Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Is org.eclipse.ocl.ecore for equinox only?(Is there a way to make org.eclipse.ocl.ecore work in Felix?)
Is org.eclipse.ocl.ecore for equinox only? [message #1328091] Fri, 02 May 2014 10:00 Go to next message
I just encountered a very nasty surprise. I am using some third party bundles that depend on the org.eclipse.ocl.ecore, which in turn depends on org.eclipse.runtime. The bundles in question run nicely in equinox but not in Felix. Class casting exceptions arise when one tries this. The tragedy is I have other bundles that are fine in Felix but problematic in equinox. To top it off, Felix is my production platform.
Everything works great outside OSGi.
Thanks all
Re: Is org.eclipse.ocl.ecore for equinox only? [message #1328197 is a reply to message #1328091] Fri, 02 May 2014 11:14 Go to previous messageGo to next message
Please use the OCL newsgroup for OCL discussion.
However this seems like an Equinox issue.
There is very little/no significant OSGi code in org.eclipse.ocl.ecore
so I suspect that the problem lies in your launcher. After all it can be
run standalone. Does EMF work fin? What are the CCEs ?
Bottom line. If you want to run in an unsupported configuration you may
have to debug the problems. Please report back with any useful solutions.
Ed Willink
> Thanks all
Re: Is org.eclipse.ocl.ecore for equinox only? [message #1328248 is a reply to message #1328197] Fri, 02 May 2014 11:48 Go to previous messageGo to next message
Thanks Ed,
Yes, EMF works fine. it's the *ocl* clutch of bundles that are at issue. Everyone of them requires org.eclipse.runtime.
I'll look for the ocl group and try again.
Re: Is org.eclipse.ocl.ecore for equinox only? [message #1328249 is a reply to message #1328248] Fri, 02 May 2014 11:49 Go to previous messageGo to next message
If EMF works fine, its probably a silly problem.
What are the CCEs?
Ed Willink
On 02/05/2014 16:48, Geoffry Roberts wrote:
> Thanks Ed,
Re: Is org.eclipse.ocl.ecore for equinox only? [message #1328273 is a reply to message #1328249] Fri, 02 May 2014 12:00 Go to previous messageGo to next message
Actually it's not just a silly problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=328227
But it looks like I'm close to a solution that would make model and edit
bundles work in Equinox or in any OSGi container.
To support this fully does require changes in existing MANIFEST.MF as
well as changes in the bundle activator implementations, but hopefully
there will be a generated solution for all those things.
On 02/05/2014 5:49 PM, Ed Willink wrote:
> Hi
> What are the CCEs?
> Regards
> Ed Willink
>> Thanks Ed,
Re: Is org.eclipse.ocl.ecore for equinox only? [message #1328380 is a reply to message #1328273] Fri, 02 May 2014 13:11 Go to previous message
"it's a silly problem" was predicated on "EMF works fine". Clearly it
doesn't.
Good to see someone working on it. Hopefully the solution will be useful
for derived EMF projects too.
Ed Willink
> edit bundles work in Equinox or in any OSGi container.
>> Hi
>> What are the CCEs?
>> Regards
>> Ed Willink
>>> Thanks Ed,
Previous Topic:Prevent generating the extension_parser extension point
Next Topic:[EMFStore] authentication and authorization
Current Time: Sat Jul 19 16:37:06 EDT 2025
Powered by FUDForum. Page generated in 0.04964 seconds
