Home » Eclipse Projects » GEF » Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does?
Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does? [message #133739] Sun, 23 May 2004 22:33 Go to next message
Originally posted by: xietao.sjtu.edu.cn
hi,all!
Now I have developed a plugin and I want to add a view that can display
figures like GraphicalEditor does,how can I make it?
Any response is appreciated!
Re: Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does? [message #133752 is a reply to message #133739] Mon, 24 May 2004 02:24 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
Yes. I haven't tried that - but I would start with looking at
LightweightSystem and GraphicalViewer hierarchy.
"Bruce" <xietao@sjtu.edu.cn> wrote in message
news:c8rmhn$f53$1@eclipse.org...
> hi,all!
Re: Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does? [message #133900 is a reply to message #133739] Mon, 24 May 2004 14:46 Go to previous messageGo to next message
You can create a GEF viewer on any SWT Composite. For creating an editor,
you extend EditorPart, create a GEF viewer and give it the "editor control"
(in the viewer's createControl(...) method). You would do the exact
samething for a view. Extend ViewPart (or a subclass thereof), and give the
view's control to the GEF viewer.
> hi,all!
Re: Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does? [message #137352 is a reply to message #133900] Wed, 09 June 2004 10:56 Go to previous messageGo to next message
Got a basic viewer working with no problems. However, I'd now like to make
the figures/editParts selectable. Even with the correct editPolicies
installed etc. the mosue events are not received. The viewer routes all
the events to the EditDomain but as I'm using a ViewPart and not an
EditPart I can't create a DefaultEditDomain. If i
setRouteEventstoEditDomain(false), i get a null pointer exception as
there's no EventDispatcher.
I looked at overriding the Viewer to change the eventDispatcher but the
relevant methods are deprecated.
What's the recommended way of doing this? I think what I need is a
"ViewDomain".
Is there an easier way to do this? All i really want is to pick up a
doubleClick on an editPart (normally performRequest(REQ_OPEN)).
Chris
> > hi,all!
Re: Can a view (ViewPart)do the works that GraphicalEditor(EditorPart) does? [message #137385 is a reply to message #137352] Wed, 09 June 2004 13:35 Go to previous message
What you want is EditDomain, not DefaultEditDomain.
"Chris Heald" <chris.heald@m.eads.net> wrote in message
news:ca78eq$gk8$1@eclipse.org...
> "ViewDomain".
> Thanks
> Chris
editor,
control"
the
> > > hi,all!
does?
display
Previous Topic:Complex Figures problem
Next Topic:TextFlow
Current Time: Sun Jul 20 06:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.04396 seconds
