Home » Eclipse Projects » Remote Application Platform (RAP) » JavaScript error in IE with M7
JavaScript error in IE with M7 [message #133843] Fri, 22 May 2009 04:11 Go to next message
--------------050208070206020804070404
Content-Type: text/plain; charset=ISO-8859-15
Hi everybody,
since RAP 1.2 M7 I get a Javascript error in IE if I set the selection
of a ComboViewer which setEnabled flag was set to false. I tried FF and
Safari which both work fine and do not show up this error. Unfortunately
the error message is in german:
"Could not evaluate javascript response:
Das Steuerelement kann den Fokus nicht erhalten, da dieses unsichtbar
oder nicht aktiviert ist oder keinen Fokus zul
Re: JavaScript error in IE with M7 [message #133862 is a reply to message #133843] Fri, 22 May 2009 05:47 Go to previous messageGo to next message
Hi Christian,
Could you check this with RC1, which is already released, and if the
problem persists, could you please file a bug report and include your
snippet? We could still try to include a fix into the release.
BTW, does the problem occur with the normal or the debug qx variant?
Ralf
> oder nicht aktiviert ist oder keinen Fokus zulässt. ..."
> This means something like - the widget cannot obtain the focus, because
> it is not visible, not activated or it does not allow any focus.
> I append an example which demostrates this issue.
> Kind regards
> Christian
Re: JavaScript error in IE with M7 [message #133902 is a reply to message #133843] Fri, 22 May 2009 06:38 Go to previous messageGo to next message
Hi Christian,
I can confirm this bug with RAP from CVS HEAD and IE8. Please file a
bugzilla to track the progress on this issue.
Best,
Ivan
Christian wrote:
> Hi everybody,
> Kind regards
> Christian
Re: JavaScript error in IE with M7 [message #133915 is a reply to message #133862] Fri, 22 May 2009 07:23 Go to previous messageGo to next message
RC1 shows the same behaviour and there is no difference between the
standard and the debug qx variant. I filed a bug report with the example
attached.
Kind Regards,
Christian
Re: JavaScript error in IE with M7 [message #134081 is a reply to message #133843] Mon, 25 May 2009 13:17 Go to previous messageGo to next message
we also experianced that behavior. In out case it occured because somehow
(not by our code) the combo viewer tries to get focus, and if it is disabled
(setEnabled(false)) as done by our code, then this exception occurs and
causes the complete kill of the app (need to do a refresh of the browser to
get it work again). This also occurs on Widget Combo, not only ComboViewer.
Markus
"Christian" <christian.hoesel@gmx.de> schrieb im Newsbeitrag
news:gv5mov$4aa$1@build.eclipse.org...
> Hi everybody,
Re: JavaScript error in IE with M7 [message #134098 is a reply to message #134081] Mon, 25 May 2009 13:42 Go to previous messageGo to next message
Hi Markus,
the bug:
277444: JavaScript error in IE when using setSelection on a ComboViewer
with setEnabled is false
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277444
is fixed in CVS HEAD. Please check it with latest from CVS HEAD.
Best,
Ivan
"Markus Kr�������������������
Re: JavaScript error in IE with M7 [message #136138 is a reply to message #134098] Mon, 15 June 2009 11:52 Go to previous messageGo to next message
Hi all,
I have the same error when I set the selection of a hidden Combo (for
example when it is in a Section or ExpandableComposite not expanded). Not
matter if it is enabled or not, the javascript error page occurred.
Should I re-open the bug #277444 or create a new one ?
Loïc
Ivan Furnadjiev wrote:
> Hi Markus,
> the bug:
> Best,
> Ivan
> "Markus" wrote:
>> Hi,
disabled
>> Regards,
>> Markus
>>> Hi everybody,
>>> oder nicht aktiviert ist oder keinen Fokus zulᅵsst. ..."
>>> Kind regards
>>> Christian
Re: JavaScript error in IE with M7 [message #136299 is a reply to message #136138] Tue, 16 June 2009 04:23 Go to previous messageGo to next message
Hi Loïc,
I can reproduce it with the Controls Demo. Please open a separate bug
about this issue.
Ivan
Loïc Bertholet wrote:
> Hi all,
> Not matter if it is enabled or not, the javascript error page occurred.
> Loïc
>> Hi Markus,
>> the bug:
>> ComboViewer with setEnabled is false
>> Best,
>> Ivan
>> "Markus" wrote:
>>> Hi,
>>> somehow (not by our code) the combo viewer tries to get focus, and
>>> if it is
> disabled
>>> and causes the complete kill of the app (need to do a refresh of the
>>> browser to get it work again). This also occurs on Widget Combo, not
>>> only ComboViewer.
>>> Regards,
>>> Markus
>>>> Hi everybody,
>>>> and
>>>> Unfortunately
>>>> because
>>>> Kind regards
>>>> Christian
Re: JavaScript error in IE with M7 [message #136316 is a reply to message #136138] Tue, 16 June 2009 05:28 Go to previous messageGo to next message
Here is the bug:
280420: [Combo] JavaScript error in IE when using setSelection on an
invisible Combo
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280420
Best,
Ivan
> Hi all,
> Loïc
>> Hi Markus,
>> the bug:
>> Best,
>> Ivan
>> "Markus" wrote:
>>> Hi,
>>> if it is
> disabled
>>> only ComboViewer.
>>> Regards,
>>> Markus
>>>> Hi everybody,
>>>> and
>>>> Unfortunately
>>>> because
>>>> Kind regards
>>>> Christian
Re: JavaScript error in IE with M7 [message #136496 is a reply to message #136316] Tue, 16 June 2009 12:55 Go to previous message
Thank you very much.
Loïc
> Here is the bug:
> invisible Combo
> Best,
> Ivan
Previous Topic:Support for GEF in RAP
Next Topic:Graceful shutdown
Current Time: Sun Jul 20 05:49:13 EDT 2025
Powered by FUDForum. Page generated in 0.05690 seconds
