Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Generating diagram code in build process
Generating diagram code in build process [message #136677] |
Thu, 21 May 2009 05:16  |
right now, I'm working on setting up a build process for my (partly
GMF-based) tooling. One step of that process should be to generate the
according diagram plug-ins (which I can do since all customizations are
either in a separate plug-in, implemented through dynamic templates, or
done using the GMFTools stuff (see http://code.google.com/p/gmftools/).
I've found two related threads in this newsgroup ("generating diagram
code from a headless build", "Generating Diagram Code from an Ant
Script") which seem to imply that this is not possible. But it's hard to
believe that nobody out there is doing this :-)
So, if my assumption is correct, can anybody share his/her experiences
with that problem? Preferably incorporating the GMFTools process...
Thanks in advance,
Chris
Re: Generating diagram code in build process [message #136692 is a reply to message #136677] |
Thu, 21 May 2009 22:35   |
Hi Chris,
I actually put together a small plugin with an Ant task that run GMF's
codegen. E.g.,
<project name="Generate Diagram Code" default="run"
xmlns:gmf="http://ecliptical.ca/gmf/ant">
<target name="run">
<gmf:GenerateDiagramCode
gmfgenPath="org.eclipse.emf.edit/model/Tree.gmfgen"/>
</target>
</project>
Other supported attributes are ignoreLoadErrors and
ignoreValidationErrors (both boolean).
I haven't had the time to publicize it in any way but you can get it
from my update site at
http://www.eclipticalsoftware.com/updates/site.xml (under the GMF
category). Version 0.9.0 is for Europa and version 1.0.0 is for Ganymede
and later. Hope it works for ya.
--Peter
chris wrote:
> Thanks in advance,
> Chris
Re: Generating diagram code in build process [message #138232 is a reply to message #136692] |
Thu, 09 July 2009 02:54   |
Originally posted by: aurelien.pupier.esial.net
Hi Peter,
I tried your plug-in with
<gmf:GenerateDiagramCode gmfgenPath=" ${buildDirectory}/plugins/org.ow2.jasmine.design.diagram/mod el/jasmine.gmfgen "/>
but it can found the gmfgen file :
org.eclipse.core.runtime.CoreException: Model loaded with errors. uri=platform:/resource/D:/build/plugins/org.ow2.jasmine.desi gn.diagram/model/jasmine.gmfgen
at ca.ecliptical.gmf.ant.GenerateDiagramCodeOperation.run(Gener ateDiagramCodeOperation.java:60)
at ca.ecliptical.gmf.ant.tasks.GenerateDiagramCode.execute(Gene rateDiagramCode.java:53)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTarge ts(SingleCheckExecutor.java:38)
at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor .executeTargets(EclipseSingleCheckExecutor.java:30)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:105)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:513)
at org.eclipse.ant.core.AntRunner.start(AntRunner.java:600)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/build/plugins/org.ow2.jasmine.design.diagram/model/jasmine .gmfgen' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:317)
at org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:194)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:296)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:287)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$WorkbenchHelper.createPlatformResourceInputStream(Pla tformResourceURIHandlerImpl.java:204)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl.createInputStream(PlatformResourceURIHandlerImpl.java :448)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:301)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1212)
at org.eclipse.gmf.internal.common.migrate.ModelLoadHelper.inte rnalLoad(ModelLoadHelper.java:139)
at org.eclipse.gmf.internal.common.migrate.ModelLoadHelper.<init >(ModelLoadHelper.java:130)
at ca.ecliptical.gmf.ant.GenerateDiagramCodeOperation.loadGenMo del(GenerateDiagramCodeOperation.java:110)
at ca.ecliptical.gmf.ant.GenerateDiagramCodeOperation.run(Gener ateDiagramCodeOperation.java:58)
... 62 more
Contains: Resource '/build/plugins/org.ow2.jasmine.design.diagram/model/jasmine .gmfgen' does not exist.
The file exists I'm sure.
I'm on Win XP.
Any idea?
Peter Nehrer a écrit :
> Hi Chris,
> codegen. E.g.,
> <target name="run">
> </target>
> </project>
> --Peter
> chris wrote:
>> Hi,
>> Thanks in advance,
>> Chris
Re: Generating diagram code in build process [message #138622 is a reply to message #136692] |
Wed, 15 July 2009 06:33   |
Hi Peter,
I want to use your plugin but, in the nwe Eclipse release 'Galileo' when
I try to get it using Update Site Manager I obtain the next error message:
"Cannot complete the install because one or more required items could
not be found.
