Home » Modeling » UML2 » LiteralUnlimitedNatural why int(why is LiteralUnlimitedNatural a int and not a long)
LiteralUnlimitedNatural why int [message #1322265] Tue, 29 April 2014 15:30 Go to next message
I just recently realized that a LiteralUnlimitedNatural is a int. I expected it to be a long.
Is there a reason why it is not a java long?
Pieter
Re: LiteralUnlimitedNatural why int [message #1322317 is a reply to message #1322265] Tue, 29 April 2014 16:08 Go to previous messageGo to next message
Hi, Pieter,
The only meaningful differences between UML's UnlimitedNatural and
Integer types are:
* UnlimitedNatural's range does not include zero and negative numbers
(like the
natural numbers of mathematics)
* UnlimitedNatural includes the special ' * ' value indicating an
unlimited upper multiplicity
bound (which does not correspond to any number in the mathematical
natural domain)
As UnlimitedNatural has no negative space, it is convenient to
represent ' * ' with -1 in Java.
Apart from that, long hasn't sufficient precision to represent the
entire natural domain, and BigInteger is unwieldy for such common usage
as multiplicity, so int is the most practical Java-ish representation.
Note that, in practice, it is probably quite rare to see any other
multiplicity upper bounds than 1, 2, or * .
HTH,
Christian
On 2014-04-29 19:30:53 +0000, Pieter Martin said:
> Thanks
> Pieter
Re: LiteralUnlimitedNatural why int [message #1322332 is a reply to message #1322317] Tue, 29 April 2014 16:19 Go to previous messageGo to next message
I'll import the Java Primitive Types then as I need to support longs.
Pieter
Re: LiteralUnlimitedNatural why int [message #1322355 is a reply to message #1322317] Tue, 29 April 2014 16:31 Go to previous messageGo to next message
Correction: An UnlimitedNatural may have the value zero.
[In EMF, the value -2 is also used for some undecided XSD status.]
However since UnlimitedNatural is only used to describe the upper bound
of a multiplicity, a zero value can never be used in a useful model.
Note that UnlimitedNatural is not a number, despite my misguided
rationalization in OCL 2.3 that will hopefully be reverted in OCL 2.5.
UnlimitedNatural has a value '*' that is unrepresentable as either
Integer or Real, therefore UnlimitedNatural does not conform to Integer
or Real and should not be freely convertible to Integer or Real. Expect
UnlimitedNatral to become increasingly unusable without explicit
conversions.
You are better off thinking of UnlimitedNatural as an Enumeration with a
very large number of enumerated values.
Integer and UnlimitedNatural are unbounded so neither int nor long is
adequate. Some tools impose limitations that work nearly always but the
occasional consumer complains. Eclipse OCL has grown from int to long;
the Pivot OCL uses Number and so supports the most convenient
polymorphic representation.
Ed Willink
On 29/04/2014 21:08, Christian W. Damus wrote:
> Hi, Pieter,
> Integer types are:
> (like the
> natural domain)
> usage as multiplicity, so int is the most practical Java-ish
> representation.
> HTH,
> Christian
>> Hi,
>> Thanks
>> Pieter
Re: LiteralUnlimitedNatural why int [message #1323201 is a reply to message #1322355] Wed, 30 April 2014 02:20 Go to previous messageGo to next message
I am afraid you left me somewhat confused?
For a standard property of type Primitive::UnlimitedNatural with upper limit of 1 it may have any value (number) between 0 and * which in UML2 java is bounded by int's upper limit.
This is/was my understanding. Am I missing something or are we talking about UnlimitedNatural at different meta model levels?
Pieter
Re: LiteralUnlimitedNatural why int [message #1323363 is a reply to message #1323201] Wed, 30 April 2014 04:08 Go to previous messageGo to next message
Yes a Property upperbound can be an value between 0 and *.
But UnlimitedNatural is not a number; it just looks like one. Since it
is not a number an implementation may choose any representation it likes
and "int" is a convenient choice where 31 bits is sufficient. There is
spare representational capacity for the irregular "*" value.
You should not be able to add two upperbound values without first
converting their values to Integer, which is a number. And once the OCL
specification is clarified you will not be able to use
..oclAsType(UnlimitedNatural) to cast the integer result; a new operation
will be needed. Perhaps
(bound1.asInteger() + bound2.asInteger()).asUnlimitedNatural() --
asInteger/asUnlimitedNatural give invalid for bad values
Just the same as in Java you cannot write for a Weekday enumeration
weekday3 = weekday1 + weekday2;
you must write something horrible like (not checked, but you should get
the idea)
weekday3 = Weekday.valueOf((weekday1.ordinal() + weekday2.ordinal()) % 7);
Ed Willink
On 30/04/2014 07:20, Pieter Martin wrote:
> Quote:
> Quote:
> Thanks
> Pieter
Re: LiteralUnlimitedNatural why int [message #1324058 is a reply to message #1323363] Wed, 30 April 2014 11:38 Go to previous message
Ok thanks,
Pieter
Previous Topic:Check if given Stereotype can be applied
Next Topic:UML-specific Diagnostician?
Current Time: Sat Jul 19 12:41:32 EDT 2025
Powered by FUDForum. Page generated in 0.04335 seconds
