Home » Eclipse Projects » Equinox » Re: Migrating a Europa custom installer to Galileo P2
Re: Migrating a Europa custom installer to Galileo P2 [message #132376] Thu, 04 June 2009 09:02 Go to next message
Derek wrote:
> We are starting to migrate our product from Europa to Galileo (we missed
> out Ganymede).
> Our product consists of RCP, our plugins and a large collection of files
> (executables, data file, etc) outside of the Eclipse install.
> For Europa, we wrote a custom InstallHandler that is invoked by the
> update process and allows us to update the 'external' files. This is
> working extremely well. We also use a similar facility to install
> additional (optional) functionality from our update site - it installs
> both the plugins and additional external files.
> We would like to do something similar with Galileo/P2:
> - is this possible?
> - are there any articles explaining how?
> - any hints on where to start?
> Thanks!
I've re-routed to e.t.equinox where the p2 people live. Basically, you
would be using p2 in 3.5. http://wiki.eclipse.org/Category:Equinox_p2
is the category for p2 articles.
http://wiki.eclipse.org/Equinox/p2/Engine/Touchpoint_Instruc tions is the
p2 replacement for install handlers.
There are a few ant tasks that can take a current site.xml and generate
the correct p2 repository ... and then the extra work to write your
"native" touchpoints, I think.
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: Migrating a Europa custom installer to Galileo P2 [message #132930 is a reply to message #132376] Fri, 12 June 2009 08:59 Go to previous message
Paul Webster wrote:
> Derek wrote:
>> Hi,
>> missed out Ganymede).
>> files (executables, data file, etc) outside of the Eclipse install.
>> - is this possible?
The concepts you are looking for are called "install handlers" in p2 as
well (also refered to as "meta requirements") and it allows an
installable unit to declare requirements on units that must be installed
prior to running the rest of the installation.
The neat thing is that the "install handlers" are just regular
installable units and sort of gives the same result as if the user first
installed them, and then the rest of the installation - only that the
user sees it as one operation.
Secondly, when using p2 to install, it invokes touchpoint actions to
perform the actual install. To invoke custom actions you need to
implement at least a touchpoint action, but possibly also a custom
touchpoint if you need additional things not provided in say the native
touchpoint.
As a starting point, take a look at how some of the p2 native actions
are implemented - like unzip, copy, etc.
I know there are articles and examples being worked on for Galileo release.
- henrik
Previous Topic:[Update Site] metadata
Next Topic:Proxy Authenication details not saved
Current Time: Sat Jul 19 13:44:50 EDT 2025
Powered by FUDForum. Page generated in 0.04050 seconds
