Home » Eclipse Projects » Remote Application Platform (RAP) » Rap (jetty server) ---> https connection how to
Rap (jetty server) ---> https connection how to [message #136544] Wed, 17 June 2009 04:37 Go to next message
Hi guys,
my problem i have an RCP application which connects to a https app server
at port 8001
I have converted this RCP app to RAP app my making all the dependency
changes and commenting all the incompatible code(SWT)
Now the problem is i connect to the jetty server using http and the jetty
connects to the app server using https and says certificate not found
although in muy machine
the certificate is installed(the jetty is running on my machine)
How can i resolve this issue....
and also what if i want to connect to jtty using https and want to forward
the same certificate info to the https app server???
any help in terms of giving direction via links will also be appreciated...
Re: Rap (jetty server) ---> https connection how to [message #136557 is a reply to message #136544] Wed, 17 June 2009 08:22 Go to previous messageGo to next message
your probleme is rather related to Jetty than to RAP. I found this link
when googling, maybe it helps...
http://www.eclipsezone.com/eclipse/forums/t97206.html
Stefan.
vijay schrieb:
> Hi guys,
> server at port 8001
> jetty connects to the app server using https and says certificate not
> found although in muy machine
> forward the same certificate info to the https app server???
Re: Rap (jetty server) ---> https connection how to [message #136652 is a reply to message #136544] Wed, 17 June 2009 13:41 Go to previous messageGo to next message
The RAP FAQ has a section on using HTTPS with Jetty:
http://wiki.eclipse.org/RAP/FAQ#How_can_I_test_my_applicatio n_with_HTTPS.3F
Ralf
vijay wrote:
> Hi guys,
> server at port 8001
Re: Rap (jetty server) ---> https connection how to [message #136697 is a reply to message #136652] Thu, 18 June 2009 03:52 Go to previous messageGo to next message
First of all thanks
All the solutions suggested are for connecting to jetty server,
what i want is from jetty server i have to connect to another https server
which needs a certificate to be installed...
and what if i want to forward the certificate info from jetty to another
server..
i.e if i connect to jetty using https using all the link info provided,
i need to forward the same cert info to the other https server....
Ralf Sternberg wrote:
> Ralf
> vijay wrote:
>> Hi guys,
>> server at port 8001
Re: Rap (jetty server) ---> https connection how to [message #136843 is a reply to message #136557] Thu, 18 June 2009 07:55 Go to previous message
First of all thanks
server..
Stefan Roeck wrote:
> Regards,
> Stefan.
> vijay schrieb:
>> Hi guys,
>> server at port 8001
Previous Topic:Bug in Table.getColumnOrder() when after moving a column
Next Topic:org.eclipse.swt.EventUtil.suspendEventHandling();
Current Time: Sun Jul 20 08:37:03 EDT 2025
Powered by FUDForum. Page generated in 0.05415 seconds
