Home » Archived » Visual Editor (VE) » VE customize layout problem
VE customize layout problem [message #134107] |
Thu, 14 December 2006 04:49  |
Hi all,
i use VE to build a swt application , when i try to customize the layout
of a component, some exceptions occur and the tabs "component" of
"customize layout" is appearing with a message "no component option to
customize on current selection".
Note: i m up to Date with eclipse 3.2.1 and i install VE from callisto
set (see my configuration details below)
2 exceptions are logged in "error Log"'s view each time i do a right
click on a component :
First :
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:779)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1115)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:833)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:818)
at
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:96)
at
org.eclipse.ve.internal.swt.GridLayoutComponentPage.getHoriz ontalAlignValue(GridLayoutComponentPage.java:1110)
at
org.eclipse.ve.internal.swt.GridLayoutComponentPage.handleSe lectionChangedForAlignmentActions(GridLayoutComponentPage.ja va:988)
at
org.eclipse.ve.internal.swt.GridLayoutComponentPage.refreshA llValues(GridLayoutComponentPage.java:971)
at
org.eclipse.ve.internal.swt.GridLayoutComponentPage.handleSe lectionChanged(GridLayoutComponentPage.java:949)
at
org.eclipse.ve.internal.cde.core.CustomizeLayoutPage.update( CustomizeLayoutPage.java:91)
at
org.eclipse.ve.internal.cde.core.CustomizeLayoutWindow.updat e(CustomizeLayoutWindow.java:367)
at
org.eclipse.ve.internal.cde.core.CustomizeLayoutWindowAction .update(CustomizeLayoutWindowAction.java:422)
at
org.eclipse.ve.internal.cde.core.CustomizeLayoutWindowAction .run(CustomizeLayoutWindowAction.java:363)
at
org.eclipse.ve.internal.cde.core.CustomizeLayoutWindowAction .showCustomizeLayoutWindow(CustomizeLayoutWindowAction.java: 148)
at
org.eclipse.ve.internal.cde.core.OpenCustomizeLayoutObjectAc tionDelegate.run(OpenCustomizeLayoutObjectActionDelegate.jav a:55)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
with this session data:
eclipse.buildId=M20060921-0945
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
and the second exception:
Unhandled event loop exception
java.version=1.6.0
Configuration details:
*** Date: Thu Dec 14 10:45:56 CET 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse\eclipse 3.2.1\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
8d8_7c
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1166088708640
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\eclipse\eclipse 3.2.1\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
http.proxyHost=dev.orange.com
http.proxyPort=8080
http.proxySet=true
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\eclipse 3.2.1\startup.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0
java.io.tmpdir=C:\DOCUME~1\defert\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\Sun\Java\ bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\W INDOWS\System32\Wbem;C:\Program
Files\Intel\Wireless\Bin\;C:\Program Files\IBM ThinkVantage\Client
Security Solution;C:\Program Files\Diskeeper
Corporation\Diskeeper\;C:\Program Files\MySQL\MySQL Server
4.1\bin;C:\Program Files\ThinkPad\ConnectUtilities;C:\Program
Files\apache-ant-1.6.5\bin;C:\Program Files\Fichiers
communs\GTK\2.0\bin;C:\Program Files\IDM Computer
Solutions\UltraEdit-32;C:\Program Files\Fichiers
communs\Adobe\AGL;C:\Program
Files\Intel\Wireless\Bin;C:\eclipse\eclipse3.2;C:\Program
Files\QuickTime\QTSystem\;C:\Program Files\CVSNT\;C:\Program
Files\OpenVPN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0-b105
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0-b105
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=fr
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\eclipse
3.2.1\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/eclipse/eclipse 3.2.1/configuration/
osgi.framework=file:/c:/eclipse/eclipse
3.2.1/plugins/org.eclipse.osgi_3.2.1.R32x_v20060919.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.1.R32x_v20060919
osgi.install.area=file:/C:/eclipse/eclipse 3.2.1/
osgi.instance.area=file:/C:/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/defert/workspace/
osgi.logfile=C:\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\eclipse
3.2.1\configuration\org.eclipse.osgi\manifests
osgi.nl=fr_FR
osgi.os=win32
osgi.splashLocation=c:\eclipse\eclipse
3.2.1\plugins\org.eclipse.platform_3.2.0.v20060601\splash.bm p
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\eclipse 3.2.1\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0\lib\resources.jar;C:\Program
