Home » Language IDEs » ServerTools (WTP) » What are the targetIDs of WST editors?
What are the targetIDs of WST editors? [message #136778] Tue, 06 September 2005 10:53 Go to next message
Originally posted by: agilbert.invalidemail.com
I'd like to extend the popupMenus of the WST 0.7 editors (mainly html/xml
JSP editors). What are the targetIDs of those editors?
Alain Gilbert
Re: What are the targetIDs of WST editors? [message #137211 is a reply to message #136778] Wed, 07 September 2005 22:15 Go to previous messageGo to next message
On Tue, 06 Sep 2005 10:53:31 -0400, Alain Gilbert <agilbert@invalidemail=
Wow, finally a question we actually have some documentation for! :)
See
Editor related IDs
in
http://www.eclipse.org/webtools/wst/components/sse/overview. html
In brief,
To contribute, a "target id" of some kind is needed. For Structured Text=
editors, the target id is generated based on the content type in the ed=
itor, type of editor, place to contribute. The target id looks like: >co=
ntent type<.>editor type keyword<.>place to contribute keyword<
[... such as ... ] To contribute to *xml source editor's popup menu*, us=
e target id "org.eclipse.core.runtime.xml.source.EditorContext
Re: What are the targetIDs of WST editors? [message #137331 is a reply to message #137211] Thu, 08 September 2005 09:37 Go to previous messageGo to next message
> To contribute to *xml source editor's popup menu*, use target id
Thanks David,
I had seen this doc recently. It could be completed to include the exact
content types of STEs. The "org.eclipse.core.runtime." prefix was not
obvious to me.
However my plug-in is still not working for JSP files (either in html or xml
format) but does for the platform text editor. The menu item is not being
added to the popup menu.
Follows an excerpt of my plugin.xml file:
<extension point="org.eclipse.ui.popupMenus">
<viewerContribution targetID="#TextEditorContext"
id="com.taleo.tools.plugins.jsf.TextEditorContribution">
<action label="Find Managed Bean"
class="com.taleo.tools.plugins.jsf.actions.FindManagedBeanType "
menubarPath="additions"
id="com.taleo.tools.plugins.jsf.findManagedBean1"/>
</viewerContribution>
<viewerContribution
targetID="org.eclipse.core.runtime.xml.source.EditorContext "
id="com.taleo.tools.plugins.jsf.XmlEditorContribution">
id="com.taleo.tools.plugins.jsf.findManagedBean2"/>
<viewerContribution
targetID="org.eclipse.core.runtime.html.source.EditorContext "
id="com.taleo.tools.plugins.jsf.HtmlEditorContribution">
id="com.taleo.tools.plugins.jsf.findManagedBean3"/>
</extension>
The last 2 viewer contributions are not considered. What am I doing wrong?
Alain Gilbert
Re: What are the targetIDs of WST editors? [message #137400 is a reply to message #137331] Thu, 08 September 2005 12:58 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
Actually, the document David referred to needs a tiny bit of updating due to
changes made in:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104233
But as for your problem, Alain, if you are trying to contribute a popup menu
while editing JSP content, you should use the targetID
"org.eclipse.jst.jsp.core.source.EditorContext"
The editor related id lookup is not smart enough to check the embedded
content type within JSP (XML, HTML). Of course, you could open a bug
requesting for this feature. Hope this works!
-amy
"Alain Gilbert" <agilbert@invalidemail.com> wrote in message
news:dfperm$17i$1@news.eclipse.org...
> Thanks David,
> obvious to me.
xml
> <viewerContribution
> <viewerContribution
> </extension>
> Regards,
> Alain Gilbert
Re: What are the targetIDs of WST editors? [message #137506 is a reply to message #137400] Thu, 08 September 2005 14:08 Go to previous messageGo to next message
> You should use the targetID
> "org.eclipse.jst.jsp.core.source.EditorContext".
Thanks Amy but unfortunately my popup menu item does not show up with this
targetID either!
Could it be that these ids were defined after the 0.7 release?
Re: What are the targetIDs of WST editors? [message #137577 is a reply to message #137506] Fri, 09 September 2005 02:46 Go to previous messageGo to next message
> targetID either!
Looks like there's one last typo. With the changes from bug 104233,
it should be org.eclipse.jst.jsp.core.jspsource.source.EditorContext .
- Nitin
Re: What are the targetIDs of WST editors? [message #137752 is a reply to message #137577] Fri, 09 September 2005 09:44 Go to previous messageGo to next message
> With the changes from bug 104233, it should be
Thanks to David, Amy & Nitin for their help. Now my plug-in is working.
Hopefully these IDs are safe to use by plugins and will be stable for some
time.
Alain Gilbert
Re: What are the targetIDs of WST editors? [message #140048 is a reply to message #137752] Wed, 21 September 2005 21:06 Go to previous message
On Fri, 09 Sep 2005 09:44:26 -0400, Alain Gilbert <agilbert@invalidemail=
That is great news.
> Hopefully these IDs are safe to use by plugins and will be stable for =
some
> time.
Hopefully a long long time -- I planning on 10 years :)
Previous Topic:Trouble creating new Servlet
Next Topic:rdb-problem
Current Time: Sat Jul 19 17:18:32 EDT 2025
Powered by FUDForum. Page generated in 0.04621 seconds
