Home » Modeling » Graphiti » Highlighting of Anchors(My anchors don't get highlighted when hovering with the connection tool)
Highlighting of Anchors [message #1334680] Mon, 05 May 2014 14:01 Go to next message
I'm migrating/merging to the current Graphiti HEAD from an custom branch originally I forked about two years ago. Almost all is going quite smoothly, except for highlit of anchors during connection creation.
Some related issues
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363186
https://bugs.eclipse.org/bugs/show_bug.cgi?id=329517
I'm still struggling to understand how it's supposed to (currently) work. I understand that
XToolBehaviorProvider.getSelectionInfoForAnchor()
is supposed to be called when hovering... but it doesn't.
Specifically, I get the tutorial code and its TutorialToolBehaviorProvider
(overriding the getSelectionInfoFor* to log the callings) and I get that only
getSelectionInfoForShape() is called, not getSelectionInfoForAnchor or
getSelectionInfoForConnection
My questions then, for now, are:
- When are those functions supposed to be called? (their docs don't say more that then method names) - and their names suggest they are called when the shape is selected ("selection info"), but they are also called for hovering?
- It's ok that in the tutorial they don't get called?
- Is there some example that show how to highlit anchors on connection creation (source or target)?
If this helps: I see that in my old working code, the highlit-on-hovering was triggered by GFAbstractShape.adaptBackgroundToHover(), but now (in the tutorial) when I hover with the Connection (EReference) over the anchor (and the connection tool pointer changes to "enabled") the method is only called with the value getHoverFeedback() = IVisualState.HOVER_OFF - and hence nothing happens. I'm not sure if this is correct behaviour.
[Updated on: Mon, 05 May 2014 14:56] by Moderator
Re: Highlighting of Anchors [message #1334751 is a reply to message #1334680] Mon, 05 May 2014 14:44 Go to previous messageGo to next message
One thing I've noticed: (still not enough for me) is that the "new" (for me) AdvancedAnchorEditPart that seems to have replaced the AnchorEditPart and its subclases, does not override the methods eraseSourceFeedback showTargetFeedback and similar, while the old AnchorEditPart did thus:
	public void eraseSourceFeedback(Request request) {
		super.eraseSourceFeedback(request);
		delegate.getVisualState().setHoverFeedback(IVisualState.HOVER_OFF);
	public void eraseTargetFeedback(Request request) {
		super.eraseTargetFeedback(request);
	public void showSourceFeedback(Request request) {
		super.showSourceFeedback(request);
		delegate.getVisualState().setHoverFeedback(IVisualState.HOVER_ON);
	public void showTargetFeedback(Request request) {
		super.showTargetFeedback(request);
Is this OK?
Re: Highlighting of Anchors [message #1334836 is a reply to message #1334751] Mon, 05 May 2014 15:31 Go to previous messageGo to next message
Another difference is that the old GFAbstractShape.adaptBackgroundToHover() considered anchors, while the current one doesn't:
Current
private boolean adaptBackgroundToHover(Graphics graphics) {
  if (getVisualState().getHoverFeedback() == IVisualState.HOVER_ON) {
    if (!(pe instanceof org.eclipse.graphiti.mm.pictograms.Shape))
      return false;
    org.eclipse.graphiti.mm.pictograms.Shape s = (org.eclipse.graphiti.mm.pictograms.Shape) pe;
    ISelectionInfo selectionInfo = tbp.getSelectionInfoForShape(s);
    IColorConstant hoverColor = null;
OLD
    ISelectionInfo selectionInfo = null;
    if (pe instanceof org.eclipse.graphiti.mm.pictograms.Shape)
      selectionInfo = tbp.getSelectionInfoForShape((org.eclipse.graphiti.mm.pictograms.Shape) pe);
    else if (pe instanceof org.eclipse.graphiti.mm.pictograms.Anchor)
      selectionInfo = tbp.getSelectionInfoForAnchor((org.eclipse.graphiti.mm.pictograms.Anchor) pe);
    else
      return false;
If I replace the current lines by the older ones (and add the changes of the previous post to AdvancedAnchorEditPart) I get my desired behaviour.
Again, I don't know if this is right.
[Updated on: Mon, 05 May 2014 15:41] by Moderator
Re: Highlighting of Anchors [message #1339122 is a reply to message #1334680] Wed, 07 May 2014 10:29 Go to previous messageGo to next message
As I said above, I'm not sure if there were valid reasons for having removed the Anchors from the valid targets for GFAbstractShape.adaptBackgroundToHover() , so I'm unsure about filling a bug for this.
Anyway, I suggest to include the following to the tutorial
TutorialToolBehaviorProvider :
	 * Highlight of anchors
	public IAnchorSelectionInfo getSelectionInfoForAnchor(Anchor anchor) {
		IAnchorSelectionInfo si = super.getSelectionInfoForAnchor(anchor);
		si.setHoverColor(IColorConstant.DARK_BLUE);
		si.setHoverColorParentSelected(si.getHoverColor());
		return si;
This is not only a useful contribution for the tutorial, but also shows the issue.
With the current master branch, nothing happens. With my two fixes ( GFAbstractShape.adaptBackgroundToHover() + AdvancedAnchorEditPart ) it works as expected. Or at least, as I'd expect Smile
Re: Highlighting of Anchors [message #1341524 is a reply to message #1339122] Thu, 08 May 2014 10:23 Go to previous messageGo to next message
Hernan,
that is at least strange and I what I can say without haveing a detailed
look into the coding, I'd guess this is an oversight in the new
implementation and a gap.
Could you please file a bug for this and provide the code snippets there?
That is also a requirenent of the Eclipse IP process to allow us to use your
coding.
Michael
Re: Highlighting of Anchors [message #1341659 is a reply to message #1341524] Thu, 08 May 2014 11:39 Go to previous message
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=434436
Previous Topic:Property Sheet & Buttons
Next Topic:View Menu: Grid and SnapToGeometry entries
Current Time: Sun Jul 20 13:13:21 EDT 2025
Powered by FUDForum. Page generated in 0.60347 seconds