Files\Java\jre1.6.0\lib\rt.jar;C:\Program
Files\Java\jre1.6.0\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0\lib\jce.jar;C:\Program
Files\Java\jre1.6.0\lib\charsets.jar;C:\Program Files\Java\jre1.6.0\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=FR
user.dir=C:\eclipse\eclipse 3.2.1
user.home=C:\Documents and Settings\defert
user.language=fr
user.name=defert
user.timezone=Europe/Paris
user.variant=
*** Features:
org.eclipse.emf (2.2.1.v200609210005) "Eclipse Modeling Framework (EMF)"
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework"
org.eclipse.jdt (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.1.v20060815_M----6zXJJzKIRGVU) "Java EMF Model"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform"
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP"
org.eclipse.rcp.source (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.1.r321_v20060801-tQ1w49KnTArT0FZ) "Eclipse Project SDK"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fxM-0vSdc) "Visual Editor"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5) "International Components for Unicode for Java
(ICU4J)" [Active]
com.ibm.icu.source (3.4.5) "International Components for Unicode for
Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.1.r321_v20060721) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.1.R32x_v20060914) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.1.v20060823) "Debug UI" [Active]
org.eclipse.draw2d (3.2.1.v20060921) "Draw2d" [Active]
org.eclipse.emf (2.2.0.v200609210005) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200609210005) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.1.v200609210005) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.1.v200609210005) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609210005) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200609210005) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200609210005) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200609210005) "EMF Common UI" [Resolved]
org.eclipse.emf.converter (2.2.1.v200609210005) "EMF Model Convert
Support" [Resolved]
org.eclipse.emf.ecore (2.2.1.v200609210005) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200609210005) "EMF Ecore Change
Model" [Active]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609210005) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200609210005) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200609210005) "Sample Ecore Editor"
[Resolved]
org.eclipse.emf.ecore.xmi (2.2.1.v200609210005) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.1.v200609210005) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200609210005) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200609210005) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.importer (2.2.1.v200609210005) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200609210005) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200609210005) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.2.0.v200609210005) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200609210005) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609210005) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609210005) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609210005) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609210005) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200609210005) "EMF Mapping UI" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.1.R321_v20060920) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.1.R321_v20060822) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.1.R321_v20060803) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Resolved]
org.eclipse.jdt.core (3.2.1.v_677_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.1.r321_v20060731) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.1.r321_v20060918) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.1.r321_v20060907) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.1.r321_v20060731) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.1.r321_v20060907) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.0.v20060918_M) "Java EMF Model BeanInfo
(Introspection) Support" [Active]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Active]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.1.v20060918_M) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.1.M20060908-1000) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.1.r321_v20060810) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.2.1.r321_v20060726) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Active]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.1.r321_v2006030) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.1.r321_v20060705) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.1.v3235e) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.1.v3235) "Standard Widget Toolkit
