Home » Archived » Test and Performance Tools Platform (TPTP) » run two test cases together
run two test cases together [message #137444] Fri, 24 October 2008 08:31 Go to next message
can anyone tell me how to run two test cases together which is created by
tptp automated gui test..i m using tptp 4.4.0.2.
Re: run two test cases together [message #137455 is a reply to message #137444] Fri, 24 October 2008 09:39 Go to previous messageGo to next message
Hi Asha,
You can in the test editor add the two test cases in the behavior tab to
have them run under the same test session.
Eugene
"Asha " <asha@readiminds.com> wrote in message
news:bf747cce572f5373677d61ad69f32e83$1@www.eclipse.org...
Re: run two test cases together [message #137547 is a reply to message #137455] Mon, 27 October 2008 03:30 Go to previous messageGo to next message
Eugene Chan wrote:
> Hi Asha,
> Eugene
thanks for ur reply..can u explain it in detail..coz i didn't understand
the whole thing.i already have tried by adding test cases in behavior
tab.but while running using run dialog..it automatically closes the
eclipse..
Re: run two test cases together [message #137569 is a reply to message #137547] Mon, 27 October 2008 07:21 Go to previous messageGo to next message
Hi Asha,
In TPTP, test suites are modeled as test cases and behaviours. Test
cases are the individual test steps to exercise/evaluate the application
under test. The test behaviour is which test cases (from either this test
suite or other test suites) and other test suites should be executed for
this test suite. You can also model behaviours are a sequential set of test
invocations or create loops of test invocations or other loops.
Unfortunately, two AGR test cases cannot be executed in parallel or
asynchronously.
Paul
news:74eac83a181ce5d40fa3450c6fc7ca2b$1@www.eclipse.org...
> Eugene Chan wrote:
>> Hi Asha,
>> Eugene
>>> by tptp automated gui test..i m using tptp 4.4.0.2.
> eclipse..
Re: run two test cases together [message #137691 is a reply to message #137569] Thu, 30 October 2008 02:57 Go to previous messageGo to next message
Helli paul,
I did that whatever you suggested.let me clear my doubt. i've
created two test cases under same test suite.and i want one master test
case in which i can call two test cases which is creates before, and when
we run the master test case then both the test cases will run one after
other.
can we create such type of master test cases? if yes then
how?plz reply soon.
Paul Slauenwhite wrote:
> Hi Asha,
> asynchronously.
> Paul
>> Eugene Chan wrote:
>>> Hi Asha,
>>> Eugene
>> eclipse..
Re: run two test cases together [message #137714 is a reply to message #137691] Thu, 30 October 2008 06:30 Go to previous messageGo to next message
Hi Ash,
Yes. In the Behaviour tab of your test suite, add an invocation for
each of the test cases (in the order you want) and run the test suite.
Paul
news:b8b0e50e53fd7dc937e7282d4fc93fcb$1@www.eclipse.org...
> Helli paul,
> other.
> how?plz reply soon.
>> Hi Asha,
>> test suite or other test suites) and other test suites should be executed
>> for this test suite. You can also model behaviours are a sequential set
>> of test invocations or create loops of test invocations or other loops.
>> asynchronously.
>> Paul
>>> Eugene Chan wrote:
>>>> Hi Asha,
>>>> to have them run under the same test session.
>>>> Eugene
>>> eclipse..
Re: run two test cases together [message #137738 is a reply to message #137714] Thu, 30 October 2008 06:56 Go to previous messageGo to next message
That i know..but how to run this?in quick mode or in standard mode..
> Hi Ash,
> Paul
>> Helli paul,
>> other.
>> how?plz reply soon.
>>> Hi Asha,
>>> asynchronously.
>>> Paul
>>>> Eugene Chan wrote:
>>>>> Hi Asha,
>>>>> Eugene
>>>> eclipse..
Re: run two test cases together [message #137774 is a reply to message #137738] Thu, 30 October 2008 09:18 Go to previous message
Standard mode.
news:11373fc4497cd41d7a2a538f0655b23d$1@www.eclipse.org...
> Hi, That i know..but how to run this?in quick mode or in standard mode..
>> Hi Ash,
>> Paul
>>> Helli paul,
>>> when we run the master test case then both the test cases will run one
>>> after other.
>>> how?plz reply soon.
>>>> Hi Asha,
>>>> Test cases are the individual test steps to exercise/evaluate the
>>>> application under test. The test behaviour is which test cases (from
>>>> either this test suite or other test suites) and other test suites
>>>> should be executed for this test suite. You can also model behaviours
>>>> are a sequential set of test invocations or create loops of test
>>>> asynchronously.
>>>> Paul
>>>>> Eugene Chan wrote:
>>>>>> Hi Asha,
>>>>>> Eugene
>>>>>>> created by tptp automated gui test..i m using tptp 4.4.0.2.
>>>>> understand the whole thing.i already have tried by adding test cases
>>>>> in behavior tab.but while running using run dialog..it automatically
>>>>> closes the eclipse..
Previous Topic:Workspace issue during testing.
Next Topic:problem with installing the agent controlller
Current Time: Sat Jul 19 17:42:32 EDT 2025
Powered by FUDForum. Page generated in 0.04261 seconds
