Home » Archived » Hudson » Plugin NoClassDefFoundError
Plugin NoClassDefFoundError [message #1292153] Fri, 11 April 2014 11:12 Go to next message
Hi, I have a plugin that I've been developing that I import:
import org.jfree.data.general.DefaultPieDataset;
To create a graph, this works fine in Jenkins, but in Hudson I get:
FATAL: org/jfree/data/general/PieDataset
java.lang.NoClassDefFoundError: org/jfree/data/general/PieDataset
         at com.me.hudson.plugins.myplugin.Publisher.perform(Publisher.java:138)
         at hudson.tasks.BuildStepMonitor$3.perform(BuildStepMonitor.java:51)
         at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:736)
         at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:714)
         at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:690)
         at hudson.model.Build$RunnerImpl.post2(Build.java:163)
         at hudson.model.AbstractBuild$AbstractRunner.post(AbstractBuild.java:652)
         at hudson.model.Run.run(Run.java:1474)
         at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
         at hudson.model.ResourceController.execute(ResourceController.java:82)
         at hudson.model.Executor.run(Executor.java:137)
Caused by: java.lang.ClassNotFoundException: org.jfree.data.general.PieDataset
         at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.findClass(ExtensibleURLClassLoader.java:54)
         at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
         at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
         ... 11 more
So I thought something must be off with the dependencies, commenting out this import and code using it solves the issue, but then I get the same with: hudson.util.Graph;
so now im confused... any ideas? also using 3.1.2 hudson
Re: Plugin NoClassDefFoundError [message #1292298 is a reply to message #1292153] Fri, 11 April 2014 13:59 Go to previous messageGo to next message
Hudson graphing interface is abstracted to use jfreechart or any other graphing technology. jfreechart is move to a plugin. If you want to use jfreechart, then add jfreechart-plugin as dependency to your plugin
<dependency>
    <groupId>org.hudsonci.plugins</groupId>
    <artifactId>jfreechart-plugin</artifactId>
    <version>1.5</version>
</dependency>
Re: Plugin NoClassDefFoundError [message #1295740 is a reply to message #1292298] Mon, 14 April 2014 10:45 Go to previous messageGo to next message
Thanks, that resolved that issue, but now its bumped into the same for:
hudson.util.Graph
I tried adding:
<dependency>
    <groupId>org.jvnet.hudson.main</groupId>
    <artifactId>hudson-core</artifactId>
    <version>2.2.1</version>
</dependency>
But now I get the error:
error: javax.annotation.processing.FilerException: Attempt to reopen a file for path ConfigFailNew.stapler
Just looking to see if im going down the right path here?
Re: Plugin NoClassDefFoundError [message #1319909 is a reply to message #1295740] Mon, 28 April 2014 09:13 Go to previous messageGo to next message
Anyone got any ideas here?
Re: Plugin NoClassDefFoundError [message #1320306 is a reply to message #1319909] Mon, 28 April 2014 14:15 Go to previous message
Hi Michael, hudson.util.Graph is part of the jfreechart-plugin, if you include that plugin as your dependency your plugin should build fine. Do not directly add core as dependency. BTW, if your plugin is somewhere in github I can take a look at it.
Feel free to write to me directly at winston DOT prakash AT gmail
Previous Topic:Hudson slaves killed (3.1.2 update)
Next Topic:Problems installing and using Hudson 3.1.2
Current Time: Sat Jul 19 17:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.04790 seconds