org.eclipse.team.core (3.2.1.M20060711) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.1.M200608161750) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.2.1.M20060831) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Active]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20060913-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.1.R321_v20060810) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal
Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21
Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.1.M20060906-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.1.v20092006) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.1.v20092006) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.1.v20092006) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.1.v20092006) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.1.v20092006) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0.v20060518_RC1) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.2.0.v20060918_M) "Visual Editor Common Data
Editor" [Active]
org.eclipse.ve.doc (1.2.0.v20060824_M) "Visual Editor for Java User
Guide" [Resolved]
org.eclipse.ve.java.core (1.2.1.v20060918_M) "Visual Editor Java Core"
[Active]
org.eclipse.ve.jfc (1.2.1.v20060918_M) "Visual Editor for Java
Foundation Classes" [Active]
org.eclipse.ve.propertysheet (1.2.0.v20060824_M) "Visual Editor
PropertySheet" [Active]
org.eclipse.ve.swt (1.2.1.v20060918_M) "Visual Editor for Standard
Widget Toolkit" [Active]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
system.bundle (3.2.1.R32x_v20060919) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu Dec 14 10:45:57 CET 2006
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/project/Protection/org.eclipse.jdt.core/org.eclipse.jdt.cor e.compiler.codegen.inlineJsrBytecode=enabled
/project/test/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.source=1.5
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/com.quantum.Quantum/com.quantum.actions.BookmarkSe lectionUtil.bookmark=squate
de la base best local
/instance/com.omondo.database/com.omondo.database.reverse.sc hema=false
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_between_empty_parens _in_method_invocation=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_type_declaration=end_of_line
/project/Printing/org.eclipse.jdt.ui/internal.default.compli ance=default
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info
extension\="xsd2ecore" name\="*">\r\n<editor
id\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit orID "/>\r\n<defaultEditor
id\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit orID "/>\r\n</info>\r\n<info
extension\="jpage" name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="uld" name\="*">\r\n<editor
id\="com.omondo.uml.CollaborationDiagramEditor"/>\r\n</info >\r\n<info
extension\="rxml" name\="*"/>\r\n<info extension\="ddl"
id\=" org.eclipse.wst.rdb.internal.sqlscrapbook.editor.SQLScrapboo kEditor "/>\r\n<defaultEditor
id\=" org.eclipse.wst.rdb.internal.sqlscrapbook.editor.SQLScrapboo kEditor "/>\r\n</info>\r\n<info
extension\="prd" name\="*">\r\n<editor
id\="com.omondo.uml.ProfileDiagramEditor"/>\r\n</info>\r\n <info
extension\="datagraph" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n <defaultEditor
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n </info>\r\n<info
extension\="hs" name\="*">\r\n<editor
id\=" org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part "/>\r\n<defaultEditor
id\=" org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part "/>\r\n</info>\r\n<info
extension\="xmi" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n<defaultEditor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info
extension\="statcon" name\="*"/>\r\n<info extension\="execution"
name\="*"/>\r\n<info extension\="jardesc" name\="*">\r\n<editor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="jdo" name\="*">\r\n<editor
extension\="trcdbxmi" name\="*"/>\r\n<info extension\="jsf"
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info >\r\n<info
extension\="usd" name\="*">\r\n<editor
id\="com.omondo.uml.SequenceDiagramEditor"/>\r\n</info>\r\n <info
extension\="java" name\="*">\r\n<editor
id\="org.eclipse.jdt.ui.CompilationUnitEditor"/>\r\n<editor
