Home » Archived » Visual Editor (VE) » VE brings up Print dialog
VE brings up Print dialog [message #133305] Mon, 20 November 2006 13:27 Go to next message
Originally posted by: joe.coughlin.itt.com
When I open a class using VE, I often get a print dialog (or sometimes another dialog) before the display will properly render. I have a method call within the class to start a print thread which opens a print dialog. Could this be doing it? Any ideas how to turn off this feature?
Re: VE brings up Print dialog [message #133446 is a reply to message #133305] Thu, 23 November 2006 16:25 Go to previous messageGo to next message
Originally posted by: spider_a.freenet.am
Same thing I've here on my PC, I've tried to remove it lot of times, NO success :(
Re: VE brings up Print dialog [message #133533 is a reply to message #133446] Mon, 27 November 2006 11:08 Go to previous message
We are actually executing any (most) classes that you reference in your
code that is being edited. That is how we get WYSIWYG. If certain code
is being executed that you don't want to execute while in design mode,
then surround that code with:
if (!Beans.isDesignTime()) {
... your code ...
During VE design time, the isDesignTime() will return true. When your
code is running in normal runtime, the isDesignTime() will return false.
Rich Kulp
Re: VE brings up Print dialog [message #614804 is a reply to message #133305] Thu, 23 November 2006 16:25 Go to previous message
Re: VE brings up Print dialog [message #614811 is a reply to message #133446] Mon, 27 November 2006 11:08 Go to previous message
... your code ...
Rich Kulp
Previous Topic:how to prevent the generation of default constructor
Next Topic:Automatically generated UI code
Current Time: Sat Jul 19 12:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.24586 seconds
