Specifying the JVM [message #1316588] |
Sat, 26 April 2014 12:13  |
OS: Windows 7 Professional
System Type: 64-bit Operating System
Eclipse Version: Kepler SR1 (4.3.1)64-bit
I would like to get clarification on the topic of Specifying the JVM. I currently have a 'default' JVM located on my machine. Do I need to install another instance of JVM and dedicate specifically for Eclipse? I am using the following for reference.
Specifying the JVM
One of the most recommended options to use is to specify a specific JVM for Eclipse to run on. Doing this ensures that you are absolutely certain which JVM Eclipse will run in and insulates you from system changes that can alter the "default" JVM for your system. Many a user has been tripped up because they thought they knew what JVM would be used by default, but they thought wrong. eclipse.ini lets you be CERTAIN.
The following examples of eclipse.ini demonstrate correct usage of the -vm option.
Note the format of the -vm option - it is important to be exact:
The -vm option and its value (the path) must be on separate lines.
The value must be the full absolute or relative path to the Java executable, not just to the Java home directory.
The -vm option must occur before the -vmargs option, since everything after -vmargs is passed directly to the JVM.
For the 32-bit Eclipse executable (eclipse.exe on Windows) a 32-bit JVM must be used and for the 64-bit Eclipse executable a 64-bit JVM must be used. 32-bit Eclipse will not work with a 64-bit JVM.
Here is an example of what eclipse.ini might look like on a Windows system after you've added the -vm argument and increased the maximum heap space:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
-product
org.eclipse.epp.package.java.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vm
C:\Java\JDK\1.6\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx1024m
Remember that the exact values will differ slightly depending on operating system and Eclipse package.
FUDForum. Page generated in 0.12895 seconds
