Home » Eclipse Projects » GEF » scrollablethumbnail with zoom
scrollablethumbnail with zoom [message #137715] Thu, 10 June 2004 23:55 Go to next message
Hi, I am using the scrollablethumbnail and scrollPane with zoom support.
I notice when i zoom out the scrollPane, the thumbnail will follow the
scale and scale itself down as well.
Is there a way to set the figure inside the scrollablethumbnail to a fixed
size, not matter what's the scollPane's zoom rate is?
Re: scrollablethumbnail with zoom [message #137851 is a reply to message #137715] Fri, 11 June 2004 14:48 Go to previous messageGo to next message
You are probably asking the ScalableFreeformLayeredPane from your graphical
viewer to paint on the thumbnail as well. Paint just the printable layers
(or go far enough down the figure hierarchy that you omit the
ScalableFreeformLayeredPane) and you should be good.
"Allen Wong" <ac4wong@uwaterloo.ca> wrote in message
news:cabafj$v3f$1@eclipse.org...
Re: scrollablethumbnail with zoom [message #137894 is a reply to message #137851] Sat, 12 June 2004 00:06 Go to previous messageGo to next message
I think I did just that. Here is my setup:
In my main view:
Eclipse View (ve.accessPlan)->canvas->lws->scrollPane
(scroll)->scalablePane->Figure (container)->a bunch of figures
protected Figure createThumbnail() { ScrollableThumbnail thumbnail =
new ScrollableThumbnail(scroll
.getViewport());
thumbnail.setSource(container);
return thumbnail;
then i create my scrollableThumbnailView by:
another eclipse view -> canvas->LWS->scrollableThumbnail->Figure(container)
public void createPartControl(Composite parent) {
VEGraphView vp = (VEGraphView) this.getSite().getWorkbenchWindow()
.getActivePage().findView("ve.accessPlan");
overview = new Canvas(parent, SWT.NULL);
LightweightSystem overviewLWS = new LightweightSystem(overview);
overviewLWS.setContents(vp.createThumbnail());
I thought the source of my scrollableThumbnail (container) is not scalable,
but apparently it is.
I have taken two screenshots. Ideally I would like to have the size of my
figures inside the thumbnail view always fixed as the one in
largeOverview.jpg.
http://www.home.mycybernet.net/~acwong/smallOverview.JPG
http://www.home.mycybernet.net/~acwong/largeOverview.JPG
Re: scrollablethumbnail with zoom [message #138013 is a reply to message #137894] Mon, 14 June 2004 13:34 Go to previous messageGo to next message
This is because when you zoom out such that the primary layer is smaller
than the viewable area, it gets
stretched to take up all available space.
news:cadvg0$mf6$1@eclipse.org...
> In my main view:
> .getViewport());
> return thumbnail;
scalable,
> largeOverview.jpg.
graphical
layers
support.
fixed
Re: scrollablethumbnail with zoom [message #138160 is a reply to message #138013] Tue, 15 June 2004 10:51 Go to previous messageGo to next message
Thanks for your reply. So I think this is a intended behaviour. Now my
question is why do you guys make the ScrollableThumbnail a final class?
The reason I say that is because I have come up with a hack to the
thumbnail class to do what I want (the size of the thumbnail figure is
fixed). Ideally I would extends ScrollableThumbnail and override that
method with my hack, however since the class is final, I would have to
extend Thumbnail and write my own code for the scrollable part. That sucks
because the ScrollableThumnail is doing exactly what i want, and if not
for the licensing issue, i would just do a copy and paste and force it to
extend my "hacked" thumbnail class.
You guys probably have a valid reason for making the class final, I am
just curious to know why. :)
cheers
> > In my main view:
> > .getViewport());
> > return thumbnail;
> scalable,
> > largeOverview.jpg.
> graphical
> layers
> support.
> fixed
Re: scrollablethumbnail with zoom [message #138306 is a reply to message #138160] Tue, 15 June 2004 15:42 Go to previous message
We did this so we could change the class however we see fit. I suppose the
other way to do this is to just put a warning in the javadoc stating that
the class should not be subclassed.
Open a bugzilla.
> cheers
> > > In my main view:
thumbnail =
> > > .getViewport());
> > > return thumbnail;
> > scalable,
my
> > > largeOverview.jpg.
> > graphical
> > layers
> > support.
the
a
> > fixed
Previous Topic:toolBar
Next Topic:Dificulty with using ButtonBorder
Current Time: Sat Jul 19 23:48:55 EDT 2025
Powered by FUDForum. Page generated in 0.04184 seconds