Software being installed: Ant Support for GMF 1.0.0.20090407141548
(ca.ecliptical.gmf.ant.feature.group 1.0.0.20090407141548)
Missing requirement: Ant Support for GMF 1.0.0.20090407141548
(ca.ecliptical.gmf.ant.feature.group 1.0.0.20090407141548) requires
'org.eclipse.gmf.codegen [2.1.1,2.2.0)' but it could not be found"
But I have already intalled the "org.eclipse.gmf.codegen
2.2.0.v20090529-1238" sice it is de defualt version when you download
Galileo.
Is there any incompatibility between your plugin and Galileo? Why
Galileo cannot resolve the dependency correctly?
I am very concerned about using your plging because I think that it is a
really useful plugin.
On the other hand, your plugin takes a .gmfgen file and generates the
diagram code and, as I said before, that's a very interesting job but
also, do you now if there is an Ant task to cover the step of having
..ecore, .gmfgrah, .gmftool, .gmfmap models, generate the .gmfgen file in
order to use it like the input of your plugin?
Thanks!
Peter Nehrer wrote:
> Hi Chris,
> codegen. E.g.,
> <target name="run">
> </target>
> </project>
> --Peter
> chris wrote:
>> Hi,
>> Thanks in advance,
>> Chris
Re: Generating diagram code in build process [message #138818 is a reply to message #138622] |
Thu, 16 July 2009 23:50   |
Miguel,
I uploaded an updated version of the plugin that will work with Galileo.
You'll find it at the same update site url as before.
--Peter
Miguel Angel Garcia de Dios wrote:
> Hi Peter,
> not be found.
> Galileo.
> Thanks!
> Peter Nehrer wrote:
>> Hi Chris,
>> codegen. E.g.,
>> <target name="run">
>> </target>
>> </project>
>> Ganymede and later. Hope it works for ya.
>> --Peter
>> chris wrote:
>>> Hi,
>>> Thanks in advance,
>>> Chris
Re: Generating diagram code in build process [message #139028 is a reply to message #138977] |
Tue, 21 July 2009 02:49  |
>> and I also tried to set <arg value="--launcher.XXMaxPermSize 512m" />
>> in my build.xml in <java classname="org.eclipse.equinox.launcher.Main"
>> fork="true"
>> failonerror="true" errorproperty="build.stderr">
> This has to be a jvmarg, not an arg.
Oh gosh!! thanks
I was thinking that it will used the values set in eclipse.ini but it seems not...
Thanks again a lot
Re: Generating diagram code in build process [message #620973 is a reply to message #136677] |
Hi Chris,
codegen. E.g.,
<target name="run">
</target>
</project>
--Peter
chris wrote:
> Thanks in advance,
> Chris
Re: Generating diagram code in build process [message #621108 is a reply to message #136692] |
Hi Peter,
... 62 more
I'm on Win XP.
Any idea?
> Hi Chris,
> codegen. E.g.,
> <target name="run">
> </target>
> </project>
> --Peter
> chris wrote:
>> Hi,
>> Thanks in advance,
>> Chris
Re: Generating diagram code in build process [message #621134 is a reply to message #136692] |
Hi Peter,
not be found.
Galileo.
Thanks!
Peter Nehrer wrote:
> Hi Chris,
> codegen. E.g.,
> <target name="run">
> </target>
> </project>
> --Peter
> chris wrote:
>> Hi,
>> Thanks in advance,
>> Chris
Re: Generating diagram code in build process [message #621148 is a reply to message #138232] |
Thu, 16 July 2009 11:42  |
Aurelien,
unfortunately GMF codegen doesn't work outside of the workspace. The
gmfgenPath argument must be workspace-relative.
To get around this in an automated build, set your
${buildDirectory}/plugins as the workspace root (using -data argument in
your build launcher).
--Peter
Aurelien Pupier wrote:
> Hi Peter,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Resource
> does not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 62 more
> Contains: Resource
> does not exist.
> I'm on Win XP.
> Any idea?
