Question about translating the plug-in manifest [message #133443] |
Tue, 19 May 2009 06:30  |
Originally posted by: benjamin.wolff.web.de
hi,
i have a question concerning the plug-in manifest translation.
in my application i make extensive use of command and menuContribution
extension points. like the name of views, perspectives etc. there
are end-user representable strings defined in the plugin.xml for menus
and commands.
one demand of the application is to choose between english and german
language for the UI during login, a usual case of internationalization i think.
since this seems to work well with RAP in conjunction with translatable
strings in the java code (with the NLS class) i don't exactly see how
can i achieve such an i18n for the plugin.xml strings.
i need to translate these strings (which are notated for example %courseView.title,
and located in a *.properties file) on a per-rap-session basis.
after reading the RAP i18n guide ( http://help.eclipse.org/ganymede/topic/org.eclipse.rap.help/ help/html/advanced/internationalization.html)
i dont really see how this can be accomplished. is it basically possible what i'm trying
to achieve? is the article mentioned above still up-to-date?!
do i have to/can i use e.g. plugin_de_DE.properties files in my classpath?!
moreover, i planned to set the locale during login (rap-ui-session already created)
by setting RWT.setLocale(Locale.GERMAN);
does this reflect on the RWT.NLS class or where does this class get
the language information??!
would be great if someone could shed some light on this :). thx!
greetings,
ben
Re: Question about translating the plug-in manifest [message #133457 is a reply to message #133443] |
Tue, 19 May 2009 07:08   |
Hi Ben,
did you add the bundle org.eclipse.equinox.rap.registry [1] to your
application? This patches the default translation handling as per
default, translated strings are hold statically.
Stefan.
[1] CVS: /cvsroot/rt/org.eclipse.rap/runtime.ui/
Ben W. schrieb:
> hi,
> and commands.
> think.
> %courseView.title,
> what i'm trying
> already created)
> greetings,
> ben
Re: Question about translating the plug-in manifest [message #133497 is a reply to message #133457] |
Tue, 19 May 2009 08:10   |
hi stefan,
it works!! thanks a lot!
so i'll sum up my results in case someone is interested in this issue:
1. internationalize strings in the java code (buttons, messages etc.) works like a charm as described
in the RAP i18n guide [1]
2. the RWT#NLS class works with the RWT#getLocale() method to determine which language to use.
so setting the locale manually to e.g. RWT.setLocale(Locale.GERMAN) (during e.g. a login process)
the strings from a *_de.properties file are used, the same is true for Locale.ENGLISH
and a *_en.properties file.
3. to internationalize the plug-in manifest (strings in plugin.xml and manifest.mf) the following steps
are required:
- checkout org.eclipse.equinox.registry as a source project [2]
- checkout org.eclipse.rap.equinox.registry as a source project [3]
- add these two bundles to your launch configuration, be careful to use the org.eclipse.equinox.registry
bundle from the workspace, not from the target platform!
- now the plug-in manifest will be translated on a per-rap-session base. one can use plugin_de.properties
and plugin_en.properties for example in conjunction with Locale.GERMAN and Locale.ENGLISH. works like a charm!
- don't forget to add 'Bundle-Localization: plugin' to the manifest.mf file of your RAP application
[1] http://help.eclipse.org/ganymede/topic/org.eclipse.rap.help/ help/html/advanced/internationalization.html
[2] CVS: /cvsroot/rt/org.eclipse.equinox/components/bundles/org.eclip se.equinox.registry
[3] CVS: /cvsroot/rt/org.eclipse.rap/runtime.ui/org.eclipse.rap.equin ox.registry
there is one question though, when running the application the following message is displayed:
!ENTRY org.eclipse.equinox.registry 2 0 2009-05-19 13:54:31.475
!MESSAGE The extensions and extension-points from the bundle "org.eclipse.rap.equinox.registry" are ignored. The bundle is not marked as singleton.
can this be ignored or should i be nervous about that? :)
greetings,
ben
Stefan Roeck schrieb:
> Hi Ben,
> Regards,
> Stefan.
> Ben W. schrieb:
>> hi,
>> and commands.
>> i think.
>> %courseView.title,
>> classpath?!
>> already created)
>> greetings,
>> ben
FUDForum. Page generated in 0.25271 seconds
