Home » Modeling » M2T (model-to-text transformation) » Generate UUID(Wondering if Acceleo has any functions for generating UUIDs)
Generate UUID [message #1375247] Thu, 22 May 2014 20:41 Go to next message
I'm generating a dataset to go into a MySQL database.
The tables I'm adding to use UUIDs (generated with the MySQL UUID function) for foreign key relationships.
I can't seem to find any existing functions within Acceleo to generate some kind of UUID (or more likely an expected-to-be-universally-unique ID). In JET2 I would probably use something like <f:uuid>.
Does Acceleo have an equivalent to JET2s <f:uuid> tag?
Re: Generate UUID [message #1386424 is a reply to message #1375247] Tue, 17 June 2014 09:12 Go to previous message
i'm not sure if this helps you. I guess Acceleo can't create UUIDs. But you can use the Ecore function "org.eclipse.emf.ecore.util.EcoreUtil". This is a Java function, that you can call in Acceleo (http://www.obeonetwork.com/page/the-acceleo-queries).
KR,
Daniel
Previous Topic:[Acceleo] unresolved proxy
Next Topic:[MWE] UML 2.4.0 to 2.5.0 mapping not supported?
Current Time: Sat Jul 19 15:09:43 EDT 2025
Powered by FUDForum. Page generated in 0.02621 seconds
