1.1.2 build issue - needs missing product.home var ? [message #1358179] |
Thu, 15 May 2014 17:41  |
My 1.1.2 Stardust build from source fails on the first build step. In contrast, previous 1.1.0 build step finished successfully back in February 2014.
As usual
created a new build directory
ran git clone ... -b I_4_3
ran git checkout for 1.1.2.20140219_0356-R
created private.properties and changed settings.xml.
First build step for 1.1.2 generates however below error:
build step used:
mvn install -f product/components-pom.xml -P stardust-build -Dbuild.tools.home=${STARDUST_TOOLS} -s ${STARDUST_TOOLS}/conf/m2/settings.xml
Error encountered:
[INFO] Total time: 1:55.946s
[INFO] Finished at: Wed May 14 14:36:45 MDT 2014
[INFO] Final Memory: 97M/234M
[INFO] ------------------------------------------------------------------------
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project jcr-vfs: Error loading
property file '/home/gudrunk/build/stardust/components/jcr-vfs/${product.home}/product-parent/src/main/filters/product.properties' -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
Tried following fix to build step command - seems to work but build step fails nevertheless at some point later. So at this point I am unclear if above fix was correct and if yes what will fix errors encountered below. Increased memory settings
for JAVA_OPTS and MAVEN_OPTS.
Changed build step - includes product.home
mvn install -f product/components-pom.xml -P stardust-build -Dbuild.tools.home=${STARDUST_TOOLS} -Dproduct.home=/home/gudrunk/build/stardust/product -s ${STARDUST_TOOLS}/conf/m2/settings.xml
14:06:46 ERROR [main ] ruct.sxml.DocumentBuilder - Unsupported StAX event type: 5
original document: <?xml version='1.0' encoding='UTF-8'?><structureddataroot xmlns:structureddata="uri:ag.carnot.structur
14:07:03 WARN [main ] DefaultPropertiesProvider - Property bundle 'carnot.properties' not found. Current classloader = sun.misc.Launcher$AppClassLoader@12360be0
Running job '2.1.0' against item 'Model' with version '2.0.0'.
Upgrade to version 2.1.0 done.
Running job '2.2.0' against item 'Model' with version '2.1.0'.
Upgrade to version 2.2.0 done.
14:07:04 WARN [main ] patibility.el.Interpreter - Deprecated comparison symbol used: '=>'. Correct symbol is: '>='.
Tests run: 253, Failures: 0, Errors: 14, Skipped: 6, Time elapsed: 21.215 sec <<< FAILURE! - in org.eclipse.stardust.engine.SanityTestSuite
testConcurrentModificationViaSet(org.eclipse.stardust.common.config.GlobalParametersTest) Time elapsed: 0.687 sec <<< ERROR!
java.lang.OutOfMemoryError: unable to create new native thread
at java.lang.Thread.start0(Native Method)
at java.lang.Thread.start(Thread.java:640)
at java.util.concurrent.ThreadPoolExecutor.addThread(ThreadPoolExecutor.java:681)
Any help much appreciated
Gudrun
[Updated on: Thu, 15 May 2014 22:56] by Moderator
Re: 1.1.2 build issue - needs missing product.home var ? [message #1373863 is a reply to message #1358179] |
Thu, 22 May 2014 07:01  |
sorry that you have build issues. As you may have noticed we have converted mostly all projects to native Maven projects. Unfortunately a lot of changes was needed to get the build working and we must introduce some new properties like product.home. Of course, we will update the Stardust WIKI as soon as we have finished the Maven migration task.
To fix your build issues it is sufficient to pass the -Dproduct.home=<root-stardust-checkout>/product parameter or in your case: -Dproduct.home=${STARDUST_TOOLS}/../product. This assumes that you have cloned the product Git repository besides of the build.tools clone. With the Maven Migration the test cases are automatically executed. To avoid this you can also pass the maven-surefire-plugin related Parameter -DskipTests=true
Sven
FUDForum. Page generated in 0.04003 seconds
