Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and org.eclipse.ui.services-Extension-Point
RAP and org.eclipse.ui.services-Extension-Point [message #137269] Mon, 22 June 2009 06:58 Go to next message
I'm on the way to port an RCP-Framework to work with RAP and have been
hitting a problem and I'm not sure if my understanding of the
IWorkbench#getService() and it's extension point is wrong.
Looking at the code it looks like WorkbenchServiceRegistry.getRegistry()
is the problem because it uses a static-Variable to remember the created
registry hence it not recreated for every RAP-workbench but is a global
Singleton :-)
So is this done by intenion?
Tom
Re: RAP and org.eclipse.ui.services-Extension-Point [message #137306 is a reply to message #137269] Mon, 22 June 2009 09:05 Go to previous messageGo to next message
Tom Schindl wrote:
> Singleton :-)
This was done by intention (ignoring possible multi-threading
issues) under the assumption that the service extensions do not
change at runtime.
What problems does that cause in your case?
> Tom
Re: RAP and org.eclipse.ui.services-Extension-Point [message #137329 is a reply to message #137306] Mon, 22 June 2009 09:43 Go to previous message
I think I now found the problem. The factory contributed was caching the
Service-Instance itself and because the WorkbenchServiceRegistry cached
the Factory it returned the same instance all the time instead of a new
instance / workbench.
Because I've not written the original code I'm not sure why this has
been done because it is not necessary to cache the instance in the
factory anyways glad to I have found the problem.
Tom
Rüdiger Herrmann schrieb:
> Tom Schindl wrote:
>> Hi,
>> Singleton :-)
> This was done by intention (ignoring possible multi-threading issues)
> under the assumption that the service extensions do not change at runtime.
>> Tom
Previous Topic:How to use the plugin mechanism with RAP?
Next Topic:Org.eclipse.ui.editorss is not available, and how to set curvy tab?
Current Time: Sun Jul 20 07:20:11 EDT 2025
Powered by FUDForum. Page generated in 0.03920 seconds