id\=" org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itor "/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.CompilationUnitEditor"/>\r\n</info >\r\n<info
extension\="edd" name\="*">\r\n<editor
id\="com.omondo.uml.emf.DeploymentDiagramEditor"/>\r\n</info >\r\n<info
extension\="text" name\="*"/>\r\n<info extension\="jspx"
extension\="vsl" name\="*">\r\n<editor
id\="de.byteaction.velocity.editor.Editor"/>\r\n</info>\r\n <info
extension\="class" name\="*">\r\n<editor
id\="jadclipse.JadclipseClassFileEditor"/>\r\n<defaultEditor
id\="jadclipse.JadclipseClassFileEditor"/>\r\n</info>\r\n <info
extension\="location" name\="*"/>\r\n<info extension\="shapes"
name\="*"/>\r\n<info extension\="html" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor
id\="de.byteaction.velocity.editor.Editor"/>\r\n<editor
id\="net.sf.vex.editor.VexEditor"/>\r\n<defaultEditor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="flow" name\="*"/>\r\n<info extension\="override"
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n<defaultEditor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="dbsv" name\="*"/>\r\n<info extension\="ecore"
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n <editor
id\="com.omondo.uml.emf.ClassDiagramEditor.ecore"/>\r\n<defaultEditor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info
extension\="trcnxmi" name\="*"/>\r\n<info extension\="ecore2xml"
id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n<defaultEditor
id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n</info>\r\n<info
extension\="htm" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n<defaultEditor
extension\="server" name\="*">\r\n<editor
id\="org.eclipse.wst.server.ui.editor"/>\r\n<defaultEditor
id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n <info
extension\="ecd" name\="*">\r\n<editor
id\="com.omondo.uml.emf.ClassDiagramEditor.ecd"/>\r\n</info >\r\n<info
extension\="ucd" name\="*">\r\n<editor
id\="com.omondo.uml.ClassDiagramEditor"/>\r\n</info>\r\n <info
extension\="xml" name\="*">\r\n<editor
id\="net.sf.vex.editor.VexEditor"/>\r\n</info>\r\n<info extension\="upd"
id\="com.omondo.uml.ComponentDiagramEditor"/>\r\n</info>\r\n <info
extension\="xsd" name\="*">\r\n<editor
id\="org.eclipse.xsd.presentation.XSDEditorID"/>\r\n<defaultEditor
id\="org.eclipse.xsd.presentation.XSDEditorID"/>\r\n</info >\r\n<info
extension\="eld" name\="*">\r\n<editor
id\="com.omondo.uml.emf.CollaborationDiagramEditor"/>\r\n </info>\r\n<info
extension\="uod" name\="*">\r\n<editor
id\="com.omondo.uml.ObjectDiagramEditor"/>\r\n</info>\r\n <info
extension\="eud" name\="*">\r\n<editor
id\="com.omondo.uml.emf.UseCaseDiagramEditor"/>\r\n</info >\r\n<info
extension\="diadef" name\="*"/>\r\n<info extension\="adapter"
name\="*"/>\r\n<info extension\="probe" name\="*"/>\r\n<info
extension\="vm" name\="*">\r\n<editor
id\=" com.hudson.velocityweb.editors.velocity.VelocityMultiPageEdi tor "/>\r\n<editor
extension\="jspf" name\="*">\r\n<editor
extension\="wsimsg" name\="*">\r\n<editor
id\="org.eclipse.wst.wsi.ui.internal.WSILogEditor"/>\r\n<defaultEditor
id\="org.eclipse.wst.wsi.ui.internal.WSILogEditor"/>\r\n</info >\r\n<info
extension\="epd" name\="*">\r\n<editor
id\="com.omondo.uml.emf.ComponentDiagramEditor"/>\r\n</info >\r\n<info
extension\="properties" name\="build">\r\n<editor
id\="org.eclipse.pde.ui.buildEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.buildEditor"/>\r\n</info>\r\n<info
extension\="ImpartOJBGenerator.properties" name\="*"/>\r\n<info
extension\="emof2ecore" name\="*"/>\r\n<info extension\="trcaxmi"
name\="*"/>\r\n<info extension\="esd" name\="*">\r\n<editor
id\="com.omondo.uml.emf.SequenceDiagramEditor"/>\r\n</info >\r\n<info
extension\="odd" name\="*">\r\n<editor
id\="com.omondo.database.external.uml.DatabaseDiagramEditor "/>\r\n<editor
extension\="rex" name\="*">\r\n<editor
id\=" de.babe.eclipse.plugins.quickREx.editors.RELibraryEntryEdito r "/>\r\n</info>\r\n<info
extension\="sqlpage" name\="*">\r\n<editor
extension\="uml2" name\="*">\r\n<editor
id\="org.eclipse.uml2.presentation.UML2EditorID"/>\r\n</info >\r\n<info
extension\="ead" name\="*">\r\n<editor
id\="com.omondo.uml.emf.ActivityDiagramEditor"/>\r\n</info >\r\n<info
extension\="uad" name\="*">\r\n<editor
id\="com.omondo.uml.ActivityDiagramEditor"/>\r\n</info>\r\n <info
extension\="trcpxmi" name\="*"/>\r\n<info extension\="testsuite"
name\="*"/>\r\n<info extension\="eod" name\="*">\r\n<editor
id\="com.omondo.uml.emf.ObjectDiagramEditor"/>\r\n</info >\r\n<info
extension\="urd" name\="*">\r\n<editor
id\="com.omondo.uml.RobustnessDiagramEditor"/>\r\n</info >\r\n<info
