Home » Archived » Visual Editor (VE) » possibility to use VE source synchronization framework in another project?
possibility to use VE source synchronization framework in another project? [message #131878] Fri, 06 October 2006 05:19 Go to next message
Originally posted by: jan.peknik.tietoenator.com
I'm developing particular project where code generation / source
synchronization
wil take place. The project is currently in analysis stage, we are
evaluation technologies
that would suite our needs.
Is it possible / good idea to try to use VE source synchronization subsytem
outside Visual Editor?
Main huge difference in our project is that we have custom domain model, so
there will be no
IJavaObjectInstances etc on the model side, but It seems the VE has pretty
strong reverse code parsing / engineering and this is exactly what we have
to implements. Is it possible to implements some custom
'last layer' for code generation system that will produce / recognize custom
source code patterns?
Thanks for answer,
Jan Peknik
Re: possibility to use VE source synchronization framework in another project? [message #131930 is a reply to message #131878] Fri, 06 October 2006 09:45 Go to previous message
It would be very difficult. It is fine-tuned to the VE's java model. And
the VE coding pattern within java.
Jan Peknik wrote:
> Hello,
> synchronization
> there will be no
> Thanks for answer,
> Jan Peknik
Rich Kulp
Re: possibility to use VE source synchronization framework in another project? [message #614691 is a reply to message #131878] Fri, 06 October 2006 09:45 Go to previous message
Jan Peknik wrote:
> Hello,
> synchronization
> there will be no
> Thanks for answer,
> Jan Peknik
Rich Kulp
Previous Topic:Controlling the dropping of widget
Next Topic:Controlling the dropping of widget
Current Time: Sat Jul 19 13:02:39 EDT 2025
Powered by FUDForum. Page generated in 0.03283 seconds
