Home » Modeling » TMF (Xtext) » "XtextReconcilerJob" internal error(Unrecoverable editor crash with simple grammar)
"XtextReconcilerJob" internal error [message #1352819] Tue, 13 May 2014 12:47 Go to next message
I have reduced my grammar to the following:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "...MyDsl"
MyDslModel: model=IfStatement;
NegationBooleanOperator: 'NOT';
Sign:    '+' | '-';
IfStatement: 'if' exp=Expression ';';
Expression: Factor (Sign exp=Expression)?;
Factor: constant=ID | (NegationBooleanOperator fac=Factor);
Then in the generated Xtext editor if I type:
if if x +
the following message pops up, an error is thrown and the editor stops working:
An internal error occurred during: "XtextReconcilerJob".
java.lang.IllegalArgumentException: Expression.exp does not exist
The problem occurs only when the if is repeated in the editor. However, this is a common pattern in the full grammar.
Many thanks for your help.
Re: "XtextReconcilerJob" internal error [message #1352953 is a reply to message #1352819] Tue, 13 May 2014 14:08 Go to previous messageGo to next message
did you have a look at http://blog.efftinge.de/2010/08/parsing-expressions-with-xtext.html
Sign:    '+' | '-';
Expression: Factor ({Expression.left=current }Sign exp=Factor)*;
Factor returns Expression: constant=ID | (NegationBooleanOperator fac=Factor);
Re: "XtextReconcilerJob" internal error [message #1352970 is a reply to message #1352953] Tue, 13 May 2014 14:16 Go to previous messageGo to next message
ps: you may assign Sign and NegationBooleanOperator so that it wont get lost
Sign:    '+' | '-';
Expression: Factor ({Expression.left=current } op=Sign exp=Factor)*;
Factor returns Expression: {Factor}constant=ID | NotExpression;
NotExpression returns Expression:{NotExpression} (NegationBooleanOperator fac=Factor);
Re: "XtextReconcilerJob" internal error [message #1354469 is a reply to message #1352953] Wed, 14 May 2014 05:10 Go to previous message
Many thanks for your really quick response. I managed to apply this pattern throughout my full grammar and it finally fixed the editor crashes. Fantastic!
I suppose the main problem, aside from my inexperience, is that these mistakes get past the Xtext editor - which does sometimes report left recursion - and past the artefact generation stage, manifesting themselves as occasional catastrophic unhandled exceptions coming from ANTLR while editing the DSL. Is there any way these forbidden constructs could be reported earlier - ideally in the Xtext grammar editor? [I am using the latest XText 2.6.0]
Previous Topic:[SOLVED]Validation- Grammar mixin semantic validation
Next Topic:How to setup IApplication to read DSL files
Current Time: Sun Jul 20 18:42:32 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