extension\="genmodel" name\="*">\r\n<editor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "/>\r\n<defaultEditor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "/>\r\n</info>\r\n<info
extension\="artifact" name\="*"/>\r\n<info extension\="tagf"
extension\="sql" name\="*">\r\n<editor
extension\="jhm" name\="*">\r\n<editor
extension\="datapool" name\="*"/>\r\n<info extension\="properties"
name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="logic" name\="*"/>\r\n<info extension\="gmfgen"
name\="*"/>\r\n<info extension\="trcmxmi" name\="*"/>\r\n<info
extension\="utd" name\="*">\r\n<editor
id\="com.omondo.uml.StateDiagramEditor"/>\r\n</info>\r\n <info
extension\="udd" name\="*">\r\n<editor
id\="com.omondo.uml.DeploymentDiagramEditor"/>\r\n</info >\r\n<info
extension\="deploy" name\="*"/>\r\n<info extension\="jsp"
extension\="properties" name\="*">\r\n<editor
id\="org.eclipse.jdt.ui.PropertiesFileEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.PropertiesFileEditor"/>\r\n</info >\r\n<info
extension\="uud" name\="*">\r\n<editor
id\="com.omondo.uml.UseCaseDiagramEditor"/>\r\n</info>\r\n <info
extension\="ecore2ecore" name\="*">\r\n<editor
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n<defaultEditor
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info
extension\="gmfmap" name\="*"/>\r\n<info extension\="shtml"
extension\="jsml" name\="*"/>\r\n<info extension\="tag"
extension\="emof" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n <defaultEditor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n</editors>
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_at_in_annotati on=do
not insert
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.finalParameterBound=ignore
/instance/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_ TAB=1
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_colon_in_condi tional=insert
/instance/org.eclipse.ant.ui/problem_security=warning
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.indent_statements_compare_to_bloc k=true
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_brace _in_annotation_type_declaration=insert
/instance/com.omondo.database/com.omondo.database.path.relat ive=true
/instance/org.eclipse.wst.internet.proxy/passwordText=encode d\:
/project/EKAsset/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.codegen.targetPlatform=1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_arguments_in_qualified_allocation_expression =16
/instance/org.eclipse.team.bugzilla/providers/http\:..localh ost/history/org.eclipse.team.bugzilla.modelType=history
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.alignment_for_parameters_in_const ructor_declaration=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_conditional_expression=80
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.continuation_indentation=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_between_type_declarations=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_body_declarations_compare_to_enum_constant_header=t rue
/instance/org.eclipse.debug.ui/Expressions.detail.orientatio n=Variables.detail.orientation.underneath
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_comma_in_type _arguments=do
not insert
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.views_to _not_open=org.eclipse.debug.ui.ExpressionView,org.eclipse.de bug.ui.VariableView,org.eclipse.ui.console.ConsoleView,
@org.eclipse.gef=3.2.1.v20060921
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_between_brackets_in_ array_type_reference=do
not insert
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_LOGGING_CORE=C\:\\eclipse\\calisto\\plugins\\org.ecl ipse.hyades.logging.core_4.2.0.v200606131519\\hlcore.jar;C\: \\eclipse\\calisto\\plugins\\org.eclipse.hyades.logging.core _4.2.0.v200606131519\\hlcbe101.jar;C\:\\eclipse\\calisto\\pl ugins\\org.eclipse.hyades.logging.core_4.2.0.v200606131519\\ tlcbe101.jar;C\:\\eclipse\\calisto\\plugins\\org.eclipse.hya des.logging.core_4.2.0.v200606131519\\hl14.jar;C\:\\eclipse\ \calisto\\plugins\\org.eclipse.hyades.logging.core_4.2.0.v20 0606131519\\hllog4j.jar;C\:\\eclipse\\calisto\\plugins\\org. eclipse.hyades.logging.core_4.2.0.v200606131519\\hlcommons.j ar;C\:\\eclipse\\calisto\\plugins\\org.eclipse.hyades.loggin g.core_4.2.0.v200606131519\\bin;
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.workspace-par ticipant
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_closing_angle_ bracket_in_type_arguments=insert
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_v iew_perspectives=org.eclipse.debug.ui.DebugPerspective,
