Once again: How to change the color of a polyline connection [message #134127] |
Tue, 25 May 2004 14:15  |
Originally posted by: Alexander.Eiken.post.rwth-aachen.de
once again I have to ask the question how to change the color of a
polyline connection. I know there have been several threads about this
topic, but everything I read about this hasn't solved the problem.
All polyline connections are drawn in a gray color, but the decorations
of the polyline have the correct color. It seems to be a general
problem, because I have the same problem with ellipse figures.
I tried to set the color of the connection only once and I did it in the
method refreshVisuals() of the EditPart.
I extend the class PolylineConnection in order to add some decorations
and a label to a polyline. May this be the problem?
Any suggestions would be appreciated.
Thanks, Alexander.
Re: Once again: How to change the color of a polyline connection [message #134387 is a reply to message #134363] |
Wed, 26 May 2004 08:46   |
Originally posted by: rlemaigr.ulb.ac.be
I have tried something similar here for me and it works here, the line =
changes its color...that's strange it doesn't work for you...
I have a subclass of PolylineConnection like you and I set the foregroun=
d =
color in the constructor.
Maybe you could try to make some tests like overriding the outline (?) =
method like that
public void outline(Graphics g)
System.out.println(g.getForegroundColor());
super.outline(g);
just to see wich color is really used by the Graphics object to paint th=
e =
line ?
If it is not the one you choosed, probably the method getForegroundColor=
called on the subclass of polylineconnection doesn't return the good =
color, so you could search in that direction...and if it is the one you =
choose...then I don't know...call an exorcist :D !
good luck,
r=E9gis
On Wed, 26 May 2004 09:19:12 +0200, Alexander Eiken =
<Alexander.Eiken@post.rwth-aachen.de> wrote:
> Randy Hudson schrieb:
>> Figures.setForegroundColor(color);
> I know. But this doesn't work for my subclass of PolylineConnection. T=
he =
> subclass is simple and jeust adds some decorations and a label to the =
> connection. The line doesn't change the color, even if I put the code =
of =
> the subclass in comments.
> If I use just a PolylineConnection, the line has the correct color.
> What might be the problem, when I extend PolylineConnection?
> Am I allowed to extend PolylineConnection?
> Thanks, Alexander.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Once again: How to change the color of a polyline connection [message #134419 is a reply to message #134397] |
Wed, 26 May 2004 11:00   |
Ok !
But that's still very strange...
A similar problem is I can't set at the same time the style AND the widt=
h =
of a polyline.
For example, I can't get a bold and dash polyline.
I write in the constructor of my subclass of PolylineConnection:
this.setLineWidth(2);
this.setLineStyle(SWT.LINE_DOT);
but it doesn't work.
It seems that this two lines can't stand each other !
Psychology of code lines is something strange, sometimes...they have =
feelings too, you know...
r=E9gis
On Wed, 26 May 2004 16:15:07 +0200, Alexander Eiken =
> Hi, regis!
> Thanks for your idea. I finally solved the problem!!!
> The graphics object had indeed the wrong foreground color. So I added =
a =
> call g.setForegroundColor() with the correct color and now it works...=
> Alexander
> rlemaigr@ulb.ac.be schrieb:
>> I have tried something similar here for me and it works here, the lin=
e =
>> I have a subclass of PolylineConnection like you and I set the =
>> foreground color in the constructor.
>> Maybe you could try to make some tests like overriding the outline =
>> (?) method like that
>> super.outline(g);
>> just to see wich color is really used by the Graphics object to paint=
>> the line ?
>> If it is not the one you choosed, probably the method =
>> getForegroundColor() called on the subclass of polylineconnection =
>> doesn't return the good color, so you could search in that =
>> direction...and if it is the one you choose...then I don't know...ca=
ll =
>> an exorcist :D !
>> good luck,
>> r=E9gis
Re: Once again: How to change the color of a polyline connection [message #134496 is a reply to message #134458] |
Wed, 26 May 2004 12:56  |
Ok so that's a known bug...thank you for your link...
I don't exactly know what it means to vote for it but I did it (I guess =
it =
increases the priority of the bug)...
r=E9gis
On Wed, 26 May 2004 11:18:43 -0500, Whitney Sorenson <none@us.ibm.com> =
wrote:
> It's not as strange as you think..
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D4853
> Feel free to vote.
> <rlemaigr@ulb.ac.be> wrote in message
> news:opr8l3y5sxxn9g2u@xn--pcrgis-dva.mshome.net...
> Ok !
> A similar problem is I can't set at the same time the style AND the wi=
dth
> of a polyline.
> r=E9gis
>> Hi, regis!
>> The graphics object had indeed the wrong foreground color. So I added=
a
>> call g.setForegroundColor() with the correct color and now it works..=
>> Alexander
>>> I have tried something similar here for me and it works here, the li=
ne
>>> super.outline(g);
>>> just to see wich color is really used by the Graphics object to pain=
t
>>> the line ?
>>> direction...and if it is the one you choose...then I don't know...c=
all
>>> an exorcist :D !
>>> good luck,
>>> r=E9gis
FUDForum. Page generated in 0.07249 seconds
