directedit and connection [message #133811] |
Mon, 24 May 2004 07:32  |
Originally posted by: m.hassenforder.uha.fr
hello,
a little question about connection.
I have a connection and around it some labels.
I use the same pattern (special Locater) as that described in the
article "Display a UML Diagram using Draw2D".
Now I am faced with the DirectEdit problem.
The editPart subscribes one and only one DIRECTEDIT request but I have
find the right label (one over about not less than 5)) according to the
mouse click.
Who have to make such a lookup (me or GEF ...). I guess it is my job,
but where is the best place ?
thanks in advance
Re: directedit and connection [message #134375 is a reply to message #134180] |
Wed, 26 May 2004 03:25   |
hello,
Just for information, I have not less than 5 labels inside the
connection. So have too make something good not just a hack, and that is
my problem.
I forward the point obtained by the request.getLocation() to the figure
which calls the findFigure method and I obtain the good Label.
But now I am faced with another problems :
how to update the underlying label during direct edition (using
showCurrentEditValue of the directEditPolicy). The Figure knows about
the different labels (it create them), and knows about the association
String/Figure. The editPart knows about string but nothing about labels
(it job is to forward the string to the connection which convert it into
a label) and the association String/label is made internally by the
figure. I am not sure if I am clear : but currently to find the label to
update I have to lookup the figure associated to the editPart associated
to the policy. This is not really nice. If I break something, the
editpart has too much knowledges about the internals of the figure. This
is my first dilemna.
how to update the string in the model. I have 1 method per string to
update in the model. Another time, I have to lookup the label which is
in the figure to find the good method. This is not nice too.
If I remember the directEditRequest has a feature field which could be
used for such a problem, but nobody set it (in 2.1.x). But two
DirectEditRequest are created : one to initiate the directEdit and one
to terminate the directEdit. This is not cool as I have to copy the
feature field between the two creations, and it looks like a hack.
I hope I have clearly explained the problem.
Randy Hudson wrote:
> Sorry. In general we have no idea which figures you are using for your
> graphical editpart, or how many properties are direct-editable.
> "Hassenforder" <m.hassenforder@uha.fr> wrote in message
> news:c8upod$uru$1@eclipse.org...
>>hello randy,
>>thank you for the reply, but I hope that GEF do it automaticly for me.
>>I will implement such a solution.
>>Randy Hudson wrote:
>>>The request will contain the mouse location in absolute coordinates.
> All
>>>you have to do is hit-test the different labels to figure out which one
> to
>>>edit.
>>>label.translateToRelative(copyOfPoint);
>>>if (label.containsPoint(copyOfPoint))
>>> //edit the label
>>>news:c8sm1j$sge$1@eclipse.org...
>>>>hello,
>>>>mouse click.
>>>>thanks in advance
Re: directedit and connection [message #135233 is a reply to message #134375] |
Mon, 31 May 2004 21:04   |
news:c91ga5$4dl$1@eclipse.org...
> hello,
> my problem.
> figure.
Ok, great separation. So the connection figure needs to provide more
services to the editpart. Add some more API for the editpart to use. Such
as getLabelPropertyAt(Point).
Yes, there is a discriminator field on the direct edit request for these
purposes. If it doesn't work, open a bugzilla.
> >>hello randy,
> > All
> > to
FUDForum. Page generated in 0.06187 seconds
