Home » Archived » Visual Editor (VE) » No SWT items in VE
No SWT items in VE [message #133104] Mon, 13 November 2006 19:32 Go to next message
Originally posted by: forrestline.gmail.com
I'm missing SWT items in the palette. Trying to create a new project and a
new visual class. Seems to be ok, it runs. However no SWT entries in
palette in Visual Editor.
The suggestion I found in previous threads, to create such file after
installing the plugin does not work for me, since I got the eclipse with
the plugin installed.
Sincerely,
Evgeny
Re: No SWT items in VE [message #133152 is a reply to message #133104] Tue, 14 November 2006 10:07 Go to previous messageGo to next message
Use the New Visual Class wizard and make sure you select an SWT style
from the Style tree. That should set up your classpath in your project
so that SWT works.
Evgeny wrote:
> a new visual class. Seems to be ok, it runs. However no SWT entries in
> Sincerely,
> Evgeny
Rich Kulp
Re: No SWT items in VE [message #133179 is a reply to message #133152] Tue, 14 November 2006 13:46 Go to previous messageGo to next message
Thanks.
It worked. I had to add SWT support as Library, not as external Jar.
However I see another problem here.
If I crate a Swing window, I get nice visual representation. But not with
SWT.
See the link with screenshots:
http://www.box.net/public/b30hzdzqj6#main
Any ideas?
Thanks.
Re: No SWT items in VE [message #133202 is a reply to message #133179] Tue, 14 November 2006 13:50 Go to previous messageGo to next message
It may be confused because of the SWT that was added as a jar, try
clearing the cache first.
1) Open one VE, then close it and all other VE's.
2) Then do Project->Clear...->Clear all projects, and then wait for
build to complete.
3) Try the VE now.
Evgeny wrote:
> Thanks.
> with SWT.
> Any ideas?
> Thanks.
Rich Kulp
Re: No SWT items in VE [message #133241 is a reply to message #133202] Thu, 16 November 2006 22:11 Go to previous message
I tried to do as suggested with no success. Same thing.
Anything esle i could try ?
Thank you. I appreciate your help.
Re: No SWT items in VE [message #614781 is a reply to message #133104] Tue, 14 November 2006 10:07 Go to previous message
so that SWT works.
Evgeny wrote:
> Sincerely,
> Evgeny
Rich Kulp
Re: No SWT items in VE [message #614783 is a reply to message #133152] Tue, 14 November 2006 13:46 Go to previous message
Thanks.
SWT.
Any ideas?
Thanks.
Re: No SWT items in VE [message #614785 is a reply to message #133179] Tue, 14 November 2006 13:50 Go to previous message
build to complete.
3) Try the VE now.
Evgeny wrote:
> Thanks.
> with SWT.
> Any ideas?
> Thanks.
Rich Kulp
Re: No SWT items in VE [message #614788 is a reply to message #133202] Thu, 16 November 2006 22:11 Go to previous message
Previous Topic:Renamed vars and VE no longer "sees" them
Next Topic:Extend VE to accommodate any two widgets with code generation. With respect
Current Time: Sun Jul 20 19:01:40 EDT 2025
Powered by FUDForum. Page generated in 0.08916 seconds
