Can't get BeanInfo file to work [message #136248] |
Mon, 05 March 2007 17:53  |
Originally posted by: shawtor.shaw.ca
I went through the SWT Custom Widget tutorial on
http://www.eclipse.org/articles/Article-VE-Custom-Widget/cus tomwidget.html#Runtime_jar
and I was able to get the BeanInfo file to work no matter where I put the
BeanInfo file (same package, different package, in a Jar, in a different
Jar, etc).
I did the same thing with my SWING plugin, but the BeanInfo file did not
work accordingly. Here are the scenarios:
Scenario 1
Project Name: SwingProject
Package: MyCodes
Files inside MyCodes: abc.java and abcBeanInfo.java
I exported MyCodes to file1.jar, ran the eclipse application, import
file1.jar and the BeanInfo file worked.
Scenario 2
Packages: MyCodes, MyBeanInfo
File inside MyCodes: abc.java
File inside MyBeanInfo: abcBeanInfo.java
I exported MyCodes to file1.jar and MyBeanInfo to file2.jar (both file1.jar
and file2.jar are at the root of SwingProject). I added the following lines
to plugin.xml
<extension point="org.eclipse.jem.beaninfo.registrations">
<registration container="CORRECT CONTAINER NAME">
<beaninfo path="file2.jar">
<searchpath package="MyBeanInfo" />
</beaninfo>
</registration>
</extension>
I just did the same thing as what I did in the SWT Custom Widget tutiroal
(and it worked for me there). Again I ran the eclipse application, import
file1.jar but the BeanInfo file did not work.
Re: Can't get BeanInfo file to work [message #136374 is a reply to message #136365] |
Tue, 13 March 2007 15:39  |
That is not a limitation of VE, it is a limitation of the Java Beaninfo
specs themselves. The spec says that it will FIRST look for a class
abcBeanInfo in the same package before it starts looking in the search path.
We've always felt this was a mistake. But the specs can't be changed, it
uses the actual Introspector from Java and can't be overrode. :-(
In fact we always felt it was a mistake to ever include beaninfo in the
same package as the main class. This prevents things like not shipping
the beaninfo when not needed and it prevents overriding as you would
like to do.
Edward wrote:
> I found out what the problem was but I still am not able to solve it.
> I have two jar files, file1.jar (contains abc.class and abcBeanInfo.class)
> and file2.jar (contains only abcBeanInfo.class, this file is different than
> the abcBeanInfo.class in file1.jar). VE always use the abcBeanInfo file in
> file1.jar even though I have edited my plugin.xml to set the beaninfo path
> to the abcBeanInfo file in file2.jar. If I delete the abcBeanInfo.class
> from file1.jar, then VE will go look at the abcBeanInfo.class from
> file2.jar. The problem here is that I don't have authorization to delete
> files in file1.jar. What can I do to set VE to look for the abcBeanInfo
> file in file2.jar when the a file with the same name existed in file1.jar?
> Thanks
> Edward
> "Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
> news:esnju6$2ke$1@utils.eclipse.org...
>> Is this during development? If it is, then there are problems because the
>> beaninfo jar must exist in the project at development time to work.
>> Thanks,
>> Rich Kulp
Rich Kulp
Re: Can't get BeanInfo file to work [message #615104 is a reply to message #136248] |
Tue, 06 March 2007 09:20  |
The beaninfo needs to be inside a package when inside a jar. Classes
from default packages often aren't loadable when in a jar (I don't know
the exact criteria). They need to be in a package. That means you need
to put both classes (the main class and the beaninfo class) in two
different packages and change the extension point to include the search
path to the beaninfo package.
Rich Kulp
Re: Can't get BeanInfo file to work [message #615105 is a reply to message #136251] |
Tue, 06 March 2007 13:46  |
I did that from the beginning but it did not work.
Both my main class and the beaninfo class were in two different packages and
exported to two different jar files. I have also change the extension point
to include the search path to the beaninfo package.
to plugin.xml
</beaninfo>
</registration>
</extension>
It worked for me in the SWT custom widget tutorial but it didn't work for my
SWING plugin.
news:esjtb2$bo8$1@utils.eclipse.org...
> The beaninfo needs to be inside a package when inside a jar. Classes from
> default packages often aren't loadable when in a jar (I don't know the
> exact criteria). They need to be in a package. That means you need to put
> both classes (the main class and the beaninfo class) in two different
> packages and change the extension point to include the search path to the
> beaninfo package.
> Rich Kulp
Re: Can't get BeanInfo file to work [message #615109 is a reply to message #136256] |
Wed, 07 March 2007 19:04  |
the beaninfo jar must exist in the project at development time to work.
Rich Kulp
Re: Can't get BeanInfo file to work [message #615117 is a reply to message #136277] |
Mon, 12 March 2007 13:56  |
Edward
> Rich Kulp
Re: Can't get BeanInfo file to work [message #615118 is a reply to message #136365] |
like to do.
> Thanks
> Edward
>> Thanks,
>> Rich Kulp
Rich Kulp
FUDForum. Page generated in 0.06491 seconds
