Home » Eclipse Projects » Virgo » REST Apis for Administration(Virgo Administration)
REST Apis for Administration [message #1360492] Fri, 16 May 2014 17:01 Go to next message
Hello Everyone!
I'm new in this Forum and I'm looking for an OSGi framework. I have been searching for a framework that exposes REST Apis for administration of Bundles, Services etc. Does Virgo offer that? I see that Virgo's administration web console is great but I would like to customize it or perhaps build a simpler administration module as my needs are quite simple - Can that be done?
Thanks in advance.
Re: REST Apis for Administration [message #1366345 is a reply to message #1360492] Mon, 19 May 2014 05:14 Go to previous messageGo to next message
There isn't an API exposed for changing the admin console this but the code for the Admin console is very modular with each page having a separate of files. The Admin console is a regular webapp that can run on both OSGis HTTP server and as a regular Servlet app. No code changes to run on either, it just works. If you require a simpler app I suggest you just check out the code and change it. As a project it has very few dependencies and interacts entirely through web endpoint. These aren't quite RESTful though as they are mapped from the JMX endpoints using a library called Jolokia.
Re: REST Apis for Administration [message #1366596 is a reply to message #1366345] Mon, 19 May 2014 07:37 Go to previous messageGo to next message
Chris, your response is much appreciated. I will download the code and have a look as suggested. I am assuming removing the admin console and placing my own simplified version would be quite simple.
Thanks.
Re: REST Apis for Administration [message #1366597 is a reply to message #1366596] Mon, 19 May 2014 07:39 Go to previous message
Yes, the admin app is just a jar file in the pickup directory. Just replace it and your new one will be deployed.
Previous Topic:Ready, Steady, Vir...Go!
Next Topic:Org.eclipse.persistence.jpa deployment issue in VIRGO
Current Time: Sun Jul 20 09:06:28 EDT 2025
Powered by FUDForum. Page generated in 0.03812 seconds