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EQUINOX_COMMON=C\:\\eclipse\\calisto\\plugins\\org.eclipse. equinox.common_3.2.0.v20060603.jar;
/instance/org.eclipse.jdt.ui/formatter_profile=_Philippe
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_declaration_throws=inse rt
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_allocation_expression=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskPriorities=NORMAL,HIGH,NORMAL,LOW
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_package=0
/project/PDAProtection/org.eclipse.jdt.core/org.eclipse.jdt. core.compiler.codegen.targetPlatform=1.1
/project/BEST/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.problem.indirectStaticAccess=ignore
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.alignment_for_arguments_in_enum_c onstant=16
/instance/org.eclipse.jdt.launching/PREF_VM_INSTALL_SYSTEM_P ROPERTY.com.ibm.ive.internal.j9.launcher.J9VMType.1164289867 828.java.specification.name=J2ME
Personal Profile Specification
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_ellipsis=do
not insert
/project/BEST/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.problem.forbiddenReference=error
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_method_declaration=in sert
/instance/org.eclipse.jdt.ui/internal.default.compliance=def ault
@org.eclipse.jdt.core=3.2.1.v_677_R32x
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_comma_in_mult iple_field_declarations=do
not insert
/instance/org.eclipse.ant.ui/anteditor.filterProperties=true
/project/test/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.debug.lineNumber=generate
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=bayesia12.Local
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_paren _in_catch=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_labeled_statement=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_then_statement_on_same_line=false
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.ui/intern al.default.compliance=default
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_question_in_wildcard=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_paren _in_while=insert
/project/Protection/org.eclipse.jdt.core/org.eclipse.jdt.cor e.compiler.debug.lineNumber=generate
/instance/org.eclipse.team.core/cvs_mode_for_file_without_ex tensions=passwd\n1\npackage-list\n2\n
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_paren _in_enum_constant=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_comma_in_enum_ constant_arguments=insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_closing_brack et_in_array_reference=do
not insert
/instance/org.eclipse.pde.runtime/orderType=2
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.compiler.problem.enumIdentifier=ignore
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.comment.format_source_code=true
@org.eclipse.ve.cde=1.2.0.v20060918_M
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_between_empty_parens _in_constructor_declaration=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.comment.indent_parameter_descript ion=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_expressions_in_array_initializer=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_assert=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_for=do
not insert
/project/BEST/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.problem.unusedLocal=ignore
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_comma_in_arra y_initializer=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.alignment_for_compact_if=16
/instance/com.omondo.database/com.omondo.database.preference .reverse.encoding.longvarchar=Character
/project/BEST/org.eclipse.core.resources/encoding//help/auth or/BAHelpTOC.xml=UTF-8
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=C\:/temp/ppctemp/build/x86/ppro10/lib/jclP Pro10/source/source.zip
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unusedPrivateMember=ignore
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_TEST_CORE=C\:\\eclipse\\calisto\\plugins\\org.eclipse.hya des.test.core_4.2.0.v200606131519
/instance/com.omondo.database/com.omondo.database.save.with. xml.extension=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_static_variables=true
/instance/org.eclipse.mylar.tasks.ui/org.eclipse.mylar.taskl ist.backup.lastarchived=1165937408859
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_breaks_compare_to_cases=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_parameterized_type_reference= do
not insert
/instance/org.eclipse.pde.core/saved_platform1=c\:\\eclipse
/instance/org.eclipse.pde.core/saved_platform0=D\:\\eRCP-v20 050727\\x86\\eRCP-M3
