Home » Modeling » Epsilon » [EMC] CSV driver not writing rows
[EMC] CSV driver not writing rows [message #1332595] Sun, 04 May 2014 14:33 Go to next message
Using the latest CSV driver source I was creating a standalone application using ETL to transform contents from a plain XML model to a CSV model.
The CSV model has a header but was otherwise empty.
Then ETL attempted to persist the contents to the CSV file but it failed:
Exception in thread "main" java.util.NoSuchElementException
	at java.util.LinkedList.getFirst(Unknown Source)
	at org.eclipse.epsilon.emc.csv.CsvModel.createInstanceInModel(CsvModel.java:323)
	at org.eclipse.epsilon.emc.csv.CsvModel.createInstanceInModel(CsvModel.java:1)
	at org.eclipse.epsilon.eol.models.CachedModel.createInstance(CachedModel.java:117)
	at org.eclipse.epsilon.eol.types.EolModelElementType.createInstance(EolModelElementType.java:168)
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.transformModels(FastTransformationStrategy.java:121)
	at org.eclipse.epsilon.etl.EtlModule.execute(EtlModule.java:127)
	at example.EpsilonStandaloneExample.execute(EpsilonStandaloneExample.java:72)
	at example.EpsilonStandaloneExample.execute(EpsilonStandaloneExample.java:64)
	at example.transformation.xml2csv.XmlCsvEtlStandaloneExample.main(XmlCsvEtlStandaloneExample.java:31)
Looking at the source of CsvModel I implemented a short fix by defining a list holding the header information - PFA the solution that worked for me.
Martin
  • Attachment: CsvModel.java
    (Size: 15.13KB, Downloaded 188 times)
[Updated on: Mon, 05 May 2014 10:02] by Moderator
Re: [EMC] CSV driver not writing rows [message #1335058 is a reply to message #1332595] Mon, 05 May 2014 17:48 Go to previous message
Hi Martin,
Thanks for reporting this and for contributing a patch. I'll add a couple of tests for this and commit the fix shortly.
Dimitris
Previous Topic:GMF node disappears
Next Topic:EOL: Loading model from a ResourceSet
Current Time: Sun Jul 20 11:31:18 EDT 2025
Powered by FUDForum. Page generated in 0.06079 seconds
