:31  |
Not that I'm 100% about the error messages you've got, but where your JRE is and the eclipse.ini contents make it look like you're trying to launch a 64-bit Eclipse with a 32-bit JRE. They have to match, either both being 32-bit or 64-bit.
FUDForum. Page generated in 0.08780 seconds