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_constructor_declaratio n=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_enum_constant_arguments=insert
/instance/com.omondo.database/com.omondo.database.edit.when. created=false
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.brace_position_for_type_declarati on=end_of_line
/instance/org.eclipse.hyades.trace.ui/refresh_type=1
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_brack et_in_array_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_default=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_comma_in_metho d_declaration_throws=insert
/instance/com.omondo.database/com.omondo.database.torque.def ault.base.class=BaseObject
/instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
/instance/com.omondo.database/com.omondo.database.preference .reverse.encoding.array=Hexadecimal
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _SWT=C\:\\eclipse\\calisto\\plugins\\org.eclipse.swt_3.2.0.v 3232o.jar;C\:\\eclipse\\calisto\\plugins\\org.eclipse.swt.wi n32.win32.x86_3.2.0.v3232m.jar;
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.comment.line_length=400
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_brace _in_method_declaration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_superinterfaces_in_enum_declaration=16
/project/JavaProxy/org.eclipse.jdt.core/org.eclipse.jdt.core .compiler.problem.assertIdentifier=ignore
/project/BEST/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.debug.sourceFile=generate
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_assignment_operator=insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_new_line_in_empty_enum_dec laration=insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_comma_in_allo cation_expression=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_new_line_before_while_in_d o_statement=do
not insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.format_guardian_clause_on_one_lin e=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_before_else_in_if_statement=do
not insert
/project/Printing/org.eclipse.jdt.core/org.eclipse.jdt.core. compiler.source=1.3
/project/test/org.eclipse.jdt.ui/internal.default.compliance =default
/instance/org.eclipse.team.cvs.ui/pref_text_ksubst=-kk
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_angle_bracket_in_type_paramete rs=do
not insert
/project/Printing/org.eclipse.jdt.core/org.eclipse.jdt.core. compiler.debug.sourceFile=generate
/instance/org.eclipse.core.resources/version=1
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_new_line_after_annotation= insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_annotation=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_postfix_operator=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.clear_blank_lines=false
/project/PDAProtection/org.eclipse.jdt.core/org.eclipse.jdt. core.compiler.debug.localVariable=generate
/instance/org.eclipse.ant.core/ant_home=C\:\\eclipse\\eclips e\\plugins\\org.apache.ant_1.6.5
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_declaration_parameters= insert
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_after_opening_paren_ in_switch=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_colon_in_labeled_statement=insert
/instance/com.omondo.database/com.omondo.database.index.view =true
/project/ercpBestPDATroubleShooter/org.eclipse.jdt.core/org. eclipse.jdt.core.formatter.insert_space_before_opening_angle _bracket_in_type_arguments=do
not insert
/instance/org.eclipse.jst.ws.consumption.ui/PREFERENCE_SERVE R=org.eclipse.jst.server.tomcat.55
/project/BEST/org.eclipse.jdt.core/org.eclipse.jdt.core.comp iler.problem.finalParameterBound=ignore
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=D\:/eRCP-v20050727/x86/eRCP-M3
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_LOGGING_PARSERS=C\:\\eclipse\\calisto\\plugins\\org. eclipse.hyades.logging.par
Re: VE customize layout problem [message #134189 is a reply to message #134152] |
Fri, 15 December 2006 05:46  |
Rich Kulp a écrit :
> Try clearing the cache.
> 1) Open a VE and then close it all other VE's.
> 2) Do Project_>Clean...->Clean All Projects and wait for build to complete
> 3) Open a VE.
Thanks it's work fine !
Re: VE customize layout problem [message #614858 is a reply to message #134107] |
Thu, 14 December 2006 11:59  |
3) Open a VE.
Rich Kulp
Re: VE customize layout problem [message #614861 is a reply to message #134152] |
> 3) Open a VE.
Current Time: Sat Jul 19 20:14:46 EDT 2025
Powered by FUDForum. Page generated in 0.04826 seconds