Re: Generating diagram code in build process [message #621150 is a reply to message #138622] |
Miguel,
--Peter
> Hi Peter,
> not be found.
> Galileo.
> Thanks!
> Peter Nehrer wrote:
>> Hi Chris,
>> codegen. E.g.,
>> <target name="run">
>> </target>
>> </project>
>> --Peter
>> chris wrote:
>>> Hi,
>>> Thanks in advance,
>>> Chris
Re: Generating diagram code in build process [message #621154 is a reply to message #138792] |
Fri, 17 July 2009 08:27  |
Hi Peter,
I set the workspace root to ${buildDirectory}/plugins but I'm still having the same error but I've got another error before :
!ENTRY org.eclipse.osgi 2 0 2009-07-17 13:56:31.614
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-07-17 13:56:31.614
!MESSAGE Bundle org.eclipse.jdt.apt.pluggable.core_1.0.200.v20090526-2130 [347] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core 2 0 2009-07-17 13:56:31.614
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.tool_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.dispatch_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.model_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.util_0.0.0.
!MESSAGE Bundle org.eclipse.jdt.compiler.apt_1.0.200.v20090528-1135 [349] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2009-07-17 13:56:31.614
!MESSAGE Bundle org.eclipse.jdt.compiler.tool_1.0.100.v_963 [350] was not resolved.
Will this can interfere?
and if you know how to avoid it.
Nota : I use the new version with Galileo
Aurelien
> Aurelien,
> --Peter
>> Hi Peter,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Resource
>> does not exist.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 62 more
>> Contains: Resource
>> does not exist.
>> I'm on Win XP.
>> Any idea?
Re: Generating diagram code in build process [message #621156 is a reply to message #138870] |
Fri, 17 July 2009 10:45  |
Ok : In fact, my project is in the folder but not really the workspace.
When I open the eclipse with the workspace I don't see the project.
Now, maybe I "only" to add the project to the workspace via ant task or by modifying your ant task.
Aurelien Pupier a écrit :
> Hi Peter,
> !MESSAGE Bundle
> resolved.
> not resolved.
> Aurelien
>> Aurelien,
>> in your build launcher).
>> --Peter
>>> Hi Peter,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Resource
>>> does not exist.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 62 more
>>> Contains: Resource
>>> does not exist.
>>> I'm on Win XP.
>>> Any idea?
Re: Generating diagram code in build process [message #621158 is a reply to message #138896] |
Mon, 20 July 2009 05:08  |
After added the project to the workspace it works fine if I execute only the diagram generation.
But I generate model java code (emf.Ecore2Java) before I've got Java Heap Space error.
And in all cases, the generation is really slow.
I argument the JVM memory args but doesn't work and BTW it works great with less memory when using classic generation via UI...
I also tried System.gc() at the beginning of the run function.(In order to have a clean VM before the generation of diagram code).
Did you encounter this kind of issue? How to solve it?
Is it an Ant issue?
Re: Generating diagram code in build process [message #621160 is a reply to message #138918] |
Mon, 20 July 2009 09:34  |
Aurelien,
do you specify "--launcher.XXMaxPermSize <size>" in your launcher
command line? I'm not sure what else could be the problem. I have not
run into it even when generating several medium-size models in one build.
--Peter
> Heap Space error.
> Is it an Ant issue?
Re: Generating diagram code in build process [message #621161 is a reply to message #138943] |
Mon, 20 July 2009 10:14  |
I run Ant from Eclipse, so in launch configuration, I choose run in a separate JVM and for VM argument :
-Xms1024m -Xmx1280m
in the eclipse.ini of the launched eclipse, there are :
-Xms512m
-Xmx768m
and I also tried to set <arg value="--launcher.XXMaxPermSize 512m" /> in my build.xml in <java classname="org.eclipse.equinox.launcher.Main" fork="true"
> Aurelien,
> --Peter
>> Heap Space error.
>> Is it an Ant issue?
Re: Generating diagram code in build process [message #621163 is a reply to message #138954] |
Mon, 20 July 2009 14:15  |
> fork="true"
Re: Generating diagram code in build process [message #621167 is a reply to message #138977] |
>> fork="true"
Oh gosh!! thanks
Thanks again a lot
Current Time: Sat Jul 19 10:15:40 EDT 2025
Powered by FUDForum. Page generated in 0.06689 seconds
