Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] NPE in PersistentStoreAdapter
[Teneo] NPE in PersistentStoreAdapter [message #138183] Wed, 08 July 2009 03:59 Go to next message
I'm using Teneo with Hibernate and just upgraded from Teneo 1.0.0 to Teneo
1.1.0. When testing my code I ran into a Problem when removing entries
from a map.
Stepping down with the debugger, I suspect Line 137 of
org.eclipse.emf.teneo.type.PersistentStoreAdapter to be wrong. Here is a
short excerpt:
case Notification.REMOVE:
if (list != null) {
if (notification.getPosition() != Notification.NO_INDEX) {
list.remove(notification.getPosition());
} else {
list.remove(replaceValue(notification.getOldValue(), eFeature));
if (map != null) {
final Map.Entry<?, ?> entry = (Map.Entry<?, ?>)
notification.getNewValue();
map.remove(entry.getKey());
break;
I suggest, that the line getting the Map.Entry should call
notification.getOldValue() instead of notification.getNewValue(). The new
value is null and thus causes a NullPointerException at map.remove().
Could somebody please verify this? Am I missing something?
Roland
Re: [Teneo] NPE in PersistentStoreAdapter [message #138190 is a reply to message #138183] Wed, 08 July 2009 04:13 Go to previous messageGo to next message
Hi Roland,
Afaics you are completely correct. Can you enter a bugzilla for this? Then I will pick this up in the next build which
will be today or tomorrow (after I solved this).
gr. Martin
Roland Brand wrote:
> Hi
> Teneo 1.1.0. When testing my code I ran into a Problem when removing
> entries from a map.
> short excerpt:
> if (list != null) {
> } else {
> if (map != null) {
> break;
> new value is null and thus causes a NullPointerException at map.remove().
> Roland
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] NPE in PersistentStoreAdapter [message #138197 is a reply to message #138190] Wed, 08 July 2009 04:47 Go to previous messageGo to next message
Hi Martin
I just filed bug 282795 for this. Thank you for your extremely fast answer.
Greets,
Roland
Re: [Teneo] NPE in PersistentStoreAdapter [message #138203 is a reply to message #138197] Wed, 08 July 2009 06:40 Go to previous message
Hi Roland,
And to add to the very-fast-feeling. I did a build 5 minutes ago which contains a change for this:
http://www.eclipse.org/modeling/emf/downloads/?project=teneo &showAll=1&hlbuild=M200907080536#M200907080536
I backported this very-small fix to 1.0.4 which I will build later in the afternoon.
btw, support for Teneo is given on the main EMF newsgroup which I added as cc.
gr. Martin
Roland Brand wrote:
> Hi Martin
> Greets,
> Roland
The Netherlands
Re: [Teneo] NPE in PersistentStoreAdapter [message #621101 is a reply to message #138183] Wed, 08 July 2009 04:13 Go to previous message
Hi Roland,
gr. Martin
Roland Brand wrote:
> Hi
> entries from a map.
> short excerpt:
> if (list != null) {
> } else {
> if (map != null) {
> break;
> Roland
The Netherlands
Re: [Teneo] NPE in PersistentStoreAdapter [message #621102 is a reply to message #138190] Wed, 08 July 2009 04:47 Go to previous message
Hi Martin
Greets,
Roland
Re: [Teneo] NPE in PersistentStoreAdapter [message #621103 is a reply to message #138197] Wed, 08 July 2009 06:40 Go to previous message
Hi Roland,
gr. Martin
Roland Brand wrote:
> Hi Martin
> Greets,
> Roland
The Netherlands
Previous Topic:[Teneo] NPE in PersistentStoreAdapter
Next Topic:[EMF Compare] Conflicting should be true, but is false
Current Time: Sun Jul 20 03:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.68588 seconds
