Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Exception in [org.eclipse.emf.compare.examples.standalone]
Exception in [org.eclipse.emf.compare.examples.standalone] [message #135420] Mon, 27 April 2009 18:10 Go to next message
Originally posted by: renezilz.web.de
Hello!
I tried the exanple of the standalone version of emf compare which you
can find
under:http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.e mf/org.eclipse.emf.compare/examples/org.eclipse.emf.compare. examples.standalone/?root=Modeling_Project
At first he did not know the type ComparisonResourceSnapshot. Because of
this I replaced the type through ModelInputSnapshot. Now the
example shows no errors but if I try to run the application I get
following exception:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/uml2/common/util/CacheAdapter
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.getCacheAdapt er(ElementImpl.java:714)
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotification Required(ElementImpl.java:852)
at
org.eclipse.uml2.uml.internal.impl.NamedElementImpl.setName( NamedElementImpl.java:263)
at org.eclipse.uml2.uml.internal.impl.ModelImpl.eSet(ModelImpl. java:266)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1071)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1154)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2643)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2702)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:85)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2178)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1316)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1454)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:501)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(XMLDTDValidator.java:767)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:1359)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl. java:1316)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:3095)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(XMLDocumentScannerImpl.java:921)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:648)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 510)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1205)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :320)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :218)
at ExampleLauncher.main(ExampleLauncher.java:67)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.uml2.common.util.CacheAdapter
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 38 more
Can anybody help me? What am I doing wrong?
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #135433 is a reply to message #135420] Tue, 28 April 2009 04:59 Go to previous messageGo to next message
--------------030506080405070407000407
Hi Rene,
See comments inlined below.
Rene Zilz a
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #135576 is a reply to message #135433] Wed, 29 April 2009 12:55 Go to previous messageGo to next message
Hello laurent!
Thank you very much for this. The merging runs without any problems. :)
Now I tried to start the comparision editor for the emfdiff result.
I added following lines to the ExampleLauncher:
ModelCompareEditorInput input=new ModelCompareEditorInput(snapshot);
CompareUI.openCompareEditor(input);
After I added this and trying to start the application, I got a lot of
NoClassDefFoundError. For example first was missing
org.eclipse.ui.IEditorInput,
then
org.eclipse.core.runtime.IAdaptable
org/osgi/framework/BundleActivator
org/eclipse/core/runtime/preferences/IScopeContext
and so on..
Because of this I think I'm doing something wrong.
Best regards
rene
laurent Goubet wrote:
> Hi Rene,
> Rene Zilz a écrit :
>> Hello!
>> can find
> EMF Compare is standalone, this isn't the "standalone version", merely
> an example of a the way to use it as a standalone application :).
>> of this I replaced the type through ModelInputSnapshot. Now the
> This means you have downloaded the latest version of the example, but
> are using an old version of EMF Compare itself. This API has changed a
> couple of months ago and "ModelInputSnapshot" no longer exists.
> You are using EMF Compare ot compare uml models but you didn't add the
> library org.eclipse.uml2.common to your classpath.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at java.security.AccessController.doPrivileged(Native Method)
>> ... 38 more
> I think the above should answer this, do not hesitate to come back to us
> if it didn't :).
> Laurent Goubet
> Obeo
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #135639 is a reply to message #135576] Thu, 30 April 2009 03:58 Go to previous messageGo to next message
--------------030602040502070804000906
Hi Rene,
That doesn't really surprise me, EMF Compare can be run standalone, yet
its UI cannot. Our UI is tightly integrated with the Eclipse UI and thus
heavily depends on it. We have neither RCP nor standalone UI for EMF
Compare and if you seek on displaying the compare editor you will have
to do it from within an Eclipse instance (the code you've copy pasted is
what's needed for that).
Laurent Goubet
Obeo
Rene Zilz a
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #135666 is a reply to message #135639] Thu, 30 April 2009 05:31 Go to previous messageGo to next message
Hello laurent!
yes I use Eclipse and also try to start the comparisionEditor in
Eclipse. But I get the errors all the same.
> Hi Rene,
> Laurent Goubet
> Obeo
> Rene Zilz a écrit :
>> Hello laurent!
>> then
>> and so on..
>> Best regards
>> rene
>>> Hi Rene,
>>> Rene Zilz a écrit :
>>>> Hello!
>>>> you can find
>>> merely an example of a the way to use it as a standalone application :).
>>>> Because of this I replaced the type through ModelInputSnapshot.
>>>> Now the
>>> a couple of months ago and "ModelInputSnapshot" no longer exists.
>>> the library org.eclipse.uml2.common to your classpath.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 38 more
>>> us if it didn't :).
>>> Laurent Goubet
>>> Obeo
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #135679 is a reply to message #135666] Thu, 30 April 2009 06:00 Go to previous message
--------------030601060008040706080305
Rene,
The problem you had at first tend to prove you are running a "java
application" and not an "Eclipse application". If what you are tryng to
do is simply compare two files and have the comparison result displayed
in Eclipse, you can simply select your two files, right-click them and
select compare with => each other. The EMF Compare FAQ at
http://wiki.eclipse.org/EMF_Compare_FAQ show how to add your extension
to the list of files EMF Compare should take into account.
If you need to programmatically call EMF Compare without displaying its
UI, you can create a Java program such as shown in the standalone
example. On the other hand if you need to programmatically compare two
files and display the result in the Eclipse comparison UI, you need to
create a plugin and have the comparison code within, then have a way to
call the code of your plugin from a runtime Eclipse workbench
(right-click action on the files for example).
If you have never developped Eclipse plugins, I think the
org.eclipse.newcomer newsgroup is your best bet for pointers on
documentation or tutorials.
Laurent Goubet
Obeo
Rene Zilz a
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #620879 is a reply to message #135420] Tue, 28 April 2009 04:59 Go to previous message
Hi Rene,
Rene Zilz a
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #620890 is a reply to message #135433] Wed, 29 April 2009 12:55 Go to previous message
Hello laurent!
then
and so on..
Best regards
rene
> Hi Rene,
> Rene Zilz a écrit :
>> Hello!
>> can find
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 38 more
> if it didn't :).
> Laurent Goubet
> Obeo
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #620895 is a reply to message #135576] Thu, 30 April 2009 03:58 Go to previous message
Hi Rene,
Laurent Goubet
Obeo
Rene Zilz a
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #620897 is a reply to message #135639] Thu, 30 April 2009 05:31 Go to previous message
Hello laurent!
> Hi Rene,
> Laurent Goubet
> Obeo
> Rene Zilz a écrit :
>> Hello laurent!
>> then
>> and so on..
>> Best regards
>> rene
>>> Hi Rene,
>>> Rene Zilz a écrit :
>>>> Hello!
>>>> you can find
>>>> Now the
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 38 more
>>> us if it didn't :).
>>> Laurent Goubet
>>> Obeo
Re: Exception in [org.eclipse.emf.compare.examples.standalone] [message #620898 is a reply to message #135666] Thu, 30 April 2009 06:00 Go to previous message
Rene,
Laurent Goubet
Obeo
Rene Zilz a
Previous Topic:[EWM] parallel and remote workflows
Next Topic:[Proposal] Edapt - Framework for Ecore model adaptation and instance migration
Current Time: Sat Jul 19 21:08:21 EDT 2025
Powered by FUDForum. Page generated in 0.08037 seconds
