VE Path Must Include... Error [message #132730] |
Wed, 01 November 2006 13:52  |
I have a complex RCP Editor that was built with the VE but will not longer
open, giving a "Path must include project and resource name:" error. If I
copy the source to another file in the same directory (renaming class, etc.)
it will open in the VE but 2 of 3 tabs in a folder don't show (though all 3
did when the editor was created). There are no differences other than
file/class name now and one opens and one doesn't.
Is there a cache the VE keeps somewhere? Is there anything else I should
look at?
Any and all help appreciated. It is hard to convince people this is easy to
do with a gui editor when the gui won't open any more! :-(
Joe Skora
joseph.skora@jhuapl.edu
Re: VE Path Must Include... Error [message #132766 is a reply to message #132756] |
Thu, 02 November 2006 22:18  |
Amazing. That did it. Can I have all those hours back now too?
Seriously, I must admin, having used Eclipse for a couple of years on small
stuff, we are looking toward moving to JDeveloper and it has always been
awkward to use. Looking into RCP lately with Eclipse (again thank goodness)
I have been surprised at the solidness and transparency of it all. When
something doesn't work, I can usually trace whats wrong or what I didn't do.
Unfortunately, I haven't (don't know if I want to) actually debugging the
development environment itself.
Many thanks,
Joe
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:eid5kc$1ft$1@utils.eclipse.org...
> Go into your plugin.xml and provide an icon for your view class
> (org.eclipse.ui.views extension point).
> Then please open a defect against VE because we don't handle a view class
> defined but no icon defined for it.
> Rich Kulp
Re: VE Path Must Include... Error [message #614750 is a reply to message #132730] |
Wed, 01 November 2006 14:50  |
Pertinent error log entries for this problem are:
!ENTRY org.eclipse.jem.proxy 2 0 2006-11-01 14:49:50.807
!MESSAGE
+++ Warning +++: Wed Nov 01 14:49:50 EST 2006 Project
(edu.jhuapl.itsd.Planning)-VM for edu.jhuapl.itsd.Planning:err>
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption--
Error code:7 Value data:"java.lang.IllegalArgumentException:Path must
include project and resource name: /edu.jhuapl.itsd.Planning"
at
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
at
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
at
org.eclipse.ve.internal.swt.targetvm.DisplayExec$1.run(Displ ayExec.java:111)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
at
org.eclipse.ve.internal.swt.targetvm.DisplayExec$ExecRunnabl e.run(DisplayExec.java:109)
!ENTRY org.eclipse.jem.proxy 2 0 2006-11-01 14:49:51.119
!MESSAGE
+++ Warning +++: Wed Nov 01 14:49:51 EST 2006 Project
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:121)
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-01 14:49:51.197
!MESSAGE Exception thrown.
!STACK 0
java.lang.IllegalArgumentException: Path must include project and resource
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:62)
at
org.eclipse.core.internal.resources.Workspace.newResource(Wo rkspace.java:1571)
at
org.eclipse.core.internal.resources.Container.getFile(Contai ner.java:116)
at
org.eclipse.ve.internal.java.vce.PDEUtilities.getIconPath(PD EUtilities.java:132)
at
org.eclipse.ve.internal.rcp.WorkbenchPartLabelProvider.getIm age(WorkbenchPartLabelProvider.java:41)
at
org.eclipse.ve.internal.cde.emf.DefaultTreeEditPart.getImage (DefaultTreeEditPart.java:133)
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.getIm age(JavaBeanTreeEditPart.java:279)
at
org.eclipse.gef.editparts.AbstractTreeEditPart.refreshVisual s(AbstractTreeEditPart.java:137)
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.refre shVisuals(JavaBeanTreeEditPart.java:313)
at
org.eclipse.ve.internal.cde.emf.DefaultTreeEditPart.activate (DefaultTreeEditPart.java:64)
at
org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.activ ate(JavaBeanTreeEditPart.java:103)
at
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:152)
at
org.eclipse.ve.internal.java.core.CompositionComponentsTreeE ditPart.activate(CompositionComponentsTreeEditPart.java:66)
at
org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsTreeEditPart.activate(SubclassCompositionComponentsTreeEdi tPart.java:66)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2098)
at
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.ui 4 4 2006-11-01 14:49:51.228
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-11-01 14:49:51.228
!MESSAGE Failed to execute runnable (java.lang.IllegalArgumentException:
Path must include project and resource name: /edu.jhuapl.itsd.Planning)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.IllegalArgumentException: Path must include project and resource
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at
at
at
at
at
at
at
at
Caused by: java.lang.IllegalArgumentException: Path must include project and
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 20 more
Re: VE Path Must Include... Error [message #614751 is a reply to message #132743] |
Thu, 02 November 2006 11:16  |
class defined but no icon defined for it.
Rich Kulp
Re: VE Path Must Include... Error [message #614752 is a reply to message #132756] |
Many thanks,
Joe
> Rich Kulp
FUDForum. Page generated in 0.05689 seconds
